E46 (1999 - 2006)
Old 08-31-2008, 10:45 PM
328ijp 328ijp is offline
Mein Auto: 1999 BMW 328i
Throttle Cable broke, need help how to repair
Hi All!
I was driving home tonight and completely lost the gass pedal. It went dead, no throttle, the car would not go. I was stranded on the interstate and had to get towed to my house. Upon looking further under hood, I pulled the cable next to the throttle and found that the end of the cable was not connected. I no clue how to fix this. At the is a small ball, that I'm assuming connects to some sort of plate.
Does anyone have a DIY or can give advice on how to repair it?
BTW: The car starts great, I can push the gas pedal all the way down, (which is floppy) and the car will move less than one mile and hour.
Any help is greatly appreciated!
JP
1999 328i - Titanium Silver
Old 09-01-2008, 06:38 AM
dj330Ci's Avatar
dj330Ci dj330Ci is offline
The Ultimate ‹bermensch
Mein Auto: 2006 330Ci ZHP
Well, you might need to go to dealer/mechanic. Bentley states on 130-18, "Models with DME MS 42.0 are equipped with a throttle cable. Cable should be adjusted any time it is disconnected or replaced. Seriously? This procedure requires the factory scan tool or an equivalent to read and adjust throttle angle. It is recommended that this procedure be done by an authorized BMW dealer service department." Depending on MT or AT, there are specific instructions. Let me know if interested. Good Luck.
There's no such thing as an ugly man with a fat wallet!
Old 09-01-2008, 07:03 AM
I'm definitely interested. I can't drive the car to dealer obviously, a tow truck can not get in where I'm at, so I'm stuck. Any help is greatly appreciated.
JP
Old 09-01-2008, 07:26 AM
dj330Ci's Avatar
Okay. One step at a time. Which transmission do you have? BTW this doesn't look easy at all but let's start at which trans.
Old 09-01-2008, 08:13 AM
It's a manual trans.
JP
Old 09-01-2008, 08:45 AM
dj330Ci's Avatar
My next question is, Where would you rate your diy skills on a 1 - 10 scale? This question is really important because the fix itself might be really easy but according to Bentley a bunch of things are moved out of the way in order to get to it; things that are a major PITA because of where some fasteners are located. Get back soon and I'll tell you more. Meantime I'm going to look for a scanning upgrade for my printer so I can scan the directions, so keep your fingers crossed.
Old 09-01-2008, 09:03 AM
I'd say a 6. I've done some work on my car. General maintenance, tune-ups, etc. I've also been told that this should go to a dealer because of the throttle slack on the cable has to be correct. That's the part I'm not sure of. Taking things on and off does not bother me, I have patience for that. It's not knowing how to adjust the tension on the cable that bothers me. Let me know, thanks for your help!
JP
Old 09-01-2008, 09:12 AM
dj330Ci's Avatar
Have you ever replaced the tube elbow and the rubber boot? If so, that's good. According to Bentley these things are removed in order to get to the cable. Here's a link to illustrate the tube diagram. The cable is directly next to the throttle housing assembly, just north east of. http://bmwfans.info/original/E46/Cou...3/ill-13_0905/ As far as adjustment specs, Bentley has those as well.
Old 09-01-2008, 09:20 AM
No, I've never removed it. I did take a look at it and feel pretty confident that I could remove everything and get to it, but don't know what I need to do from there. Also, It looks like the cable has slipped out of the rubber sheath. The metal cable is exposed with the ball on the end.
JP
Old 09-01-2008, 09:29 AM
dj330Ci's Avatar
That is the best case scenario. Probably could re-seat it depending on what caused the problem. The PITA is taking the tubes off of the throttle body because of the position of the hose clamps fasteners and their screw head for lack of a better turn. Many have pulled their hair out trying to get to them. Where in relation to atl are you coming from? If you have another vehicle we could meet halfway. I've been wanting an excuse to shop Dekalb County Farmers Market if they're open today.
Old 09-01-2008, 09:31 AM
I'm actually in Dekalb county. The Market is in Decatur, about 8 miles or so from me. Looks like they are open.
http://www.dekalbfarmersmarket.com/
JP
Old 09-01-2008, 09:53 AM
dj330Ci's Avatar
They are open; I just checked. Why don't you take a look at the location of the clamps mentioned, then find the screws and see if you'll have enough time to undo all that assuming you need this by tomorrow. This'll give you a sense for the difficulty of this job which probably accounts for about 85% of time involved. While you're there see if there are any cracks in any of the tubing especially at the Y split on the tube elbow. If so, this will have to be changed at some point but not necessarily today. Looking at the pic it looks like the screw is in the right position for removal which indicates a good probability that the tubing has been replaced which is really a good thing. Let me know and we'll talk about me meeting you. Check PM for my phone #
