E46 (1999 - 2006)
Old 09-27-2008, 08:54 PM
josenar145 josenar145 is offline
Mein Auto: BMW 2002 E46 330ci
Thumbs down Broken oil plug
I was a little impatient this time while screwing my oil plug back in and paid the price. Now the bolt is resting on the bottom of my oil pan. I was woundering If it is possible to get the oil pan off the engine enough to slide my hand (or a magnet?) in to get it out. And if it is at all possible to do so without removing the suspension? also can I remove the oil pan and put it back without replacing the gasket?
One more question where can I find a oil plug for a 330ci around town on a Sunday? (Autozone?)
PLZZZZ Help!!!
Old 10-07-2010, 09:29 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Someone broke their oil drain plug today and he couldn't find any references on the topic, so I search for him (and found these which I'll post here as a cross reference).
Here is the search result for broken oil pan drain bolts:
- How not to change your oil in your E39 (stripped drain plug)
- Broke the plug....
- Oil Plug Stripped! Now What ??
- URGENT: engine oil drain plug broke
- Broken oil plug & Broken oil plug!
- I Literally Want to Cry....
- Broken Oil Plug 0n E39 1998
- Magnetic oil drain bolt broke in half
Here is the search result for stripped oil pan threads:
- Drain plug / oil pan stripped on 2.8 Z3
- oil plug bad
- '92 325i-- oil drail plug stripped HEEEELP!
- Oil pan stripped (use level sensor as a drain plug)
- Oil pan stripped (weld plate over hole)
Here is a good cn90 DIY on changing your oil the gravity feed way:
- DIY: E39 Changing engine oil made simple
And, read this BEFORE you select a vacuum extractor:
- DIY - BMW E39 Oil & Filter Change (vacuum extraction method)
- Why I don't recommend the Motive Vacuum Oil Extractor ...
Note the bevy of potential solutions:
- Use a 6mm wide screwdriver to spin the broken half out
- Use an EX-4 screw extractor (aka easy out) to spin the broken half out <-- recommended
- Reverse drill the steel broken half out of the aluminum oil pan
- Retap the stripped threads in the aluminum oil pan (but generally the bolt breaks before the threads strip)
- Wrap teflon tape on the threads of a new bolt and screw it in abutting the broken bolt half
- Heli-coil the stripped threads in the aluminum oil pan
- Drop the E39 V8 il pan to access the bolt if it fell through (dropping the E39 I6 oil pan is a nightmare)
- Weld over the hole and use the MightyVac oil extractor from the dipstick forever more
- Weld over the hole and use the oil level sensor as the drain plug instead
- Access the broken bolt inside the oil pan through the leveling sensor opening
- Buy an aftermarket oil drain bolt (e.g., EAS Tuning magnetic, or ?)
