E46 (1999 - 2006)
Old 09-16-2008, 09:14 PM
mtrizzle06 mtrizzle06 is offline
Mein Auto: BMW
Car Doesn't Start.... Sometimes
For some reason, a couple of days ago, my car would not start sometimes. I would drive for about an hour, go to the store, and then come back and the car would have difficulty starting, but the everything else was on (A/C, radio, OBC). I did notice that I didn't hear the engine 'clicking' or attempting to start when it didn't start. After about 5 - 6 attempts of turning the ignition, the car finally started. Again, this happened to me the next day, except it took even longer to start (and I pushed down the gas). I changed the battery (which had been leaking acid) and the same problem did not occur at first, but looks to be happening again. Now, whenever I turn the ignition, there is a delay before the engine starts, if it does at all.
Does anybody have any idea what is wrong before I take it to the dealership?
The make is an 01, 325i with 97k miles.
Ads by Google
Old 09-16-2008, 10:03 PM
eleison eleison is offline
Mein Auto: 330i
Same thing happening to me (but I do have the "clicking"). Could it be the weather? In any case, I'm gong to change the fuel filter this weekend. Maybe that will help.
2001, 330i 120K miles
Old 09-16-2008, 10:05 PM
cjwheeling's Avatar
cjwheeling cjwheeling is offline
Need a Toyota?
Mein Auto: MBZ E500
Battery terminals not clean or on tight enough.
Old 09-16-2008, 10:21 PM
essi1553 essi1553 is offline
Mein Auto: 2001 330ci ZPP
Originally Posted by cjwheeling View Post
battery terminals not clean or tight enough.
+1
Old 09-17-2008, 12:47 AM
shointake shointake is offline
2001 bmw 330i SEX MACHINE
Mein Auto: 01 bmw 330i
Check the battery terminal cables like they said..
try turning it Upside down and see if that gets a better connection * i had to do this before *
just casue everything was on, doesnt mean ur battery has enough Power to start the Motor.. try turning everything off and seeing if the car turns on easier.. if it is, means ur battery is dying but since u got a new one.. check ur alternator.. its probably not charging the battery..
TEst: jump ur car with someone elses.. and see if it just turns on perfectly.. if it does.. charge ur battery for about 10-15 mins with theres.. Let it run for a BIT.. if it turns off/dies, its ur alternator.. But u can still see and fill the battery UP with water.. and see if that helps it charge.. if not.. NEW alternator Brother!
" Its like a Thousand Angels Dancing in my Mouth "
Old 09-17-2008, 10:01 AM
JamaicanBMW JamaicanBMW is offline
Mein Auto: bmw E46 325i
I also had this problem with my 01 325i, it was on and off all day monday but it hasn't happen since then.
and i changed my battery about 2wks prior. its a mystery!!!
Old 09-17-2008, 11:04 AM
phoenixreborn's Avatar
phoenixreborn phoenixreborn is offline
I'm an agent of chaos
Send a message via AIM to phoenixreborn
Mein Auto: '02 530i
Sounds like the battery or the battery terminals. Check that first. You might want to buy a jumper battery pack that can discern between a bad battery and a bad alternator(in this case is seems to be the former). I keep one in my trunk.
How can you move faster than possible, fight longer than possible without the most powerful impulse of the spirit: the fear of death
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
