Bumped into this post on e46fanatics.com yesterday. Looks like 06SMGCabrio is getting a new motor because his VANOS failed immediately after Inspection II. There are hints at the fact that a lot of the VANOS failures on S54 M3s have been past Inspection II.
http://forum.e46fanatics.com/showthread.php?t=603639&page=4
Since our cars are still low in mileage, I though this would be something to keep in mind when bringing your Z4M to a dealer for Inspection II where they open up the valve cover and expose the VANOS for valve shimming etc.
Looks like a very sensitive solenoid can cause catastrophic failure of the VANOS and potentially send metal shards into the cylinders.
Not to be all negative, I also found this thread where Tonester has done some preventative maintenance on the VANOS. This sounds reasonable to do after about 10K miles, methinks to cleanout all the break-in metal from the unit filter.
http://www.m3forum.net/m3forum/showthread.php?t=225780
