E46 (1999 - 2006)
Old 09-28-2008, 10:48 PM
onetruegem onetruegem is offline
Mein Auto: 2002 BMW 330i
Resetting oil indicator light After Oil Change
Hello, just a brand newbie to this site as I just bought a used 2002 BMW 330i so I wanted to start with brand new oil, had oil and filter changed. Now it shows 25000 and the word inspection is this correct or should it say oil service or something to that effect.
THANX
Old 09-28-2008, 10:55 PM
SeanC's Avatar
SeanC SeanC is offline
Mein Auto: E70 Xdrive48, F30 328i
normal.. it'll say oil change after you have your inspection done in 25000 kms..
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Old 09-29-2008, 05:22 AM
viloria9 viloria9 is offline
Mein Auto: 2001 330ci BMW
i have a 2001 330ci and i to am a newbie to my car functionality. i have changed my oil last week and the car continues to flash "-3300 oil service" whenever i start my car then goes away. is there a way that i can reset this myself without having to go to a dealer and pay a pot load of money?
Old 09-29-2008, 08:37 AM
Kurt V Kurt V is offline
Mein Auto: 2006 330i
You only need to HOLD the left odometer reset button WHILE turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
Old 09-29-2008, 09:17 AM
bimmeryota bimmeryota is offline
Mein Auto: 3 pedal saloon
good post! very helpful...
'02 330i| UUC Stage 4 + | UUC Evo3 SS | TSE3 | Dinan Stage 1 SW
Old 09-29-2008, 09:57 AM
SeanC's Avatar
this might not work on earlier model e46s such as 2001, in which case you'll need a reset tool. wiki should contain this information.
Old 09-29-2008, 12:10 PM
This will work on any mid-2000 forward E46.
Old 09-29-2008, 06:35 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
this might not work on earlier model e46s such as 2001, in which case you'll need a reset tool..
Or a paperclip.....
Old 09-29-2008, 08:13 PM
SeanC's Avatar
Originally Posted by smolck View Post
Or a paperclip.....
Old 10-26-2008, 03:00 AM
Socal323 Socal323 is offline
Mein Auto: 323i
What do you do with the paperclip that resets the inspection reminder ? I have a 323i built in January 2000 . I did everything on the inspection 2 following the Haynes manual but I still don't know how to reset the service reminder and the dash keeps flashing "inspection -300 mi" I've been told that the peake research tool is the only way to reset the reminders but if there's another way then I want to know. Those reminders are a good thing it's just getting a little annoying, especially knowing that the service has been done already. Thanks
Old 10-26-2008, 07:13 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
The information is in the wiki.
http://www.bimmerfest.com/wiki/index.php?title=BMW_E46
Old 10-30-2008, 12:13 AM
Mein Auto: 323i
Thanks KrisL !!
Old 02-03-2014, 12:26 PM
l.wagner14 l.wagner14 is offline
lwagner14
Mein Auto: 2000 323ci
i dissagree
I just tried that solution on my 2000 323ci and it worked. good tip
Old 02-03-2014, 08:31 PM
ChuckyVee ChuckyVee is offline
Mein Auto: 2000 323i
I have a 323i with an 04/2000 build date and the reset sequence using the cluster knobs worked like a charm.
FWIW.
Old 05-05-2015, 01:20 AM
rts100 rts100 is offline
Mein Auto: 730i
I've recently reset the Oil Inspection Indicator on my 325C! (2004). I used the button and key method and after a few tries, it works. BUT, it has reset to 11000km. I thought it should reset to 25000km. The oil used in the recent oil change is the whizz-bang one that is supposed to sustain the vehicle for long service intervals. Any thoughts??
Old 05-05-2015, 06:17 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
My thought is do it the old fashioned way and log your mileage. Btw unless you're doing >75% highway miles your interval should not be the full 15k miles. Most people go half the BMW recommended interval. I did an oil analysis on mixed driving and was suggested to go 9k miles between changes. Lots of discussion on this.
Otherwise you may try resetting it again or a programming tool like PA Soft may be able to edit the reminder interval. I've never reset mine.
Look in the wiki
http://www.bimmerfest.com/forums/showpost.php?p=8014505
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
