Old 05-31-2003, 12:16 PM
Edwin Huang Edwin Huang is offline
Mein Auto: 2001 M Coupe
S54 M coupe 3.73 diff impression
I have the 3.73 diff in my 01' S54 M coupe for a little over a week now, and it still amazes me every time I drive it how much the 3.73 diff has transformed the character of S54 M coupe. With 3.15, it used to feel like the power delivery is always lagging a little behind. That always bothers me considering how flat the S54 torque curve is. The 3.73 diff really makes the S54 M coupe come alive, I now feel perfectly in sync with the engine. The engine feels a lot more flexible, it pulls smoothly at low rpm even in high gear and the top end rush is really addicting. It makes you appreciate how good the S54 really is and this is the kind of little monster I imagined the S54 M coupe should be in the first place.
Big thanks to MarkL for the head up on 3.73 diff. He showed up on the day of installation, and was kind enough to let me try out the sweet gound controll setup on his white(same as mine) S52 M coupe. Mark is right about Louis at Rush Motorsport, he has done a great job rebuilding the 3.73 diff. Total cost for the 3.73 diff is $1500.
Ed
Old 06-01-2003, 09:56 AM
EYT EYT is offline
Mein Auto: '02 M Coupe
3.73 vs 3.46
Hi Ed:
It must be a blast shifting to third at 70 mph and flooring it. I switched to a 3.46 about 12k miles ago and loved it. My question is in your research for the 3.73, have you tried out the 3.46 in a friend's S54 Coupe? and therefore could comment on the differences?
I am a little bit intrigued by the performance of the 3.73 diff. teamed with the S54. Would love to hear more about your experiences. Somebody mentioned the 3.73 diff from the 325 3 series would work just fine, any modifications needed in order for it to fit?
Thanks,
Eric
'02 M Coupe
Old 06-01-2003, 03:24 PM
3.73 vs 3.46
Hi Eric,
I haven't tried out a 3.46 S54 coupe, so really can't comment on the differences. 3.73 is about 18% lower-gearing than 3.15 while 3.46 is about 10%, so I assume the difference will be similar to going from 3.15 to 3.46.
As for the 3.73 diff from E36 325, I believe it should be a direct fit. Quite a few people have done this without problem, a lot cheaper too.
And what a blast it is. The harder you drive, the more you can feel the difference. Wish I had switched sooner.
Ed
Old 06-01-2003, 03:48 PM
Shawn Fogg Shawn Fogg is offline
Mein Auto: Z3
Ed,
"As for the 3.73 diff from E36 325, I believe it should be a direct fit."
No, it wouldn't be. The direct swap (excepting output flanges) would be E30 differentials excepting the non-M3 4 cylinder diffs.
Shawn
Old 06-01-2003, 04:21 PM
EYT EYT is offline
E30 3.73 differentials
Ed: Thanks for your inputs. Continue to have loads of fun driving your car.
Shawn: Thanks for clearing up the question in my mind. Do I understand you correctly that a E30 M3's 3.73 diff. would fit perfectly for the S54 M Coupe? Please clarify.
Thanks,
Eric
'02 M Coupe
Old 06-01-2003, 05:40 PM
Mein Auto: Z3
Eric,
Yes, it should bolt right in. You may need to swap output flanges though so they mate up with your existing half shafts. You can swap your rear diff cover over to the E30 diff too.
The E30 non-M 4 cylinder differentials are the narrow case diffs like used in 318ti and 1.9l Z3s. All the other E30 diffs (the sixes and the E30 M3) used the same diff case as all the six clylinder Z3s.
Shawn
Old 06-01-2003, 06:23 PM
EYT EYT is offline
Shawn:
Thanks very much for the info. I am going to have a lot of fun searching for a reasonably low mileage one. :>)
Cheers,
Eric
'02 M Coupe
Old 06-02-2003, 03:10 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
What kind of revs are you turning at highway speeds?
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 06-03-2003, 08:46 PM
QikSilver's Avatar
QikSilver QikSilver is offline
Too much is never enough
Mein Auto: 01 M roadster
Eric,
If you're looking for a 3.73, I am a buyer for your 3.46. I'm getting ready to buy one, but I'll wait if I can make a deal with you. Knowing you have cash coming in might make your hunt for a 3.73 a little easier.
John
John
01 M roadster, F: GC/Koni short coilover struts, Eibach, Wilwood front brakes, GC tubular swaybar. R: TC Kline springs, short Bilsteins, IE sub & swingarm bushings & shock mounts, 3.23 gear, Rogue dual-ear cover, Eisenmann 4x83 pipes. MISC: Sport mode, Rogue pulleys, keyless, RG Motorsport intake, OZ Superleggera 18" 3 piece.
06 Hemi Durango
04 G35 Coupe
05 Scion xB
07 Scion tC
89 Reynard F2000
Old 06-03-2003, 09:35 PM
EYT EYT is offline
John:
I actually got my 3.73 diff today, I am very excited about it, will be installing it this Saturday.
I want to keep the 3.46 diff though, thinking I can remain flexible.
Good luck with your purchase.
Cheers,
Eric
'02 M Coupe
Old 06-10-2003, 07:06 AM
DrM DrM is offline
I'm thinking of swapping in a 3.46 or 3.73 diff. Where did you guys get the new diff? I want to keep the stock one just in case.
Price?
Also, for those of you who have done this - how difficult is it on a scale of 1 to 10? I've done quite a bit of engine work on other cars (inc. two rebuilds) but they were much older cars (1980's Mini's) so that's where I'm at on the competence ladder.
TIA
DrM
Old 06-10-2003, 07:52 AM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
Rev's?
I'd be curious to know what rev's are being turned at 70 mph.
looks like 3560rpm
3469 if I installed the same in my S52 with 265/35-18's, of course I would have a much lower redline
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 06-10-2003, 09:11 AM
EYT EYT is offline
3.73 vs 3.46
Bob:
In my S54, with my speedo at 70 mph, the 3.73 shows 3300rpm, while the 3.46 shows around 3000 rpm. ( Very un-scientific observations )
Cheers,
Eric
'02 M Coupe
Old 06-10-2003, 09:35 AM
Shawn:
Thanks for correcting my mistake, hopefully no harm is done.
Pinecone, Bob:
Go to this site http://www.368s.com/tools_rpm.phtml and use the handy rpm tool to figure out rpm changes. 70mph should be at 3,551 rpm with 245/40/17 rear tire.
Eric:
Congratulations on your 3.73, now you know what kind of fun I'm having. Have you done the Sport mode mod? If so, I'm curious to hear your opinion.
Old 06-10-2003, 11:20 AM
EYT EYT is offline
Sport mode
Ed:
I have not done it, mainly due to feedbacks from a few local e46 M3'ers who autocross their cars; on course throttle modulation is hard as the gas pedal becomes overly sensitive, but they tell me the only time they would have it on would be on the freeways.
I have 275/40/17's rear and 255/40/17's for the front, I wonder would the slightly taller tires lower the engine rpm ever so slightly?
Cheers,
Eric
'02 M Coupe
Old 06-10-2003, 12:44 PM
Eric,
Thanks for the feedback. Taller tires do indeed lower engine rpm. If my calculation is correct, that means your final drive ratio should be about 3.59 (3.8% taller). Another factor to take into consideration is speedo error. Mine is about 10% higher, so 70mph on speedo means I'm only doing 63mph.
Ed
Old 06-10-2003, 12:48 PM
EYT EYT is offline
3.73 diff
DrM:
It's a direct bolt-on, relatively simple if you are mechanical.
The switch from 3.15 to 3.73 would be awsome.
In my research, prices varied from $600 from a recycling outfit to $1,800 for rebuilt. Ed got it for $1,500 installed?
Cheers,
Eric
'02 M Coupe
Old 06-10-2003, 12:56 PM
A Clean Windshield
Speedo is accurate!
Originally posted by Edwin Huang
Eric,
Ed
for what its worth.....
I changed the tire size on my S52. now with 265/35-18's on the rear my speedo is exact, no error. I used the 386s.com calculator and checked with local cops using radar.
The whole inaccurate speedo thing was driving me crazy. The cops around here are on every street using moving instant on and stationary radar. 35 mph then 45mph then 25....I was ready to buy a digital rally speedometer. so I used the calculator and I was pleasantly surprised to find my spedo is correct. It was just a lucky thing I picked that size tires.
Old 06-10-2003, 12:59 PM
DrM DrM is offline
Thanks for the info Eric.
It seems like this mod is the best bang for the buck without messing too much with the S54 engine.
Is metricmechanic the best place to go for this - anyone else who has done it let me know where you got your diff.
Having owned a 2002 M3 I also miss the sport mode - but don't want to do that mod for warranty reasons.
cheers
DrM
Old 06-10-2003, 03:44 PM
Mein Auto: Z3
Keep an eye on ebay and you can usually pick up a used one cheap.
For example:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2418661907
Shawn
Old 06-15-2003, 05:04 PM
H&RMcoupe H&RMcoupe is offline
Mein Auto: 2002 M coupe w/coilovers
what would you say the acceleration difference is from say 0 to 60, 30 to 50 etc... with the 3.46 and 3.73 versus 3.15. I would imagine it would be faster?
