Old 01-19-2011, 08:05 PM
dbirdez dbirdez is offline
Mein Auto: 528i
Thanks for the write up Kraft!!!!! I used to repair circuitry on tdd's (telephone device for deaf) and was hesitant to "cut" out the resin or what ever that is so I took 2 small paint brushes , made a chisel end on one and sharpend the other in the pencil sharpener.
I still used the heat gun like you mentioned , but now I could kindof gouge out the resin w the chisel end and fine tune w the pointed one and not worry about scratching the printed board.
I am in the process of finishing it so hopefully it works .
Tlhanks again
Old 01-19-2011, 08:51 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Would love to see pics of the problem and results.
Old 01-26-2011, 04:15 PM
bluebee's Avatar
Today Mark at EACtuning and Pleiades and I were revisiting the right brand of FSU:
- Fourth FSU in two years
Rather than rehash that guy's problem (like buying from Ebay & buying used), do we yet have a good listing of which FSU manufacturer is the one to get for our E39s?
Here's the summary from back in August in post #69 of this thread:
Recommended:
- Sitronic/Bosch
Not recommended:
- GKR
- Behr
- Valeo,
- Siemens
Certainly not recommended:
- Meyle
- Hella
- Uro
- Denso
- Power Pro
Is this the final summary for recommended reliable replacement FSUs ?
Note: Below is the EAC Tuning replacement (I presume it's made by Sitronics based on what I can see of the label).
Old 01-28-2011, 06:52 PM
bluebee's Avatar
As a cross reference, over here, where a new FSR wasn't working:
- New FSR not working
... are interesting pictures of a Chinese-made Behr/Hella FSR.
Notice how badly the sticker is placed on the FSU. That's unusual (so far).
ID:	264276   Click image for larger version
ID:	264277   Click image for larger version
ID:	264278   Click image for larger version
ID:	264279   Click image for larger version
Old 02-18-2011, 03:23 PM
bluebee's Avatar
Over in the E46 side of the house, they're struggling with a procedure for testing the FSUs.
- How to check blower motor resistor
I'm surprised, with all these extra FSUs floating around, that more autopsies haven't been performed.
I guess not everyone is curious?
ID:	266980   Click image for larger version
Old 03-21-2011, 12:18 PM
bluebee's Avatar
This thread is probably the best thread for explaining which FSR to buy and which NOT to buy ... but ... the information is buried half way down ... and the title of this thread doesn't imply that it covers the brand to buy.
So ...
To refer others to it in the future, I just now opened a new thread (of course, pointing to this thread) that 'does' ask the question point blank:
- What is the right brand of FSU (aka FSR) final stage resistor/unit to buy for the E39
Please post brand PICTURES to that thread so that we may refer others to it (since the question seems to pop up frequently). The pictures you post should show the brand information (as FSU branding is a complex mix of marketing agreements that I, for one, cannot fathom).
Old 04-02-2011, 07:43 PM
yoshi900 yoshi900 is offline
Mein Auto: 03 540iA
Another FSU fixed by digging out the epoxy.
picture of the FSU.
also picture of the pinout on the connector side.
ID:	272913   Click image for larger version
Old 04-02-2011, 08:20 PM
bluebee's Avatar
I must apologize for asking ... but ... I'm still a bit confused about how the reputed 'fix' supposedly works.
From the original post:
the 928 was known to have terminal ECU failures due to resin which retracts while getting old with the result of breaking hybrid circuits and removing soldering from some cms components from mainboard.
Bmw seems to have same issues
OK. I get that the 'resin' is 'contracting' and, in doing so, it's pulling components off the board ...
But, what I don't get is how just removing the resin "fixes" the FSU. I mean, it's not putting the components back on the board, is it? It's not resoldering any broken solder connections, is it?
I don't get it. How does just removing the resin, 'fix' the FSU?
Old 04-11-2011, 12:41 PM
Mein Auto: 03 540iA
Update on FSU "fix".
after a week, the FSU was acting up again. first few minutes after starting the car, fan was blowing a bit erratic. fan speed was pretty slow then suddenly came back and back to normal. then it was working normal for the rest of the day.
so the "fix" is temporary and I'll be ordering a new one soon. can't afford to have it fail when summer comes around.
Old 05-03-2011, 08:37 PM
bluebee's Avatar
What brand did you order?
BTW, today another FSU/FSR failed in less than a year:
- E39 (1997 - 2003) > FSU vs FSR difference and symptoms?
So I asked the OP of that thread to post a picture of the label of the failed FSU/FSR so that we can anecdotally add yet another vote against whatever brand it was.
For the record, I also provided these related threads from the bestlinks:
- What is the right brand of BMW E39 FSU (aka FSR) to purchase (1) (2) when your interior heating & air conditioning HVAC/IHKA blower motor goes haywire (1) (2) (3) (4) (5) (6) (7) (8) & how to repair your own final stage resistor including an autopsy & wiring diagram schematic (1) (2) and why a bad final stage unit will cause the battery to drain overnight (1) (2) (3) & how to isolate and replace the E39 blower motor (1) (2) (3) (4) (5) & how not to replace the FSU (1)
Old 06-17-2011, 10:32 PM
mtbokc mtbokc is offline
Mein Auto: 2001 BMW 540i - Sport
WOW…Unbelievable!!!
I carved out just like you said and were back to a 100%. I signed up here for the first time just looking for some help with my A/C and found your post. Thanks a million kraft. Do you know if those who tried your repair job (including yourself) started having problems again later and also what would happen if I didn’t refill the space with a silicon paste and just left it empty? (anybody?) Thanks again kraft, great post!
Old 06-25-2011, 08:31 PM
ill_kuma's Avatar
ill_kuma ill_kuma is offline
Mein Auto: 2001 530i
My fan motor stop running yesterday and was about to purchase a new FSU unit last night but decided to check out here first. After reading this thread I was excited to try it and very skeptical. I did it today while I as at my friends BBQ and they all thought I was wasting my time. We were so amazed when it worked! Thanks kraft!
No one ever mentioned what kind of silicone they used. I was not sure of what to use so I just left it like that and plugged it in. Is it bad to leave it like that? I will fill it in with silicone when you guys let me know which brand and type to use. Also, how long will this method work before actually having to replace the FSU unit?
Old 06-27-2011, 11:06 AM
bluebee's Avatar
Originally Posted by edjack View Post
it's also potted with silicone
For the record, the previous repair refers to this ill_kuma successful repair using the Kraft method:
- E39 (1997 - 2003) > Repaired my FSU unit
Old 07-09-2011, 04:00 AM
Dennis Hon Dennis Hon is offline
Mein Auto: E39 E34
Help
Originally Posted by bluebee View Post
cn90 posted some useful information here about what some of the FSU pins actually do and how to test 'em ...
Also kraft apparently FIXED his FSU by gouging out the resin, resoldering connections, and then filling the holes with silicone!
Thank you guys for these information...
My Bimmer is a 1997 E39 528I
My unit is different (see pic). There is a protective casing to cover the circuits, the epoksi does not stick to the Circuits. I tried to press in the chips and others but doesnt work. Can anyone help or share?.
Old 07-13-2011, 09:12 AM
bluebee's Avatar
For the record, we're making some progress on the question:
Old 07-13-2011, 12:55 PM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
Can someone post the fuse # for the blower motor, por favor?
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 07-29-2011, 09:12 AM
bluebee's Avatar
I don't know which fuse it is but I would think the fuse number would be in one of these canonical FSU threads from the bestlinks:
- What is the canonical thread on the BMW E39 FSU/FSR/Blower Motor Resistor (1) and what is the right brand FSR to purchase (1) (2) when your interior heating & air conditioning HVAC/IHKA blower motor goes haywire (1) (2) (3) (4) (5) (6) (7) (8) & how to repair your own final stage resistor including an autopsy & wiring diagram schematic (1) (2) and why a bad final stage unit will cause the battery to drain overnight (1) (2) (3) & how to isolate and replace the E39 blower motor (1) (2) (3) (4) (5) & how not to replace the FSU (1)
Regarding repairing the FSU, which is the topic of this thread by Kraft, Tema, today, left me a PM pointing out yet another FSU thread on a different web site where at least two users repaired their FSU by reflowing the solder:
- Final Stage Resistor resoldering fix DIY
If you find that your blower motor is pulsing or randomly coming on after your vehicle is turned off, this may be your answer. If your blower motor is on full all the time, this fix may not work as the semiconductors may be shorted at this point.
Remove the FSR from your vehicle. Carefully remove the potting material in the corner shown. Go slowly because you don't want to damage the circuit board below. The potting material is soft so this process is relatively easy.
You will see two sets of three legs when you have successfully removed this material. To see the board and these pins easier, you may want to put some contact cleaner on the end of a Q-Tip and wipe the board to remove access "small bits" of loose potting material.
In most cases, the solder will be broken around these pins connecting to the circuit board causing erratic operation
, "blower motor doing it's own thing."
Carefully resolder these pins.
Make sure you don't bridge any pins with solder. If you do bridge the pins, remove the access solder and try again. Run a small jewelers screw driver between the pins to make sure there are no solder bridges. Once this is done, you are ready to try it.
You can see my FSR below. This is what I have done and it now works great. You will see some larger solder connections, I have done this to prevent future problems.
A second person posted saying they fixed theirs the same way.
My fan quit today so I pulled that bastard out, re-flowed the solder joints and its working again.
ID:	287035   Click image for larger version
Old 08-14-2011, 08:27 AM
steveo1729 steveo1729 is offline
Mein Auto: E39 525i
FSU Fixed
Thanks Blubee, great post! Symptoms on my E39 were the blower became intermittent about a week ago and then stopped completely. All A/C panel lights and interface work as normal, just no blower. Your fix worked like a charm, I did open all of the black potting compound but re-soldered the 6 pins as in your pic. Tested it just hanging loose and blower worked! I filled the cavity with regular silicone sealant, let it cure and then re-installed. HVAC is now fully operational and I've saved the $75 from NAPA or $150 from the dealer. I'll post again if the issue comes back. Thanks again!
Old 12-24-2011, 11:08 AM
CompactWRC CompactWRC is offline
Mein Auto: BMW Compact
Hello, I have a problem.
I tried to repare my final resistor unit and made a mistake removing the gum and broke a "capacitor" (I´m not sure). How can I do know? I dont know the capacity or if really was a capacitor.
My car is a BMW 320 td compact (2003)
Sorry for my english.
Between the both pins my multimeters find a diode.
Old 12-25-2011, 07:43 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
just by a new one from your /bmw dealer, only safe way to fix it.
Old 12-25-2011, 07:53 AM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Interesting, repair the fsu or clean it up rather than replace it.
Cost of the fsu is not high, but if you can consistently repair them and you have the time .... why not?
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Old 12-25-2011, 12:07 PM
I saw the images in the page 4 of the circuit whitout covert gum and definitely it is a capacitor but I need the capacity:
The other thing that I want to know is how the circuit works?
I measure the volts in the connector:
1) + battery
2) - Ground
3) + fan
4) - fan
5) 2-8 V according to velocity roulette selectión
I undestand that the roulette potenciometer send the variable voltage to the microcontroler that makes an A/D conversión and consecuently acts, whit a PWM exit, in the MOSFET that controls the fan but, and the second MOSFET?
greetings
Old 12-26-2011, 10:31 AM
last update
I simulate externaly the functioning of the module putting 12 V in suply pins and a variable signal (0-8 V) in the control pin (A/C module) and the exit pins (fan pins) works perfectly varying between 0 and 12 V but when I connect the module in the car it doesn´t work.
I test the fuses and all are ok.
I don´t understand.
Old 12-29-2011, 02:48 AM
olivier577 olivier577 is offline
Mein Auto: E39 2002 530d
Hi I'm about to open my 2002 original FSU also, to repair it or at least to try ...
for the 1st mosfet I was thinking it was the switch from 0v to -motor and the 2nd mosfet the switch from +12V to +motor
Do you know what are the 2 big bridges on the board ?
Old 12-29-2011, 09:07 AM
It´s not possible because emisor pins and colector pins of the mosfets are connected among themselves.
The configuration you mentioned is used in a foward/reverse system whit 4 transistors in "H" but it will works bad whit PWM exits because desynch between transistors.
I think the bridges are only conections betweens pins over the PCB tracks (probably for a bad initial desing)
