E46 (1999 - 2006)
Old 09-17-2008, 08:32 AM
darkmanx1209 darkmanx1209 is offline
Mein Auto: BMW 330CI
Window Washer Fluid SLOWWWWW leak
Okay, so I have a washer fluid leak that I cannot find.
Here's what happens:
I fill the washer fluid tank - no leaks.
In one or two days after filling the tank, the washer fluid tank is empty again.
Does anyone know how much is costs around to fix this at either bimmer dealership or regular shop?
Old 09-17-2008, 08:35 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP & 04 Honda VFR
It's quite common for it to leak right around the pump (the pump is attached to the tank). A new pump includes the new seal and everything. Of course, you could use some epoxy or something and probably just fix it just as well. You just need to pull the tank out, which is very easy.
Old 09-18-2008, 06:40 AM
rhinom67 rhinom67 is offline
Mein Auto: 03 330CI
I just replaced the pump on mine. It was fairly easy, and there is a DIY with pics if you do the search. One thing I would do different, is get the BMW pump rather than saving a few bucks on a generic one because of splicing the wires due to the harness.
I believe the pump was under $20, I would probably just replace it.
Old 09-18-2008, 01:26 PM
sierrakilo99 sierrakilo99 is offline
Send a message via AIM to sierrakilo99
Mein Auto: 2001 325Ci/1989 Civic HB
I replaced the o-ring on mine and that fixed the leak.
Old 09-18-2008, 02:10 PM
lochness lochness is offline
Mein Auto: e46 M3 Dinan / e70 X5 35
Do you have headlight washers? On previous e46 there was small hole in the driver's side line that caused the same thing.
Old 09-18-2008, 02:32 PM
Starch Starch is offline
Mein Auto: 330xi
Links:
http://www.bimmerfest.com/forums/sho...d.php?t=114615
http://www.bimmerfest.com/forums/sho...d.php?t=180101
Old 09-18-2008, 02:58 PM
milobloom242's Avatar
milobloom242 milobloom242 is offline
gashlycrumb
Mein Auto: 325i
Very easy DIY, about 15-20 minutes if you work as slow as I do
