Old 09-14-2008, 09:48 AM
Est1974's Avatar
Est1974 Est1974 is offline
Mein Auto: 1999 E39 Touring
HELP! Driver's side door panel removal question
I am stumped on the driver door panel removal.
have searched threads with no luck
How does the panel seperate from door at the top edge by the window? I have the clips detatched, the inner door release is through the panel etc. But the black frame that houses the speaker etc seems to be holding the panel to the door?
Dont want to go further until i have clear direction
thanks
[SIGPIC] "yoda is my co pilot"
87' 318, 91' 525i, 95' 325iA (SOLD), 95' 318iA 96 M3 Sedan (Sold), 97 528i Sedan, 99' M5, 00 740iL, 00 323i wagon:
Current 99 528iT
Old 09-14-2008, 10:22 AM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
There are two screws that need to be removed from the front door panel as well as the clips--the screw under the little plastic cover beneath the inside door handle, and an additional screw on the inside of the door, accessible when you open the door up--if I recall correctly, you should see a screw in or near where the air duct is located, where the air blows from your console into the air duct of the door. Hope this helps! There is also a row of metal clips on the top of the panel, which are different than the plastic clips surrounding the rest of the door panel.
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 09-14-2008, 11:40 AM
Chris525i Chris525i is offline
Mein Auto: 01 525i & 99 SLK230
E39 Door Removal
Fyi. . . this series of video on YouTube is very helpful. . . you may want to check them out.
It's by Bavarian Soundwerks ("bavsound"), and I was able to take the doors apart without any problem.
Good Luck !
Chris525i
http://www.Cars18.com
2001 BMW 525i (E39)
1999 Mercedes-Benz SLK230 Kompressor Sport (R170)
Old 09-15-2008, 01:57 PM
weasel like's Avatar
weasel like weasel like is offline
Technical Graphite > ALL
Mein Auto: E39 528i 5-speed
2 screws to be removed - under door handle and in vent, seen when door is open. Start popping the door away from the panel with your fingers from a corner. Be gentle, don't push on the tweeter grill. Pop all around and it will come loose. Don't worry, even IF you break a connector, they are easy to replace, and are made to pop in and out. Be mindful of the wires connecting your controls, lights, and other electronics. Also be mindful of the door handle and don't pull it out of the track or your door won't operate corectly when you reinstall the panel.
Rules to live by:
- Fast, reliable, cheap. You can only have two.
- BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one.
Old 09-25-2010, 02:35 PM
bigal540i bigal540i is offline
Mein Auto: 540I 2003, 328i 1998
I know this one is old, but outstanding job, save me time and money. thanks
Old 09-25-2010, 04:03 PM
BMR01530 BMR01530 is offline
Mein Auto: 2001 530i
Wow that is a great video.. just my speed. Are there more topics done this way?
Old 09-25-2010, 05:00 PM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
This forum is a virtual library of how-to's.
