E30 (1982 - 1993)
Old 09-22-2008, 04:38 PM
josh84bmw318i josh84bmw318i is offline
Mein Auto: BMW 87 325
Question i heard.. is it true?
so i was lookin around on here the other day an someone said they put 19lb. injectors in their e30 an i found some online an it said i dont have to do anything to my engine if i get that is this true an what exactly will it do for me?
Old 09-22-2008, 06:50 PM
kamotors's Avatar
kamotors kamotors is offline
Mein Auto: 325i
yes 19lb injectors very goood, makes the car pull waaaay harder after 5000rpms, this mod should be combined with an M30 AFM, then the car will run bad for about 2-3 startups/drives, and then the ECU will fully adjust and the car will run amazing.(the stock ecu can adjust to injectors up to around 24lbs)
89 325i~~04 s60r~~88 635csi~~91 325ix-SOLD~~02 WRX-SOLD~~04 WRX-SOLD~~01 2.5RS W/h6-SOLD
Old 09-22-2008, 06:58 PM
Edev's Avatar
Edev Edev is offline
BMW Genius @ BMW Portland
Mein Auto: M Coupe
yeah im running 19lb injectors and i agree that it pulls way harder..but mine is after 4k rpms. where can i get a ahold of this M30 AFM kamotors? im assuming you have one on yours..so how bout some pictures
BMW Genius @BMWPortland.
2000 Z3 M Coupe
Old 09-22-2008, 07:09 PM
cliffmac cliffmac is offline
Banned
Mein Auto: 325ic
19 PSI is actually low right?
should be running around 29 to 35 or 36 PSI..good luck cliff
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
I also have 19# injectors...and it pulls really hard from 3500 to 5500
but that might also have to do with the turbo!
sorry i had to.
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 09-22-2008, 07:12 PM
Edev's Avatar
Mein Auto: M Coupe
sorry i had to.
haha UGH! how dare you!
it makes me want a turbo soo, soo badly
2000 Z3 M Coupe
Old 09-22-2008, 08:25 PM
kamotors's Avatar
Mein Auto: 325i
the M30 AFM has to have the part number ending in 027 and its plug and play. its around 3.125 outside diameter on each end so stretching of the intake boot will be needed and you have to run a conefilter(well, you dont have to if your creative.
I'm going to start running megasquirt so no more AFM for me. and then i want to supercharge the car,(i dont like how you have to run oil lines to the turbo).
Old 09-22-2008, 08:26 PM
kamotors's Avatar
Mein Auto: 325i
good luck with that
Old 09-22-2008, 08:27 PM
Edev's Avatar
Mein Auto: M Coupe
megasquirt. ive heard of it before, but never looked into it. what does it do?
SC..omg..it makes me drool
2000 Z3 M Coupe
Old 09-22-2008, 08:33 PM
kamotors's Avatar
Mein Auto: 325i
at first it seems super overwhelming, but then i realized you can just buy plug and play ones from r3v or e30tech, it controls fuel and spark, and eliminates the AFM so you can just run a piece of pipe in the AFMs place, theres tons of updates for it you can make it so you have traction control, it controls all you boosting needs, you can control fuel curves and what not,you just plug it into your lap top and tune away, only problem is that its expensive. i think i found a plug and play one for $400 that i'm going to buy as soon as i get the money.
Old 09-22-2008, 08:36 PM
Edev's Avatar
Mein Auto: M Coupe
whoa..400. you make it seem tempting. but with the 400 for ME, i could put it towards an o2 sensor, TOB, lowering springs, rear shock mounts..and i think thats it. haha.
2000 Z3 M Coupe
Old 09-22-2008, 08:41 PM
Sweet thanx for the advice guys guess ill order some then. An any ideas were i could get a chip for my ecu?
Old 09-23-2008, 03:48 AM
snake952 snake952 is offline
Mein Auto: BMW 318i 1990
what do u mean by 19lb injectors?
Old 09-23-2008, 07:12 AM
Edev's Avatar
Mein Auto: M Coupe
they're the injectors for your car. you have 6, well.you have a 4 cylinder so you have 4 of them. the bigger the # of lbs, the more fuel flow you'll get.
2000 Z3 M Coupe
Old 09-23-2008, 08:22 AM
adding on to this, the stock injectors on the 325i are 14#.
Old 09-23-2008, 03:33 PM
kamotors's Avatar
Mein Auto: 325i
i think i'll turbo my car and forget about megasquirt and supercharging, that TCD kit seems very tempting. it uses a turbo chip instead of megasquirt
http://www.turbochargingdynamics.com...Turbo_Kits.php
Old 09-23-2008, 03:55 PM
Edev's Avatar
Mein Auto: M Coupe
ahhhhh, i was going to say 14# but i wasnt 100% sure...
2000 Z3 M Coupe
Old 09-23-2008, 04:56 PM
prestige prestige is offline
Mein Auto: 88 bmw 325is
ok i have a theory
i have 19lbs fuel injectors but stock afm
so i did a little bit of research and i found out the the M20 afm has a spring adjustment control soooooooo
can i make it less resistant making the car run lean causing the ecu to add more fuel witch = more power
do you think that would work or should i leave it alone?
sorry about jacking the thread but i thought it was kinda relevant
-Stats
>19lbs injectors
>mark D chip
>kamotors CAI
>Zimmermann cross drilled rotors
>cool carbon pads
>Bilstein Sport shocks and Bavarian Autosport springs
>M30 AFM
>205/60 R14 tires
-Coming Soon
>25MM Brake MC
>Front Strut Brace
>IE sway bars
Old 09-23-2008, 07:45 PM
kamotors's Avatar
Mein Auto: 325i
Originally Posted by prestige View Post
ok i have a theory
i know that the AFM i have is adjusted by the previous owner of it, but i don't think you should mess with the spring, but i know for a fact that when me car is running rich(adapting to the AFM and injectors) it runs alot faster than it does when it is fully adapted and not running rich anymore.
Old 09-23-2008, 08:06 PM
Edev's Avatar
Mein Auto: M Coupe
ok i have a theory
i have the same as you, stock afm but 19lb injectors. interesting. if it works for you, let me know..i could always use a little more ummpf!
2000 Z3 M Coupe
Old 09-23-2008, 08:49 PM
I might try it tomorrow i was going to do it today but it was really hot outside and my engine was a million degrees
-Stats
>19lbs injectors
>mark D chip
>kamotors CAI
>cool carbon pads
>M30 AFM
>205/60 R14 tires
-Coming Soon
>25MM Brake MC
>Front Strut Brace
>IE sway bars
Old 09-23-2008, 08:53 PM
Edev's Avatar
Mein Auto: M Coupe
i know how that is. up here, its going to start raining for a good, idk..6 months or so lol. kind of a bummer because i cant work on the car outside, nor can i keep it clean
2000 Z3 M Coupe
