E34 (1989 - 1995)
Old 09-16-2008, 02:18 AM
bigman bigman is offline
Mein Auto: BMW 535I 1990
Exclamation windshield wiper hits the hood
hi guys
i have a BMW E34 535I 1990 and the wiper of the windshield is hitting the hood so the arm is getting eaten plus the hitting sound is annoying so please some help, appreciated.
thanks a lot
Old 09-16-2008, 08:56 AM
bimmer dot info bimmer dot info is offline
The Biggest P0st Whore!!
Mein Auto: 2008 MS3
Not much you can do about it.
There are some minor adjustments that you can make to the hood brackets by the fire wall. I've heard of a few people that bent the hood back up.
Old 09-16-2008, 10:09 AM
MeanM50 MeanM50 is offline
Mein Auto: E34/5
Pretty common. Out of 4 E34's I have had, they ALL did this. I have never figured out how to remedy this.
Old 09-20-2008, 10:47 AM
Reyes(E34) Reyes(E34) is offline
Mein Auto: 1991 535i
I was havign the same problem on my 535i. Just fixed it yesterday. There are brackets that when you put the hood down and push i closed, the hood slides into them.There is a bolt on side closest to the windshield and you losen that and then pull up on the whole bracket. and do that to both side. Hope that helps you out.
Old 09-20-2008, 03:16 PM
attack eagle attack eagle is offline
No more e34!
Mein Auto: Nikes + Mongoose
yeah or notch the wiper... or all three !!!
Still cruising after all of these years...
now on iOS 9 (saves gas)
Mutual Admiration Society
Member #5
Old 10-08-2008, 07:28 AM
simmro simmro is offline
Mein Auto: 520i
Hi,
have this problem on my 95 520i an older guy a retired mechanic has a similar car and he told me its the wiper linkages that are worn but I've not got round to trying to fix it yet.
Old 10-08-2008, 08:04 AM
Mein Auto: 2008 MS3
I dont see any way that it could be the linkage.
Old 10-09-2008, 03:34 AM
Mein Auto: 520i
If it's not the linkage and it wasn't like that from new then the bonnet (hood) is damaged. do you think?
Old 10-09-2008, 04:03 AM
Damian Hayes Damian Hayes is offline
Send a message via Yahoo to Damian Hayes
Mein Auto: E34 525ix, E46 316i
It is due to a warn linkage. The spindle that the wiper arm fixes to runs in a two part bronze bush. That bush gets warn and allows he spring that pushes the wiper blade onto the screen to push the arm up instead. If you push the arm away from the bonnet, you should find it moves down easily. I have read about a fix where you remove the linkage from the car. Take it apart and remove the two part bush and turn the two halves around so the worn ends are in the middle, then refit.
I am planning to try and see if this can be done with the linkage in situ', with just the spindle pushed out of its guide, and a puller I will make to suite the bush size. But I've not got round to any of it yet. And to make things worse, I've now lost the original site I found the info on
But I am sure someone on here must know of the site I saw this fix on?
Old 10-09-2008, 08:34 AM
Mein Auto: 2008 MS3
I havent seen the site or heard that explination before but it makes sense. I'll have to take a look at my car when I get a chance.
Old 10-23-2008, 08:48 PM
Jairo Jairo is offline
Mein Auto: 1995 525i Touring Wagon
I noticed the smae problem on a 1005 525i I just purchaced. I fixed this by removing the nut that holds the wiper arm to the shaft, lifting the arm off the spline shft and otating the arm away from the hood about 2 to 4 degrees adn reinstalling the arm. teh wiper blade is up further intot he winshiled while at rest, but it is nto hight enough to obscure visibility. I made sure it did nto traveled too much when the blade is all the way up adn before starts to move downward.
I am not sure if this the the right way to fix this but is working fine and is no longer eating away a the arm
