Old 09-18-2008, 10:07 AM
Blue Monk Blue Monk is offline
Mein Auto: 2004 X3
Is an AT flush possible?
My 04 2.5 X3 is at 61,000 miles. I spoke with my SA about having the AT flushed and he said it was not possible because it is a sealed unit. I've searched the board and if I'm not wrong, it can be done.
Also, the mileage counter flashes inspection upon startup. Does this mean that the oil needs to be changed too?
Old 09-18-2008, 10:10 AM
AzNMpower32's Avatar
Tar Heel Faithful
I think part of the AT unit is sealed (perhaps the torque converter), so that sealed part cannot be flushed. However, the rest of it can, and if the dealer refuses, then take it to an independent BMW shop.
If your Service Indicator flashes upon startup, then yes, you need to do Inspection II ASAP!
Old 09-18-2008, 10:29 AM
Mein Auto: 2004 X3
So the transmission definitely needs to be flushed at 60k?
Old 09-18-2008, 11:12 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
I've heard that ATF and diff fluid are lifetime fluids? But I might be wrong...
Old 09-18-2008, 01:02 PM
sunnyyan sunnyyan is offline
Mein Auto: 05' X3 3.0I/05' Honda S2k
that's what BMW claim, I personally will replace both tranny and diff fluid every 20k or 30k miles.
I'm little confused on diff fluid since I'm not sure how many diffs X3 has due to its all wheel drive system (front and rear diff?)
Old 09-18-2008, 02:15 PM
MPBX3 MPBX3 is offline
Mein Auto: 2004 X3
I think you're panicing here. Inspect II is nothing more than alot of checking this and checking that.
Old 09-18-2008, 02:26 PM
Tar Heel Faithful
Didn't mean to convey a sense of panic, rather mild urgency. I'm already one of those who think 15k intervals are too long.........but waiting 15k and then like, 2000mi on top of that......well.........its your car I guess.
I let my X3 run into the negatives but that's because I change the oil at 7,5k intervals.
Old 09-18-2008, 03:31 PM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Leaf Tekna
In addition to the transmission there is the front and rear differential plus the automatic transfer case. Be sure to use the correct fluids.
None of these are scheduled items. Brake fluid and coolant changes are on the schedules and are often overlooked.
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
Old 09-19-2008, 11:20 AM
Vodka G Vodka G is offline
Mein Auto: ??
the trans fluid is good for 100k miles the diff and X-drive trans case should be about 60k miles
20-30k seems to be wayyy tooo short......(i know that's what they used to recommend back in the 90s when they use non synthetic fluids) but nowadays almost all of the euro cars (audi, bmw mbz) uses synthetic fluids on tranny etc. and from my experience they will last 60k (under normal driving conditions ie no towing etc.)
i did replace my tans case and diff fluid at 60k but since is a PITA to do the tranny and the fact that you cant get the correct fluid besides from the stealership and you have to get like 25L of it which will cost like $250....i decided to wait till 100k miles (esp when my car is under BMW CPO and service manual dont call for it till 100k)
Now - '14 Volt -12' Audi A6 3.0T Prestige- '10 Porsche Boxster S
SUVs-'08 Acura RDX Tech -'04 BMW X3 3.0
2 doors -'01 Audi TT QC 6 spd -'01 Toyota MR-S - '06 BMW M Roadster -09' BMW M6
4 doors -'01 BMW 325i E46 -'96 MBZ C280 Sport -'12 VW Golf 2.5
no doors- 00' Suki GS500
Old 09-19-2008, 04:57 PM
---cant get the correct fluid besides from the stealership ---
Does anyone has any link/reference/info on fluid type/brand we should use in X3 tranny/diff? Thanks
Old 12-06-2012, 06:56 PM
mertensx3 mertensx3 is offline
Mein Auto: 2006 x3 3.0i
flush is possible
yes do flush it dont wait till 9ok, bg flush machine will to the jog with the proper fittings
Old 12-06-2012, 07:22 PM
chagrin chagrin is offline
Mein Auto: M3/X3/XI
Your recommendation is only about 4 years too late...
___________________________________________
BMWs currently in the garage: VF570 E46 M3, E46 XI Touring, E83 X3 "M" retrofit
Old 12-06-2012, 07:27 PM
awdrev awdrev is offline
Mein Auto: 2004 BMW X3 3.0 Auto Tran
Yea, I mean, what in the world just happened... and was he drunk?
Old 12-06-2012, 08:40 PM
x3brian x3brian is offline
Mein Auto: X3
Lmao! Good thread though!
Just in case this hits a google search:
Tranny is dexron vi
Differentials are 75w90
Transfer case is BMW xdrive fluid
There I did my part...lol...
Old 12-06-2012, 10:20 PM
Mein Auto: 2004 X3 2.5i
Originally Posted by x3brian View Post
Tranny is dexron iv
I'll fine tune that before I drink some fortified wine:
Tranny is Dexron VI (Why does GM confuse us with Roman numerals? Label it Dexron 6)
Differentials are synthetic 75w90
Transfer case is BMW xdrive fluid, Part No. 83 22 0 397 244
BMW specifies Castrol SAF-XO for the differentials which is apparently available in Canada (for about $47) but not in the U.S.
No indication that it is different from any other 100% synthetic 75W90 gear oil.
Originally spec'd. Shell or Esso fluid for the 5 spd. A/T may still also be available at a high price.
Is it better to use that over Dexron 6 in the 5 spd. transmission? Don't know.
Owners that have converted to Dexron 6 don't seem to report any problems.
Old 12-07-2012, 09:06 PM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
how much should I expect to pay at an indy to have my tranny done? I am only at 82k miles but I tow a light trailer some (about 1200 pounds) so I want to get it done!
Old 12-08-2012, 06:43 AM
Mein Auto: X3
Anywhere from $350 to $600 depending on labor rates and if you also change the filter.
Believe it or not my dealer only charges $350 for this. Since there is no dipstick this is about the only maintenance I do not do myself.
EDIT:
I forgot when I paid to have this done it was $416 at the dealer but it included transmission, both differentials and the transfer case. I did that at both 50k and 75k.
They didn't break out the labor for each desperately on the invoice only the fluid cost.
Old 12-08-2012, 06:56 AM
holy moly! thats alot! The Mercedes dealer only charged $275 for our CLK500's tranny flush/filter change, and they had a awesome (free) espresso bar too!
Old 12-08-2012, 02:00 PM
Mein Auto: X3
Yes, but I get a new BMW to drive for the day lol. That's worth a $100. . This is the last and only thing I do at the dealer.
Honestly I could do this myself for about $150 in fluid and filter in my garage. I have done it at least 100 times over the years. The issue is three fold why I haven't yet done it:
1) I need a high capacity fluid transfer pump. I only have a small one right now designed for low fluid apps like differential and transfer case. A good one is about $80 to $150.
2) I need a good instant read infrared digital thermometer to measure temps to make sure I filled it full enough...remember no dipstick to check after getting up to operating temp and you went through all gears and sport mode and back to park (5 seconds in each). Another $100 to $150 for a good one...granted second change both would have paid for itself.
3) I had the 100k mile maintenance plan and didn't want any flack from the dealer about not wanting to touch it at 100k miles even though it was recommended. So I paid at 50k and 75k when I was in for inspection 1/2 on BMWs dime. I also see value in using the same fluid each time because its darn near impossible to get a few quarts of fluid out of the torque converter.
I might just do it myself at 125k if the dealer will sell me 8 quarts of the dex 6 they used....heck at that point what's the harm....
