E60 (2004 - 2010)
Old 08-25-2008, 09:34 PM
harmonkardon123 harmonkardon123 is offline
Mein Auto: 2005 545i
check engine light- increased emissions
I have a check engine light on my 05 545i that reads on the increased emissions, this went on last week when I put cheap gas and then went off when i put in gas with an octane of 91, but it has come on again. Any help with this would be appreciated.
Old 08-26-2008, 06:49 AM
skylolow skylolow is offline
Mein Auto: 2004 545i Sport with SMG
Mine just came on to about a week ago. I researched around and the conclusion is there is just many different things that can cause this. Everything from bad gas, gas cap not on correctly, bad seal on gas cap, one of the many different emmissions sensors, thermostat, and the list goes on. So mine goes in Friday. I'll tell you what they say.
Old 08-27-2008, 09:01 AM
CLG CLG is offline
Mein Auto: '05 545i Sport
If you guys did a search, you would find that a couple of us have had this issue in the recent past. Mine was a bad O2 sensor, and I can't remember the other ones' issues. However, you should take it in to get fixed soon.
CLG
2005 545i - Jet Black - Black Dakota - Dark Poplar - Sport - Logic 7 - Park Distance Control - Escort 9500i hardwired - Sirius - Adaptive Xenons - Active Steering
Old 08-30-2008, 08:42 AM
Well took my in Friday and it turned out to be the DMTL Pump part of the fuel system.
Service agent told me it quite common as there is a small valve/flap in this part that once in awhile sticks and sets off the error code FC 27 CB. According to him it usually just unsticks itself but the error code is there. So since it was covered under CPO they just replaced the DMTL Pump.
Asked him about the increased emissions warning and he said its usually a O2 sensor (4 of them I believe are on the car) or its this DMTL Pump. One of those two he said is the reason 90% of the time.
Old 07-25-2011, 09:07 AM
1garry 1garry is offline
Mein Auto: 2005 bmw 545i
On my 2005 545i I had incresae emission lite change crankcase pressure valve change them reset lite is off
Old 07-25-2011, 10:19 AM
JASONAARONDC JASONAARONDC is offline
Send a message via Skype™ to JASONAARONDC
Mein Auto: 04' 525i
Mine was caused by a secondary air pump relay. The dealer told me it was the pump itself. I tested the pump, checked the fuse, and then determined that it was the relay. I changed it 2 months ago and the light went off and hasn't come back on.
If you think its the gas, just go get a bottle of octane booster and take your car for a highway trip and beat on it for a while.
2004 525i AUTO, STAGGERED 20" BEYERN RAPP WHEELS, 20% TINT, 7.2 HEADREST MONITORS, KICKER AMP & DIRECTED SUB WOOFER, ADAPTIVE 6K HEADLIGHTS & 6K HID FOGS, LED INTERIOR LIGHTING, HEATED STEERING WHEEL
Old 07-25-2011, 12:27 PM
danna's Avatar
danna danna is offline
<my other German
Mein Auto: 05 545i
good luck with that. I had "increased emissions" turn out to be nothing early in my '05 545i life, but at 75k it meant thermostat, valve cover breather tubes, belts, vacuum pump, vlave cover gaskets, oil pressure switch, and upper timing cover gaskets...to the tune of $1,300.
2008 550i Carbon Black manual, sport, cwp, fold down rear seats, nasca leather vent seats, CA, HU, night vision
2005 545i, black on black, sport, prem, cold, fold down seats - sold
2005 545i, 6 speed MANUAL, black sapphire, auburn interior, sport, prem, comfort seats, fold down rear seats - deceased
Old 10-04-2011, 12:50 PM
laro1965 laro1965 is offline
Any wisdom/recommendations from you experts would be so appreciated. I've had issues with the rough idle for about 3-4 months now. I spent a couple of hours reading everything I could find on the issue. As far as I can tell, there is a cold start idle issue and and warm start. It seems that mine falls in the category of the warm start.....which from what I've seen on these forums is about 25% of the time. Here's what my car is/has been doing:
1. Turn the car on in the morning and as it warms up, it does something weird after a couple of min, idle comes down to 500 rpm...and yes, I get the increased rpm/surge when I put it in reverse. I can live with that.
2. I have NO ISSUE when the A/C is off. But once the compressor kicks in, the idle goes to 700 rpm and then it begins to wildly flutter up/down. I've seen it as high as 900 and as low as 400 rpm.
3. This issue occurs in Drive only - if I put it in Neutral or Park it idles normal.
4. Have had "Service Eng Soon" light come one a couple of times..with the Increased Emissions message. The first time I took it in to the dealership and they replaced the crankcase valves. I picked it up and was back within 15 min...Light came back on. It ran much smoother after that...but the idle issue came back the next day. I can't remember what they did then but I guess they just cleared the msg??
5. A few days later I get the "Service Eng Soon" light again while sitting at a light with the A/C on. Drove it for about 10 min. Then it idled wildly and I immediately noticed that the "Service Eng Soon" light actually came off or cleared itself. But I was still having the problem. So I went back to the dealership. I left the car on and had the Serv Mgr come sit with me while he watched. He did tell me that light fluttering of the RPM needle is "normal" for these engines (incl. X5 and 745i) but the engine doesnt do what mine was doing. So I leave it again. They check everything and could find nothing else wrong.
6. Serv Mgr calls me and tells me that they are going to try to reprogram the engine overnight (valve lift program?? idk) and they also upgrade the CCC software in iDrive. I mentioned the 25 sec relearning prog and he says: "No, you have to do a computer reprogram for the engine to relearn itself". He tells me they drove it several times that day and could not get it to do the same thing. So I pick it up that evening..running smooth! He also tells me that it may be a bit touchy since its reprogrammed to brand new specs. New software in iDrive and the car is really, really driving well...A/C on and everything.
7. The very next day that evening the rough idle comes back with a vengeance. But I notice the following: the issue is still when the A/C comes on...but when I left during lunch car was fine and I usually keep my A/C temp around 76° F or so (yes, blue bars in iDrive) operating normal. But then in the evening, 90's outside, hot car, A/C acts like normal but then it switches and I can barely get any air. I have to put the thermostat all the way to the left at 60° F and it still not blowing enough. Everytime I come to a stop I have to either endure the idling/sputtering or put it in Neutral. I've been driving like this for about a week now. Everyday is like clock work. Come 5 pm I have to put the A/C on manual so I can get enough air (dont forget I'm in Tx!). Now I got the Service Eng Light-Increased Emissions light again yesterday.
Interesting note: When I dropped off the car the last time at the dealership I printed both SIB's (cold start and warm) and gave them to the Serv Mgr. After I picked up the car he told me that if the reprogramming didnt work that the only alternative is doing the SIB procedure---which he tells me it will be around $2000 or so. I have no warranty, my CPO ran out in Feb 2011. I am really disturbed now because I dont really have ANY confidence or guarantee that the SIB will fix the problem. And besides that...if I want to get rid of the car...who is gonna give me what is worth with this obvious issue?
I do not where to go from here. I'm ready for them to just buy it back...but at what cost? I'm not willing to shell out thousands with no guarantee of a fix. I've really had my fill of this problem.
Old 07-25-2012, 05:09 PM
DD545I DD545I is offline
Mein Auto: 2005 545I
I got this warning on my 05 545i last week. Finally had the chance to have it look at a private shop and they said the thermostat is failing and cost of repair is $302 to be exact. Prior to this warning light, i noticed that when cruising between 30-40 miles per hour, the car would drop speed and rpm feels a little choke or hiccup but at higher speed the car runs fine. This is on regular drive mode. Anyhow, I'm taking the car in to a dealership tomorrow morning and have it diagnosed and see what they find out about the "increased emissions"? I'm not going to tell them about the little choke or hiccup just yet.
Anyone experience the same issue?
Will be posting a follow up soon as possible.
Old 07-25-2012, 05:17 PM
borderchris's Avatar
borderchris borderchris is offline
Ich liebe meine Funfers!
Mein Auto: 550i and E34 530i
Nice job on reviving a 2008 thread
Anyway, many engine performance parameters get their data from the temperature and position of the the thermostat. Your quote for the job is ridiculous, though- It's a 30 minute job with a $55 part:
http://www.partsgeek.com/mmparts/the.../bmw/545i.html
Remove the forward lower pan, drain the radiator, remove the air intake, disconnect the sensor wire and hose clip, remove the three screws and replace. Refill with a 50/50 mix of distilled water and BMW (or Zerex G-05) coolant, run with the cap off and heater on for a few minutes to bleed, and you're done.
550i . Sport . Nav . L7 . Sirius . Cold . Eibachs . Bilsteins . 19" TSW . K&N . MTech V3
Old 07-27-2012, 10:49 AM
Unbelievable! Had an appointment with the dealership yesterday 7:15am in hopes of getting that second opinion and find out exactly what the problem maybe. I was told by the service advisor it would take 1-2 hrs to run it through a complete diagnostic test but they NEVER touched my car. Yes, from 7:15am to 4:30pm my car sat there. The advisor was hard to get a hold of and when he did call all he could say was I'm sorry we are really busy and that the service people pulled a "waiter" a customer who had no appointment in front of me. This guy was full of crap! Stay away from BMW of SUCK i mean San Diego!
Anyhow, i found another shop and im taking the car in this afternoon. I hope 3rd time is the charm. I will post another update...
Old 07-27-2012, 06:21 PM
MachtSchnell's Avatar
MachtSchnell MachtSchnell is offline
Mein Auto: 2008 535
I hope you find the issue. I had a similar experience, supposedly a puma opened and everything. Turned out to be a bad injector 2 heading out and 2 O2 sensors. A small BMW dealer in ft Walton beach that mostly works on Toyota's found the issue in an hour. Local dealer United BMW Roswell had the car for 4 weeks the last time. 3rd place was the charm.
Schwarz | Premium | Sport | Nav | Sat | Paddles | PDC | Lead Foot | Hardwired Passport 9500ix w/ Escort Live | Convenience | Matte Grill | JB4 | DCI | LI Jammers | smoked side markers | Specdock | rear spoiler | AutoWerke BOV | BMS Oil Catch Can | R1 Cross Drilled Rotors w/ Hawk HPS pads |
BMWCCA Peachtree Chapter Member 444107
Old 07-31-2012, 10:14 AM
Ok, so the 3rd place was a charm They just earned a new customer. I found this place through a friend and the guy's name did not ring a bell at first, but it turned out I know the guy the owns the shop. After telling them what i been through, they waive the diagnostic fee. Just as suspected it was a failing thermostat. The first shop was charging me $302. These guys charged me $240 for parts and labor and with the peace of mind that the job was done honestly. I wish BMW of San Diego could of diagnosed the car and given me the results and what cost was going to be. Not that I was gonna have them repair it. I will never go back to them! Anyhow, thanks for the replies. The car is running flawlessly i can tell the difference in performance and no more rough idling. Also, the choke or hiccup that was going on when driving between 30-40 mph is no longer happening.
Old 08-08-2012, 01:52 AM
sassernucka sassernucka is offline
Mein Auto: 2004 530i
I just had that error pop up and took my 2004 530i to the delership and it turned out to be a bad 02 sensor and it ran me about 600$. the delership kept my car for about 3 days due to them having trouble resetting codes and them just being busy I guess but I got a loaner so it wasn't too bad.
Old 08-09-2012, 06:01 AM
Phil75070 Phil75070 is offline
Mein Auto: 545i
I've had intermittent problems with this, too. I needed an oil change and had my indy check it out. They couldn't find anything wrong and reset it - no charge. Another time the Service Engine Light had come on I had to take it to the dealer for one of the recalls. I had them check it out and they couldn't find anything wrong either so they, too, just reset it - at a cost of over $100! I have had that light and the "Increased emissions" light come on and eventually go away of its own.
More recently, I got in the car, started it up and get the Service Engine Soon light and the "Engine Malfunction" warning. My indy checked it out and it was misfiring as the cylinder one coil was "shot'. They replaced that and all of my spark plugs and $500 later the car is running great again. I don't know if the intermittent problems were early warning signs but when taken to both my indy and the dealer thay had found nothing to repair.
2005 545i, Jet Black, Black Leather, Cold Weather pkg, Logic7, 6 disk changer, Sport Package, Automatic, moonroof, electric rear sun shade, dark wood trim, PDC, Xenon Adaptive lights, Nav, Sat radio, 245/40 ZR18 - 275/35 ZR18 tires, Progman 30.02
Old 08-13-2012, 05:15 PM
Jaycal3's Avatar
Jaycal3 Jaycal3 is offline
So this message just popped up for my 04 545 on Thursday. I had the codes run today by my BMW mechanic who works out of his house and basically has all the tools, computers, software etc necessary... Anyway, He said I am getting a fault on the secondary Air Pump/Valve System... if I am understanding him correctly, there is a pump that only goes on for a few seconds when the car is started cold. This sends air to the back of the motor where there are 2 valves, one for each head. My pump is working fine. The lines are a plastic/rubber and could be cracked and/or the valves could be gummed up or stuck. He says I have to (or should) replace the valves in the back along with the lines and hopefully this takes care of the issue. Worst case scenario is that the heads need to be opened and cleaned (which has to be sent away)..... mucho dinero....
So for now the codes are cleared (although he says it will most likely come back within 3-4 cold starts) and parts will be ordered for the first and hopefully only part of the job. $600 for parts and labor - the parts alone are about $125-150 for each valve and another $50 or so for the lines... his cost. I am hoping for the best... why couldn't it just be an o2 sensor...
oh wait, this is me and my bad luck!!
Deceased - 2004 BMW 545i Black/Auburn
-Sports Suspension, Premium and Cold Weather Package, Logic 7 Professional Audio, Rear Sunblinds, Adaptive Xenon Headlights, Active Steering, staggered setup on 124's, Aux Input
Mods
MTEC V3.0 AE's, Black and white roundels, Clear LED Side-markers, New Conti ExtremeContact DWS's, Charcoal Filter Delete, 35% Tint, 20%rear.
http://s705.photobucket.com/albums/w...%20BMW%20545i/
GARY BETTMAN IS A TOOL!
Old 10-02-2012, 11:55 AM
idriveE60 idriveE60 is offline
Mein Auto: 2004 e60
increased emissions fault.
i recently had the increased emissions fault on the idrive console with the dreaded CEL light
, i ran a code seach on OBII it came up with secondary air valve and air pump malfunction
and o2 sensors running lean ,im going to start repairs and hope the CEL stays off .
Old 10-02-2012, 05:19 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z3 2.8L, 545i
Please post some OBDII codes! Increased Emissions can come form a lot of items. Cam sensor, coolant sensors, O2 sensors, Vacuum, on and on.
I am chasing a P0492 Secondary Airbank 2 - Drivers side. It is not the O2 sensor as I replaced it. I have no cracked air lines and vacuum lines test good.
SES never comes on at start-up it usually comes on after 15 minutes of driving or in one case 1 hour. The secondary air pump is not even on at those times. The pump works great and I have received only bank 2 which means bank 1 is working OK - which means airpump and relay are ok.
Old 12-03-2012, 12:54 PM
blksphrwit19 blksphrwit19 is offline
Mein Auto: 2005 525i
whats the average price for a brake flush my service indicator is red
Old 12-03-2012, 07:21 PM
joe110010 joe110010 is offline
Was the dealer you went to the one in Kearney Mesa, or a different one? What's the shop you found that was good?
2005 525i
Old 03-10-2013, 11:07 AM
Kalil147 Kalil147 is offline
Mein Auto: BMW 545i
Has anyone gotten this code from OBDII? P0507?
At times the code would appear and disappear by itself. Now the check engine light stays on and I get this code: P0507. I already replaced the waterpump, thermostat, alternator, and battery prior to the code. I cleaned the mass airflow sensor, I checked the crankcase valves and they look new (no bends, no tears).
Symtoms: Car jerks at times, sometimes a rough idle, check engine comes on, and goes away at times, now the check engine doesnt go away. Code P0507. What should I replace? Should I replace the CCV even though they look ok?
Any suggestions?
Old 03-10-2013, 11:34 AM
pjinca pjinca is online now
USAF Pararescue Veteran
Mein Auto: 2008 550i
Try this: http://forums.5series.net/diy-do-you...no-more-85337/
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers
Previous 3 cars (the 550 is my 38th car):
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-21-2013, 04:19 PM
mgunner42 mgunner42 is offline
Mein Auto: 2004 545i manual
just got excessive emission code on my 2004 545i and when i hooked up code reader said it was thermostat with coolant not reaching desired temp so looks like i am gonna be replacing only a thermostat if i am lucky.
Old 03-22-2013, 01:48 AM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
Read your fault code - if P0128 then pull off the harness on the thermostat and measure the resistance across the two conductors in the connector in the thermostat. Should read around 16ohms. If it reads 1 your thermostat heater coil is open (failed) and replacing the thermostat will correct your problem.
Old 03-24-2013, 06:08 AM
bmwrulez bmwrulez is online now
d'oh!!
Mein Auto: 05 545i, 06 330i (Hers)
Thanks for the info on testing the thermostat. Found out i replaced a good thermostat. Oh well. But, does the same process apply for testing ohms on water pump? I'm getting a 1 when testing.
Sent from my SCH-I535 using Bimmer App
