E30 (1982 - 1993)
Old 09-24-2008, 06:36 PM
mike2937 mike2937 is offline
Mein Auto: 89 325i
code 1222
hello all new 89 325i owner, i just got it knowing it has issues, the previous owner just had a head gasket put on and the guy that did it was a novice, anyway after the job was done its running pig rich, i am getting a code 1222 lambda.cant find any air leaks, i used the search button and came up with several causes, i am leaning toward the o2 sensor because antifreeze can foul a 02 sensor in a hurry,but the 02 code is 1221 and that code is not stored. the afm operates smooth with no tight spots and the coolant sensor is new, fuel pressure is a steady 38 psi. was wondering if the the timing belt was off a tooth would it have these symtoms because he metioned that the timing may be off,the car idles fine and reponds well to throttle but the raw hydrocarbons will bring tears to year eys, i am going behind someone elses work and trying to get some answers from this guy is a little difficult, any help is appriciated,
Old 09-24-2008, 06:43 PM
cliffmac cliffmac is offline
Banned
Mein Auto: 325ic
1221 is the O2 sensor
no question..clifmac
Old 09-24-2008, 06:48 PM
Banned
Mein Auto: 325ic
1222 is O2 sensor regulator code
once the O2 sensor is repaired the 1222 should go away....
Old 09-24-2008, 06:50 PM
kamotors's Avatar
kamotors kamotors is offline
Mein Auto: 325i
also if the car runs lean or rich for more than 10 seconds the code comes on,ex: if you run seafoam it will come on or adapt to a chip or injectors or AFM. reset the battery and see if it comes back, could of just been a one time deal.
89 325i~~04 s60r~~88 635csi~~91 325ix-SOLD~~02 WRX-SOLD~~04 WRX-SOLD~~01 2.5RS W/h6-SOLD
Old 09-24-2008, 06:53 PM
Banned
Mein Auto: 325ic
btw
how can antifreeze foul up an O2 sensor? just curious...cliffmac
Old 09-24-2008, 07:01 PM
Mein Auto: 89 325i
when a hg blows the burnt antifreeze gets into the sensor and kills it, not all the time but sometimes, i work on some older dodge turbo cars and they are famous for it.
Old 09-24-2008, 07:08 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
Fuel tank ran empty, Incorrect Fuel Pressure, Injector valve defective or coked, Engine Temperature Sensor defective, Secondary air leak, Fuel evaporation control system defective, Air Flow Meter defective and/or the combustion is being disturbed by mechanical failure
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 09-24-2008, 07:13 PM
Banned
Mein Auto: 325ic
so the head gasket is really the issue
of course, how plebian of me......the O2 sensor is just the observer of this problem...really...cliffmac
Old 09-24-2008, 07:16 PM
Banned
Mein Auto: 325ic
of course symtomatic of a major engine problem
there should of been other issues presented that a trained doctor would have diagonsed prior however....regardless...seriously...come on...good luck...cliffmac
