Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series
3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 06-05-2003, 10:00 PM
CtrlAltDel CtrlAltDel is offline
www.piratecove.org
Send a message via ICQ to CtrlAltDel
Mein Auto: 2000 323i - manual
Exclamation Moonroof Issue...
I posted this at fanatics and someone suggested some people over here might be able to help.
No it's not the 'cover got stuck' issue.
This is one dealing with the control of it.
All the one touch settings are set for the moonroof's button, open/close/raise, etc.
Now the issue arises when I go to close the moonroof from the fully opened position.
I press the button forward until it clicks and the roof starts moving into the close position, gets 3/4 of the way, stops and goes to half way. If i push the button again, it goes to 3/4 and back to half, if I hit it again it goes all the way closed.
Same thing happens if i try and close it from the outside with the key, sometimes it will take the three times for it to close all the way.
WTH is going on here?!
Old 06-05-2003, 10:49 PM
Terry Kennedy's Avatar
Terry Kennedy Terry Kennedy is offline
There and back again
Mein Auto: 2003 325xiT, 2006 Atom
Re: Moonroof Issue...
Your roof controller may have forgotten its configuration memory. Try this procedure and if that doesn't work, take the car to your dealer.
Old 06-06-2003, 12:00 AM
Patrick330i's Avatar
Patrick330i Patrick330i is offline
Mein Auto: 2003 OB 330i
Something similar like this happened to me the other day x2, but it hasn't happened since. It was really kind of strange. Terry, thanks for the link.
Old 06-06-2003, 04:31 AM
www.piratecove.org
thank you for the link, i'll try this today!
Old 06-06-2003, 04:48 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Controler
Same thing happen on my 99 323i. THe dealer put in a new controler mechanism.
Good Luck
vern
Old 06-06-2003, 06:18 AM
www.piratecove.org
thx
i'm going to try that procedure again tonight and try cleaning the rails some and see what happens.
Old 06-06-2003, 06:43 AM
www.piratecove.org
my next question would be if there is a TSB on this, and if so, how could I find the number. I just broke the 50k barrier on my car so the manuf. warranty is out and im into CPO territory. So if there is a tsb that would get this replaced for free, that would be nice.
Old 06-06-2003, 10:19 AM
Beats me - I just found this when I was installing the M steering wheel and followed the chain of "stuff you have to do first" - it was all the way down in the "after you reconnect the battery" list.
Old 06-06-2003, 10:21 AM
www.piratecove.org
540700 DEC 00 Sunroof - Intermittently Inoperative
540701 DEC 01 Sunroof - Revised Initialization Procedures
thx guys!
I'll call the dealer and schedule a time to come in after i get back from vacation.
someone at fanatics pointed me to
http://www.alldata.com/
