Old 11-05-2009, 12:41 AM
harjothundal's Avatar
harjothundal harjothundal is offline
E65/E66 Helper Man.......
Send a message via AIM to harjothundal Send a message via MSN to harjothundal
Mein Auto: BMW 745 Li
a most bus isnt intended to be a repair, but rather diagnosis... if it helps symptoms, i hate to say that whatever issue cause the problem will most likely arise again... this just reset all devices in the chain so they re-establish communication, that's really about all it does... also be careful with the fiber optic wires, the smallest kink can affect the entire ring!
Old 11-05-2009, 08:15 PM
745ibeamer 745ibeamer is offline
Mein Auto: 02 bmw 745i
hey harjot, check your pms...
Old 11-23-2012, 05:35 AM
hedge hedge is offline
Mein Auto: Bmw 745i MY02
Thanks a million for that! Now I have bass! And its Friday. All I need now is beer and someone to chauffeur me around...
Just like you said, after reset it seemed like I got several more speakers. Fascinating!
Life's good!
Originally Posted by A4427 View Post
Just wanted to share with you.
I was pretty much dissatisfied with sound quality on my E65 (No Logic 7 installed) and felt that sound system is not working correctly (lost clarity especially on high frequencies) After some research found an article by mighty BMW_Tech where he suggested following to fix unrelated to my problem audio failure:
"We can isolate possibilities and eliminate them one by one,thus the need for more information.If you can,borrow a MOST bus "jumper" from another car.This is located in the glove box, looking in it's on the top panel with a "door".You cant miss it,that's the MOST bus connection for the OPS.(Pin 1 is incoming,2 is out) You can try to "reset" the MOST by turning the key on and disconnecting/reconnecting the jumper plug."
I decided to try reset. Result is AMAZING. Now system produces deep and clear sound on all frequencies and I am happy happy ! It's like half of the speakers just got turned on...
I do not know, maybe bus reset triggered other processes but looks like now system is back to normal again.
BMW_tech, thanks for info!
Old 12-07-2012, 08:22 AM
wtr1906 wtr1906 is offline
Mein Auto: 05 745i
I can't believe this actually worked but I tried it on my 07 and my audio sounds totally different! The bass is strong now and not all treble. Thanks a million!
Old 12-08-2012, 06:03 AM
los2much's Avatar
los2much los2much is offline
Mein Auto: 745li
Has anyone tried it with logic 7 and it worked.
Old 12-08-2012, 07:23 AM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Guess I will try this too.
I've about had it with my feeble ass bass...
~ Big Marcus
Old 12-08-2012, 07:58 AM
TXSTYLE's Avatar
Just returned from doing this.
I shall allow the following smiley to describe my results...
Ohhhh Mmmmm Geeee!!!!!!!!!!!!!!!!!!!!!!!
My stereo completely woke the FOK UP!!! Bass is now present... BIGTIME!
Now then... I was unable to completely remove the clip (pisses me off how they make small **** so difficult to remove!) so I used a small screwdriver and pried it loose. It didn't take much but I knew the connection broke because the radio and screen went off. The engine wasn't running but the everything else was: place fob in and press start, THEN do the disconnect.
HEDGE... I owe you a BREW bruh!!!!
*edit* this makes me wonder about the "amp fix" floating around....
~ Big Marcus
Old 12-08-2012, 08:01 AM
TXSTYLE's Avatar
If A4427 is still around after all these years.... I owe you a BREW or TWO!
~ Big Marcus
Old 12-08-2012, 08:05 AM
albertoxikitin albertoxikitin is offline
Mein Auto: bmw e63
~ Big Marcus
Me alegro mucho de que lo solucionaras Marcus.... Ahora podras escuchar bien la musica de tu hermano LL COOL J....jajajajajaja..
