E30 (1982 - 1993)
Old 08-25-2008, 10:58 PM
boien boien is offline
Mein Auto: 1998 323is coupe
awww **** what just happened did i blow my timing belt or fan belt ? and if wasnt a b
i went off a curb about an hour before the car just started to stop on me. im sure it isnt my battery because all the lights still work perfectly. and it turns on just fine. So here i am about to get off my exit, when suddenly my car starts to slow down on its own and i start to hear a really loud tick tick tick tick tick tick sound and it gets louder and i gas the car more. ithe car suddenly come to a complete stop on its own. 2 lights on my dash now come on, the oil light icon and the battery light, nothing else. i get out theres smoke coming out of the back, and some thing is leaking under the bottom of the front of the car. now, can someone please tell mewhat the hell just happened?????????? im told tat its my fan belt but i dont know so im here looking for help.
Old 08-25-2008, 11:16 PM
Ryan M Ryan M is offline
Mein Auto: .
Have you opened the hood and looked?
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 08-25-2008, 11:23 PM
no i had to leave it about 1 mile from my house and it was about 9pm and no street lights where i could park so no.
Old 08-26-2008, 06:16 AM
wtown312 wtown312 is offline
Mein Auto: 2002 330ci
Sounds like you could have busted the oil pan when you ran off of the curb. Smoke coming from the car would not be caused by the fan belt unless the fan belt was loose. Then there would be the smell of burning rubber? Did you smell burning rubber? Did the temp gauge run into the red? Well i hope it is something as simple as a fan belt but it sounds like you busted the oil pan and then ran the car with no oil, which caused the valve train noise and or rod knock.
Old 08-26-2008, 09:30 AM
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
+, I also think you cracked your oil pan. I shattered my oil pan in HS, and there was smoke everywhere luckily I turned the engine off the second I heard the bang so all i needed was a new pan. Good luck getting your car fixed let us know what happens.
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 08-27-2008, 02:00 AM
downhiller's Avatar
livin large
+another 1. theres only a couple times when the ticking noise gets louder, no oil pressure, or too light of oil.
Old 08-27-2008, 07:10 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
You killed it. It's ova. No pan= no oil= motor siezed. Not to mention who knows what type of susp damage is done.
Old 08-27-2008, 07:47 AM
haha say what you mean swiss, don't sugarcoat it.
time for a motor swap boien...good luck w/ everything
Old 08-28-2008, 10:41 PM
so heres the deal
from the mechanics mouth:
it all starts with a freshly painted street curb. turns out that my AC belt was already starting to fall apart being that its probably never been in changed in a long while. so, after rolling off the curb and scratching the bottom of my engine with all that paint. the paint then dried up and became hardened, this all happening while the belts are still trying to rotate. this which caused my AC belt to start falling apart, once that happened it got tangled up with the Alternator belt since the AC wasnt blowing from the fan any more which caused my radiator to overheat. going off the curb supposedly created a small hole in the radiator. if this is the weirdest stuff youve heard happen to a car then im glad to share it with you as for the progress of the bmw, its still in the shop and waiting on the custom parts to be replaced. parts : AC belt , Alternator belt, Temporary Radiator. comments welcome. feedback adn advice as well. yes im still new to BMW's and still learning. will report later.
Old 08-28-2008, 11:20 PM
downhiller's Avatar
livin large
i have heard of weirder things but then of course i did work at a dealer that dealt with alot of old people.
Old 08-29-2008, 05:33 PM
Well im not a master BMW mechanic, but if this "dried paint and busted radiator" story is true then you engine is probally siezed from running the motor hot for long periods of time. Or you have a warped head due to over heating. I want to call BS on this story especially the paint hardening on the AC belt. The engine should still run for a short period of time (without running hot) with out a radiator and AC belt. If this sory is true then my advice is get a new mechanic.
Old 08-30-2008, 02:24 AM
ok, so let me get some numbers here from you fellas on what you think these would cost me in a store or from where ever i would need to go to get them.
how much would each part cost me ? 325 '86
-New Radiator
-New AC belt
-New Alternator belt
Old 08-31-2008, 08:05 PM
downhiller's Avatar
livin large
Originally Posted by boien View Post
-New Radiator
-New AC belt
anywhere from $130 to $600 depending on performance wanted
why do you need that?
i spent like $12 on mine from bavauto with shipping
Old 09-03-2008, 11:35 AM
12$ dollars on what ?
Old 09-04-2008, 10:11 AM
325ic a beer's Avatar
325ic a beer 325ic a beer is offline
World Traveller Forever
Mein Auto: 2006 650i Coupe
God ....if you believe that....
Then I have bridge to sell you.
Paint drying??? Are you f-ing kidding me? Your mechanic sure does have a f-ing vivid imagination Boielen.
Thats the dumbest theory I have ever heard.
Sorry. Thats waaaaaay tooooo out there even for me to believe.
Thats "HOKE"!
325ic a beer
"Swimming with the sharks" All over this World...I'll see you in the next one.,,yeahhhh.... AND DON"T BE LATE,,,, DON"T BE LAAATTEE! ...(Jimi Hendrix)
Old 09-04-2008, 10:13 AM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
lol Seriously.
Old 09-04-2008, 09:04 PM
On Top
Well....
The tick may have been the belt slapping against something. No Alt belt will cause your car to overheat and die due to no power being generated back into the battery. The curb killed you rad and likely you pressed it into your AC belt, which caused it's demise. Sry, but the paint didn't do you in.
Old 09-07-2008, 09:28 AM
idc4mhc idc4mhc is offline
Mein Auto: 1986 325 E30
Have him check the motor mounts while at it. Maybe consider changing waterpump/T-belt while radiator is out in case it is due. May save on some labor.
Old 09-07-2008, 06:17 PM
cliffmac cliffmac is offline
Banned
Mein Auto: 325ic
doesn't sound good
gonna have to look at it, but a jumped curb doesn't sound like a timing belt thing...sounds more like an oil thing...I would agree with others about the cracked oil pan thing...I certainly would look at it before trying anything else. A cracked oil pan is very easy to detect...or just check the dipstick and determine oil level....good luck
Old 09-07-2008, 06:23 PM
benmazur16 benmazur16 is offline
Mein Auto: The Bus
Wow your mechanic is a jerk. I don't believe that paint story for a second.
Edit: Take a look at the flux capacitator and piston return springs.
Old 09-07-2008, 06:38 PM
Banned
Mein Auto: 325ic
this is quite a little tale of goofiness
jumping curbs, paint, timing belts...yes...quite interesting...keep us posted on this one...good luck
Old 09-07-2008, 06:43 PM
Banned
Mein Auto: 325ic
you're serious about this?
hmm, this is better than one could hope for...good luck
Old 09-08-2008, 05:24 AM
But dont let your mechanic charge you extra for turn signal fluid, oh and have him rotate the air in your tires.
Old 09-09-2008, 12:29 AM
Rekcedbob Rekcedbob is offline
Mein Auto: 1985 Bmw 318i
Rotating the air in the tires, funny, but I have a feeling the reason most people DIY is because it's not so funny.
Old 09-21-2008, 12:53 PM
ok so heres the update on my e30, its a long list. ( going off of receipt )
I had replaced:
Timing Belt
Rad Hose
Hector Hose
Thermostat
Hose
Thermostat Housing
Head Gasket
Intake Valves
Radiator
Degreaser
Carb Cleaner
Clamps
Fuel Hose
Rostch? Plugs
Oil Filter
Cam seal restrainer
Hose Clamps
Now she runs like a beaut.
comments ? feedback ? fellas
