Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 03-01-2002, 10:13 AM
Scotes's Avatar
Scotes Scotes is offline
Send a message via AIM to Scotes
Mein Auto: '03 M5
Question 325Ci Coupe tire pressure ques. - DJ not right
OK, I did a search and couldn't find an answer to this - I went out to check my tire pressure this morning since I've got a bit of a drive to Palm Springs this afternoon for work. My '01 325Ci has the SP so I've got 225/45/ZR17 Dunlop SP Sport 2000s all around and the door jamb tire pressure gauge doesn't accomodate for this.
ie.
for 225/45/R17s all around it's 33F 38R
for 225/45/ZR17 in front it expects you to have 245/40/ZR17s in back and 30F 35R
I set it to 30F 35R this morning and around a turn I usually hit on my way to work (National towards Motor from the eastbound exit of the 10 for those familiar with L.A.) I tapped the gas and felt the back end jump out a little and loose traction (though my DSC light didn't flash). This has never happened while I was running 30F and 30R.
Any thoughts? Who else has an '01 325Ci with the SP and 225/45/ZR17s all around and what are you running at?
Thanks for the help!
'03 M5 Carbon Black
Incoming: 2016 340i Estoril Blue
Stolen, recovered, auctioned: '03 530i 5sp Sterling Gray, SP, PP, modified CDV, Dinan rear sway, retrofitted NAV
"A democracy is a sheep and two wolves deciding on what to have for lunch. Freedom is a well armed sheep contesting the results of the decision." - Benjamin Franklin
Old 03-01-2002, 01:13 PM
geomax geomax is offline
Mein Auto: 335i
I run 32F/35R, and the rear has always stayed planted, even at very high speeds/corners. I find that 32/35 has a nice medium between a little comfort, and control.
..but I'm also not a fan of Dunlops. That could be your problem right there....the 2000E's suck
Old 03-01-2002, 02:14 PM
in_d_haus in_d_haus is offline
Mein Auto: car
I find your pressure settings confusing. A higher pressure rear than front promotes understeer. These cars already understeer bad from the factory.
I use the same (32) all around on the street and add 2 psi to the fronts to bring in a bit of oversteer.
I'm runnimg the SP on street and track and I have the sport suspension.
Haus
Similar Threads
Tire Pressure Monitoring System jaspar 1M & M2 6 05-14-2003 08:05 PM
Tire pressure question Terry Kennedy General BMW Questions 16 01-19-2003 04:18 PM
Tire pressure - Anyone know why the 2003 has different tire pressure then my 2001 AF 3 Series & 4 Series 21 11-15-2002 08:32 AM
Tire Pressure Gauges - Article by consumer reports. JSJAMALA 3 Series & 4 Series 0 07-20-2002 11:24 PM
What tire pressure to use? Nat Brown 3 Series & 4 Series 55 04-22-2002 08:48 PM
