E46 (1999 - 2006)
Old 08-14-2008, 06:01 AM
simmonsinc's Avatar
simmonsinc simmonsinc is offline
Sophistication...
Mein Auto: 2000 BMW 328i
Red face P1397 Code - CamShaft Sensor
Hey Guys... 2000 328i Service Engine Light came on... Just replaced the AC Compressor, and the Code reads P1397. Took the BMW and they said it was the CamShaft Sensor. Does anyone know where I could get one cheaper than $150? And... where is this thing located at?
I tried to get some more info, but the Dealership wouldn't tell me where it was located, or even give me any invoices. Isn't that a bit weird??
Thanks In Advance!!
Sean
Old 08-14-2008, 08:16 AM
BeemerGuy's Avatar
BeemerGuy BeemerGuy is offline
former motorcycle rider
Mein Auto: F06
BMWPartsOnly.com has excellent prices and super service. Try them.
The CPS is a DIY if you are fairly handy working on your car. On the straight six engine, it is in front, so easy to get to. It is the camshaft position sensor, so look around where the camshafts are. Really, when I did this myself (on a 528) I just ordered the part and then looked for something that looked the same. I had to remove the engine hoist bracket first, IIRC, and maybe a hose or two, but it wasn't a big deal.
It may take several engine start cycles before the SEL goes out.
Michael
Old 08-14-2008, 09:19 AM
simmonsinc's Avatar
Sophistication...
Red face
I thought about doing it myself, but when doing some research, they mentioned something about the timing and framing which I don't want to mess up...
Sean
Old 08-15-2008, 03:51 PM
jackinthebox jackinthebox is offline
Mein Auto: 2000 E46 330ci
Hi it's an easy change ,if you look in the forum under Wiki he tells you how ,great wealth of info
Old 09-27-2008, 10:35 PM
silverbimmer3's Avatar
silverbimmer3 silverbimmer3 is offline
Mein Auto: '05 M3 ZCP; '06 530 XIT
The one on the front is the intake cam position sensor; the exhaust cam position sensor is behind the air filter box, right?
