Fuel Pressure Regulator "fix" - lots more power - Page 3 - Bimmerfest - BMW Forums
Old 04-02-2010, 07:16 PM
dano670 dano670 is offline
Mein Auto: 97 M3, 65 Mustang FB
I wanted to thankyou for your write up. I had a blown HDG and after getting the engine together, I ended up with the exact sames codes. I had a spare O2 sensor, and swapped it out in 15 minutes and the car works perfect now.
Old 08-22-2012, 10:32 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
P1189 P1073 - I think was o2 sensor bank 2 precat not tight
Originally Posted by ztom View Post
My car's been running fine but then got a cel and found by obd tool the bank 2 pre-cat o2 went bad, now changed out and cel gone. I'm still losing coolant, maybe 1 qt in 1-2K miles, and I think maybe it's through the head gasket, causing the o2 sensor to go bad, but not sure. I'll update this post later, we'll see how it pans out. It could have been the previous o2 sensor wore out but we'll see. One thing of interest is the code for the cel was 1189 and 1073, suggesting maf, but the scan tool clearly showed bank 2 o2 sensor bad, yet there was no code thrown for bad o2.
Many years later & now I get 1189 $ 1073 again. I forgot I wrote this, looks like I may need a new o2 sensor bank 2 precat. Also since above I replaced the head. A coolant leak does indeed kill o2 sensors.
Update - I changed out the O2 sensor and found that it was not tightly screwed in. Not wiggly, just not tight. My 1189/1073 this time was intermittent, happened only at rev above 2500, more often when going up a hill. I'm thinking that unders such conditions it may have have more exhaust pressure and somehow allowed air into the system? I changed the O2 sensor out anyway, maybe also it was getting lazy in switching. Anyway it test drives ok and seems to have more power, let's see how it goes.
Old 08-23-2012, 08:28 AM
cn90 cn90 is offline
For those who want so replace Fuel Pressure Regulator, it is about $50-$60:
---> 06/1996: 13531729319
---> 09/1997: 13531436110
---> 1999+ models have FPR built into the Fuel Filter itself.
Old 08-23-2012, 08:29 AM
Anyway, for 1996-1998 models, in contrast to realoem diagram (which showed FPR next to the Fuel Rail, which is incorrect), the FPR is actually located next to the Fuel Filter, it is connected to the vacuum hose.
DIY:
https://www.bimmerfest.com/forums/sh....php?p=7028585
Photo of FPR:
Old 08-31-2012, 08:00 AM
SilverBlue SilverBlue is offline
SilverBlue
Mein Auto: 2007 X3
Early '97's are different
CN90,
My 6/96 production date 528i indeed has the fuel pressure regulator up in the engine compartment along the fuel rail. Underneath the car, I only have a fuel filter, not the 3/2 valve and FPR setup that's depicted in your photo.
Old 08-31-2012, 08:18 AM
Interesting,
So the BMW engineers moved the FPR down there later...
Old 04-30-2014, 10:44 PM
Aztecson Aztecson is offline
Mein Auto: 1997 Bmw 528i
How's it going. Did you fixed the problem? If so any tips?
Old 04-30-2014, 10:59 PM
Just seen the date. This one's old as he'll.
ccv, cps, fpr, maf, o2
