E36 M3 (1995-1999)
#26
'98 M3/4 (manual) Estoril/black nappa, UUC clutch stop, airbox debaffled, Pilot Sports ’04 Discovery II |
#27
#29
facebook.com/sctsracing 02 M3 SMG Coupe - prepared class BMW Club racer 08 135i 6sp - stock class BMW Club racer Photo gallery |
#30
My quick contribution -- I have more than what's listed so far ...
But, as a follow-up to the water pump issue ... I would highly suggest people use the COMPOSITE water pump. E36 M3's have gone through 3 revisions of the water pump. a) plastic pump with the 95 M3's b) iron cast metal impellar pump; and c) the new composite pump which seems to feel like plastic than metal. I don't have the p/n's off the top of my head ... I posted them on bf.c. But, I DO KNOW that the "graf" made water pumps can potentially have problems ... I had one with a loose bearing right out of the box. There should be no play. Because when this one disintegrates, you are SOL. A couple of more that I would add quickly... 1) oil pump nut 2) rear diff bolt 3) guibo .... etc...etc...etc.... |
#31
At the track this weekend, the bolt at the bottom end of the left rear shock came out. On the sticky shifting, I used to experience the same thing on my '95, especially when it was cold, but was much better when I depressed the clutch pedal all the way.
#32
If you are tracking your car -- I would definitely take a look at the rear control arms. Wait, why are you even asking me Scott? You know more probably than I do. Mine completely broke on me while I was on the highway. Come to find out, this is not an uncommon failure if you auto-x or track the car.
The best I could suggest which you might not do is taking some UV dye and adding it to your coolant AND to your oil before going on the track which should show you ANY pinhole leaks not really detectable by visual inspection. This can definitely be invaluable to prevent catastrophic failure. You need to be on the east coast so I can purchase that S54 from you ...good luck with your sale! Last edited by jderry; 08-05-2003 at 03:35 PM. |
#33
What do you use to look for the UV dye - a black light or something? If you'd really like that S54 M Roady, don't let some distance discourage you - we could negotiate including shipping in the price HACk took some nice shots at Laguna Seca
#34
Common maintenance issues
I don't know if it was posted before but I think this could be useful:
US E36 M3 FAQ
The subsystem beeps and flashes on loss of oil pressure, and also warns you if the oil switch doesn't close when the engine is stopped. |
#36
#37
My car is quiet enough that the constant pinging of the chime is a strong enough clue. |
#38
#39
Maintenance Issues: M3
Hi,
Thanks for this forum, it certainly helps on stuff to be aware of. Some problems that i experienced are as follows: 1. Climate Control display - apparently these are problematic on all E36's (mine was intermittently going on/off at 100 000km - not sure how many miles this is...) 2. SideShaft/Wheel bearing - i seem to be getting a constant humming sound from LR wheel - BMW has changed out the side-shaft twice, the wheel bearing but the problem still persists - took it in again today- hopefully it gets sorted out as my warranty is up! 3. A question for you guys, has anyone got the problem with the car just switching off for no reason? It seems like when the oil temp reaches 100 deg C, the car switches off on slowing down. Its starts first time when restarted but its bloody embarrassing! Cheers, i will check back soon. Mampara from South Africa... |
#40
The bottom bolt hole for the rear shocks can strip out, especially if you take it out and put it back in often enough when doing brakes. I had one that it seemed like it threaded in, but just wouldn't torque tight.
Requires a perma-coil or Time-Sert to fix.
#41
The front strut towers on the early years (before they introduced a reinforcement ring) can begin tearing if not using a strut brace - it's a similar problem to the rear shock mount towers.
In group 31, upper front suspension, there is a part #15 for later years (I think 97 and up) that will work on all of them. It's about a $5 part each.
facebook.com/sctsracing 02 M3 SMG Coupe - prepared class BMW Club racer 08 135i 6sp - stock class BMW Club racer Photo gallery Last edited by scottn2retro; 10-06-2004 at 12:43 PM. |
#42
on the e36:
the car' ECU is right bellow a rainwater drain area. If this drain gets plugged with debris, twigs, leaves or other crap; it can overflow the drain water onto the computer. This is BAD. My puter had a nice layer of corrosion on the PCB board because of this. My car would not run after a simple carwash, often leaving me stranded. To fix this, you can remove the rubber constrictor at the bottom of the drain area near the ECU (looks like a black rubber thumb). This removal allows the rainwater to flow unrestricted to the bottom of the car, instead of overflowing onto the ECU computer.
'94 325is, '03 M3 Vert, '86 M35a2 |
#43
One other thing that's a problem on all e36s... The taillight housing.
More specifically, the brake light bulb contact (sheet metal part in the tail light assembly) makes weak contact on the brake light bulb receptacle. This causes high resistance between the bulb and the housing, which leads to high heat, which leads to the metal contact burning through. This causes a brake light to fail and requires replacement of the entire tail light assembly to properly fix. I just took mine apart and man handled the metal contact so a new/clean/un-burned portion of it contacts the brake light housing. I also cleaned and electrically lubricated the crap out of it, so we'll see how long it works. |
#44
http://www.macadamizer.com/bmwfix.html |
#45
I've been thinking about getting an M for some time but with all these "Common Problems" I may get something else.
Oh and What's up I'm new here! |
#46
This thread is very good but has gotten a bit out of control.
We need to differentiate between common failures (things that are likely to happen if not checked/replaced) and failed once (misfortune breakages that have occurred to only one person or so), and there are many many posts, some asking questions, some suggesting things (like this one), others explaining what has broken for them, and others confirming another post, and all these post are responses all over the threads (multiple subthreads within the main thread) So with all that said, as a suggestion, is there a way to create a poll that lists the majority of things that break and where you are allowed check off what has broken for you? Then have some primary page tally up the overall totals for each area in question. This will show what really breaks frequently vs what broke once for one or two people... Just a thought T
Tony E 2005/330Ci/ZHP/ZPP/Leather/Xenon/Weather 1993/318i/5sp/H&R/Bilstein/17"/ShortShift/JimC chip /Xbrace/StrutBrace/Scroths
#48
Brake Light Circut Failure
Oxygen Sensors Failures Sticky shifting, I have a 1968 RS Camaro that shifts very smooth compared to the M3 |
#49
This many responses makes it look like the E36 M3 has too many problems to cope with! A proper list needs to be made, preferably by someone who knows a lot about these faults and could put them in the right place. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
