what's making this engine noise? (E30 content) - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 09-15-2008, 12:28 PM
stevehecht's Avatar
stevehecht stevehecht is offline
Mein Auto: 2014 328d;1990 325i coupe
Problem: My engine (~130K miles) started making clacking noises about two months ago that increases with rpms. They get WORSE when the engine warms up. The noise is not a deep thud/clunk but a rat-tat-tat clacking. One import shop adjusted my valves and told me that sludge had blocked the oil spraying onto the cam and rocker arms. They put some sludge remover into the oil and told me to drive it 1K miles and then they'd do an oil change and that would clear up the noise. The noise only got louder after 150 miles so I had it towed to my BMW guy, who just listened to it and said it was a blown piston/bearing and the noise was piston slap. He recommended replacing the engine.
EXCEPT that piston slap and worn bearings are supposed to make clunking noises not clacking noises, and they're supposed to decrease (not increase) as the engine warms up. Does piston failure sound right or should I get a third opinion? What else could it be? This sucks.
Old 09-15-2008, 01:10 PM
pporcaro pporcaro is offline
Mein Auto: '86 325e
could be a valve tick....
did they adjust the lifters when they adjusted the valves?
Old 09-15-2008, 01:17 PM
E30bimmer E30bimmer is offline
Mein Auto: 86 325e, 95 m3
well first off, does ur car feel like it is losing alot of power, cause then it could possibly be a blown piston. You probably have a bad valve or a few bad valves. Valve ticking is very common in e30s, but it shouldnt be exremely noisy and it shouldnt get increasingly or decreasingly worse with engine warm up
Old 09-15-2008, 02:46 PM
stevehecht's Avatar
No, it's not apparent that I've lost a lot of power. I don't know if the first guys adjusted the lifters too, but I'll ask tomorrow. But believe me, this sound is not a "tick-tick-tick" it's a very LOUD 'RATTITY-RAT-RAT-TAT', like when a moving fan runs against a piece of paper. But what hangs me up is that the sound is not at all deep and clunky. The PelicanParts.com website says this about piston slap:
It is a dull-thud clunk that can be heard every two rotations of the crankshaft. Piston slap is most commonly heard when the engine is warming up, before the piston to bore clearances have decreased due to the pistons expanding.
As far as I know worn bearings sound about the same.
Old 09-15-2008, 02:52 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Location, location, location.
If you can isloate the area from where the noise is coming from you can pretty much determine the cause.
Old 09-15-2008, 03:47 PM
you said it sounds like a fan hitting something. did u check to see if something is rubbing up against the fan or something else
Old 09-15-2008, 03:56 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
H2O pump or alternator. I've heard both make a similar sound.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 09-15-2008, 04:21 PM
stevehecht's Avatar
Yeah, except I'm talking LOUD here--like a clanging clatter, not a small sound.
Old 09-15-2008, 04:36 PM
Rather Large Member
Bad bearings will make significant noise. But I'm not sure what you mean by loud. Like louder than the exhaust at speed, or louder than the valves at idle. Methinks we need a vid here.
Old 09-15-2008, 04:57 PM
cliffmac cliffmac is offline
Banned
Mein Auto: 325ic
I would consider re-adjusting the valves
if the shop is not specializing in BMW they could have not got it right the first time, it is not unusual to have to take a couple shots at the valve adjustment process. sometimes they just miss the adjust or don't retighten the nut enough and they come loose again and the lash goes....good luck....cliff
Old 09-15-2008, 05:04 PM
faviolosky faviolosky is offline
registered bimmer user
Mein Auto: 325e 1987
have u tried the fan hitting the distributor cap, when the engine is warmer the fan turns faster explaining why it increases when warmer engine, at higher rpms the fan is turning faster, which also explains it, that is happening to my far, but less intense so i keep the car at low rpms
Old 09-15-2008, 05:43 PM
Banned
Mein Auto: 325ic
also as mentioned
make sure the fan is not wobbling and that the top radiator hose is securely pulled back to the valve cover side, any of these things could cause what you say...I'd have to actually look at it to determine the actual cause, but if it's that noticable it can't be that hard to figure out...might be expensive to repair but the diagnosis can't be that hard....just get in there and look....good luck...cliff
Old 09-15-2008, 06:19 PM
Rather Large Member
I don't see how the fan could be hitting the dist cap. The diameter isn't big enough. Sounds like the cowl is loose maybe.
Old 09-15-2008, 06:26 PM
the diameter IS big enough
Old 09-15-2008, 06:37 PM
Rather Large Member
Yes you are right. That was me having a brain fart. I mean to say that the fan shouldn't be thick enough to make contact, if that makes sense. When you did the new clutch did you make sure that the fan was sitting on the correct side of the clutch? If incorrectly assembled it could make the plastic fan sit closer to the block.
Old 09-15-2008, 06:40 PM
Banned
Mein Auto: 325ic
the fan clutch works the other way around
it (fan clutch), when the engine coolant is hot, makes the fan spin faster at low rpm and slows down as the rpm gathers...that's the point of the clutch....while idling at 650 rpm the fan needs to spin faster than at 3500 rpm....it's the point of the fan clutch ...cliff
Old 09-15-2008, 06:45 PM
Banned
Mein Auto: 325ic
did I just see this? do you know what that represents? my goodness...just trying to help...cliff
Old 09-19-2008, 06:14 PM
d970813 d970813 is offline
Mein Auto: 2004 330xi
Similar noise E46 - 90,000Km
I think I have a similar problem with mine. I can't describe it as well in words, here's what the dealer's SA put: "grumbling/whinning noise. ... engine needs to be warm" (to hear the noise). The noise is quite annoying.
First time I took it in (few weeks ago) they changed the "tensioner pulley". According to them this fixed the problem. Five minutes later as I drove off, the noise came back. I was away for a couple of days so I couldn't take it back.
Today I had an inspection done and I pointed to the same problem. This time around the "P/S pump noise, grinding noise" is listed as the problem. They ordered it and I should have it fixed by next Thursday. It can't be the alternator because that one let me down a month ago so they put in a new one at that time.
I'm "lucky" with this being a "certified series" so I don't have to pay for these parts. The guys at the dealership are great too. And I don't know why, but I still love this car.
If anyone wants to hear the noise, I recorded it with my phone and put it here (you'll need QuickTime or Real Player):
http://cid-e8ab8d5920b3c5cc.skydrive...se.aspx/Public
