E46 (1999 - 2006)
Old 08-11-2008, 08:27 AM
ZIGGURAT89 ZIGGURAT89 is offline
Mein Auto: 2000 328i
How often should we replace coolant hoses on our cars?
Is it time to replace the coolant hoses at 140k miles? They appear to be in good condition.
Old 08-11-2008, 08:31 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Are you a good gambler? That is really what you are asking. If the upper and lower radiator hoses are what you are referring to they are less than $50 for the pair and it would be a shame for you to blow an engine due to overheating from a blown hose.
Old 08-11-2008, 09:18 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
It was time about 40k miles ago.
The expansion tank is probably the weakest link. I'd change that as well as hoses and belts at a minimum. If it were mine, I'd also replace the waterpump and the thermostat.
Or roll the dice and pay a whole lot more when something eventually fails.
How long do you plan on keeping the car in question?
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 08-11-2008, 10:09 AM
I replaced the entire cooling system( thermostat, wp, radiator, expansion tank) at around 100k miles. I don't think they changed the hoses, but I will get it changed soon. Is it necessary to change the coolant hose to the expansion tank?
Old 08-11-2008, 06:59 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
My Bentley manual says "every four years". I'm good with that. Cheap enough, as smolck said. Why not change them when it's convenient for you?
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 08-11-2008, 09:26 PM
Scott ZHP's Avatar
We want the Lion!
The coolant hose to the expansion tank is effectively the upper rad hose.
At 140k, I'd buy some parts and make a date
Surprised that a shop would change the hard parts and skip hoses; thats odd to me .
Old 08-12-2008, 04:37 PM
BMWayne BMWayne is offline
Mein Auto: 2002; titanium 325 Cic
i replace mine everyday, and i only use the dealer, so yea... i have a money tree.
2002 convertible - 18 inch SSR GT3
Old 08-13-2008, 08:02 AM
Hutchman Hutchman is offline
Mein Auto: 2011 328i, 01 325I
I think it depends on your location. My 325 has 92,000. Here in Houston they do not go through the extreme temperature changes they do in the North. I had the hoses off when I replaced my water pump and thermostat (preventative mx, 85k) they did not show any wear whatsoever. I snapped them back on and have no leaks at all.
Old 08-13-2008, 08:06 AM
Scott ZHP's Avatar
We want the Lion!
In my experience, hoses don't show wear, they just fail suddenly.
Old 08-13-2008, 08:16 AM
smolck's Avatar
ROLL TIDE!
I think that was a big $40 gamble. But then again here in Alabama I have similar weather to Houston. My hoses are WELL past due for a change too...
Old 08-13-2008, 09:44 AM
LKNGOOD's Avatar
LKNGOOD LKNGOOD is offline
Mein Auto: 2003 BMW 330i
I'm planning in changing a few hoses also since I'm about to change the water pump.
I have a question about what hoses to change?
I plan on changing the following:
Part # 11531436408 BMW (OE)/CRP-Contitech - Radiator Hose; Lower to Thermostat Housing with Temperature Sensor Fitting $20.33
(#03 from realoem.com under Engine Cooling)
Part # 17127510952 BMW (OE)/CRP-Contitech - Radiator Hose; Upper Radiator to Thermostat Housing $28.09
(#01 from realoem.com under Engine Cooling)
Part # 17137787039 MTC/OES Expansion Tank/Coolant Reservoir $49.95
(#05 from realoem.com under Radiator)
Part # 11531436410 CRP-Contitech - Cooling/Coolant Hose; Water Pipe to Expansion Tank $18.43
(#05 from realoem.com under Engine Cooling)
I'm ordering these parts from autohausaz.com
My question is do I need to also order these two additional hoses?
Part # R3055-279112* or 11531705210 Heater Inlet Pipe $29.00
(#08 from realoem.com under Engine Cooling)
Part # G2021-279352 or 11537502525 Water Pipe $33.97
(#06 from realoem.com under Engine Cooling)
Later,
Mike
*2003 330i Steptronic *Sport/Premium/Cold Climate Package *HK Premium Sound System *18" CSL Staggared Wheels - HyperBlack *Front/Side/Rear Clear Lights with Solaris II Bulbs *AC Schnitzer Pedals and Front Strut Bar *Rear Lip and Roof Spoiler *Valentine 1 Hardwire *AFE Cold Air Intake Stage 1 *6000K Predator Chromium Angel Eyes and D2S bulbs *CSL-V2 Front Bumper *Painted Moldings & Interior Trim *Matted Black Kidney Grill *CF Emblems & Pillars *H&R Cup Kit "Sport"
Old 08-13-2008, 10:14 AM
smolck's Avatar
ROLL TIDE!
I dont know. The heater inlet pipe doesn't sound like a hose, besides it is under the manifold, so unless you plan on removing the upper intake, you ain't gonna get to it! I wouldn't worry about it, I have NEVER heard of those being a common failure (but it COULD happen I guess).
Old 08-13-2008, 10:58 AM
desertrat desertrat is offline
Mein Auto: non-BMW
Two questions if I may: I have the two hoses, two belts, a water pump with a metal impeller, a thermostat and a Bentley book. I am going to order an expansion tank and a gallon of BMW antifreeze. Do I need to order hose clamps or can I reuse the original ones? The new water pump I have does not have a pulley wheel on it, do I need to replace that also?
Old 08-13-2008, 11:12 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
The BMW hoses do not use clamps.
If the water pump pulley is metal, I don't think it requires replacing. I'd definitely pick up 4 of the bolts that attach the pulley to the water pump however.. they're only to be tightened to about 7lb/ft and are VERY easy to strip... ask me how I know.
Old 08-13-2008, 11:25 AM
uncle ken's Avatar
uncle ken uncle ken is offline
Mein Auto: 2014 M6
Best plan is to replace all the hoses, and all the other cooling system components on a regular schedule. For the 540 that would be about 60 -80,000 miles depending how lucky you feel. If one component such as the expansion tank, cracks, replace everything as it is just a matter of time before everything else blows. Like others here say hoses are cheap, engines are expensive.
"Whither goest thou, America, in thy shiny car in the night?"
- Jack Kerouac, On the Road
Old 08-13-2008, 11:29 AM
Mein Auto: non-BMW
OK thanks, I'll check the pulley and make sure it's metal.
Old 08-13-2008, 11:51 AM
scrapcan scrapcan is offline
Mein Auto: 330xi
as having just done this on a new to us used car, just change all the components and the belts while you are in there. It is money well spent and takes no more time to replace the hoses with the water pump as it does just for the pump.
Old 08-13-2008, 01:22 PM
smolck's Avatar
ROLL TIDE!
How do you know?
Old 08-13-2008, 02:26 PM
Scott ZHP's Avatar
We want the Lion!
How do you know?
Old 08-13-2008, 02:59 PM
How do you know?
- J.C. Watts Jr.
Old 08-13-2008, 03:00 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
How do you know?
because I read it on the internet, DUH
Old 08-13-2008, 03:10 PM
smolck's Avatar
ROLL TIDE!
Old 08-13-2008, 04:19 PM
Scott ZHP's Avatar
We want the Lion!
Hmm, thinking about this some more... the water pump flange is threaded, the pulley is just along for the ride. Did you crack the bakelite pulley or strip the water pump threads? Or maybe both?
I am running Turner Motorsport T-6061 aluminum (underdrive) pulleys for the alt/waterpump/PS pump.
Old 08-13-2008, 05:42 PM
smolck's Avatar
ROLL TIDE!
I was thinking of investing in some of these. Any advice on whether or not they are worth it in your application?
Old 08-13-2008, 05:52 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
I just stripped the $.87 bolt.
