Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 08-14-2008, 11:57 AM
jhowe1's Avatar
jhowe1 jhowe1 is offline
Mein Auto: E46 & E21
'83 320i battery light stays on while keys out of ignition.
-had a reman bosch alternator just put in a month ago.
-had the battery checked and it checked good.
any suggestions???
Dictated But Not Read.
Old 08-14-2008, 01:17 PM
PBC///2.7 PBC///2.7 is offline
Mr.Evil...E30
Mein Auto: 87 E30
look at your alternator...( like all the hook-ups)
Old 08-16-2008, 01:18 AM
jhowe1's Avatar
alternator wires are good.
Noticed sometimes just the clock stays on also...
Old 08-28-2008, 09:33 AM
Mr.Evil...E30
Mein Auto: 87 E30
it sound like to me that there maybe a grounding thing going on there....
Old 08-28-2008, 09:37 AM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Sounds like bad ignition switch. Power should be all off with key removed.
Old 08-28-2008, 09:57 AM
jhowe1's Avatar
i forgot this was posted... i found a couple wires about 8 inches off of the alternator shorting out on each other.
thanks everyone for the input!
Old 09-10-2008, 08:03 PM
Mr.Evil...E30
Mein Auto: 87 E30
^^^^like I said too you....nice too see you fixed it now....hwhehehewewe
Old 10-29-2008, 06:00 PM
rgmrgm rgmrgm is offline
Mein Auto: 87 325i
I am having this problem with a 1987 325i . with the engine off and key removed the battery light stays on. i cannot find a short in the wires. i removed the small wire from the alternator (field wire?) and the light goes out. I shorted the loose wire to ground and the light did not go on. does this mean i have an internal short in the alternator. everything works ok when the engine is running
Old 10-30-2008, 12:55 AM
jhowe1's Avatar
sounds like your alternator is pulling power from your battery. i learned a little bit about this stuff from my previous adventures with my '83 320i. if i remember correctly it is the voltage regulator pulling power (maybe a short in itself)
i think it is def worth a shot...
especially if you have checked your wires off the alternator. like mine.
also, after i fixed my wires, the clock stayed on at all times for about an hour or so... never figured that out but it never returned.
also the post before you this person: PBC///2.7
also has an e30.... they def steered me the right way.
Old 11-01-2008, 09:10 PM
Mr.Evil...E30
Mein Auto: 87 E30
take your "alternator" to a place to have it tested it,if it passes then check your wires that come your battery....if is still doing this...you may have to replace wires that come off your "alternator then....Oh yes how old is your battery and alernator by the way???
Old 10-15-2014, 12:50 AM
mannysd mannysd is offline
Mein Auto: 82 E21 320i
i know why the light is on when the ignition its off
the reason why when you turn off your engine and your battery light remains on its pretty simple actually. A new alternator and battery replacement should be done correctly step by step or you will have electrical problems.
Heres the solotution:
on the back of your new alternator, for E21 models from 79-83. Theres two connections for a special little wire. it connects just like a usb port or the same way you will connect your cell phone charger. All you need to do its unplug your battery for safety. Now on the back of your new alternator, unplug the special cable/wire and plug it on the other connection available thats available on the back of your new alternator. Both connections are next to each other.
Remember! this little cable can only be plug into two separate spots. Once you basically switch it to the other option AND after you hook up your battery cables, your car should be ok.
You will notice that the battery light inside the dashboard is now off. The reason why this happens its simply bc the person who installed the alternator, either you or the mechanic didnt plugged the cables back in the right order.
battery, light, solenoid, starter
