Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 06-09-2003, 08:54 PM
alee's Avatar
alee alee is offline
Super Moderator
Mein Auto: '13 E92 M3, '01 E46 330Ci
M3 strut brace install questions
Since the group buy for the M3 strut brace is well underway and it looks like people will be phoning in their orders soon enough, it's time to ask a few quick questions about the installation, as I'm sure they'll crop up eventually.
I read Ack's post which mentioned that only a 13mm wrench is needed.
Questions:
1. What is the BMW specified torque requirements when you mount the brace?
2. What are the risk(s) (if any) if you don't torque it enough or overtorque it by hand without a torque wrench?
3. What could go wrong with this install (i.e. what's the HACK factor here -- what are the chances I'll end up with a car I can't drive)?
4. I don't own any tools... if I were to buy the correct tool(s) for this install, what would you recommend (assuming I were to make a trip to Sears and wanted to spend under $100)?
2001 E46 330Ci - 42K miles, 2013 E92 M3 - Back from PCD
Thinking about doing European Delivery? Read about my ED experience. Best trip, ever.
Old 06-09-2003, 08:57 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
You can get the tools for a couple bucks. All you need is a 13mm box wrench. I recommend springing for the ratcheting variety for a couple more bucks.
I torqued to tight, using a six inch or so long socket wrench. It's worked for me. About the only way you'd screw something up so badly that you wouldn't have a car to drive is if you left the bolts off...
I'll look up the torque specs sometime when I'm not feeling so lazy.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 06-09-2003, 09:24 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
The nuts that go in that location if you don't have a strut bar are either 24 or 34Nm depending on whether the flange on the nut is small (18mm) or large (21mm). Seems pretty loose to me, but that's out of the book. I really can't see too much harm in overtorquing it (at least from the amount of reasonable torque you could get into a 13mm combination wrench). Any looser than specified, and your front strut could come loose, but probably not fall out very easily.
As for tools, IMO a good general starting point for little money is a 3/8" socket set, preferably all-metric, so you don't spend money on SAE sockets you may not use unless you work on stuff around the house. Sears has a nice set with their new polished, low-profile ratchet and laser-etched sockets that will do nicely.
Old 06-09-2003, 09:35 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
It's a pretty HACK proof project. All you need is make sure the top strut hat does not move (or if you're in the mood for negative camber, move it). If your car is sitting under load (i.e. not on a lift or jackstands) then you'll be fine.
The nuts, from what I understand, is very sensitive to UNDERTORQUING. And Kaz is right, it's the 24Nm (or 18ft-lbs) torque setting. If you want to do the job right, get the torque wrench. If you just want to wing it (since the strut brace is, afterall, mostly cosmetic) just hand tighten it and go over it with a racheting wrench. Do be careful, the reason why BMW specs a torque rating for these nuts is that overtightening it WILL stretch the threads, or worse yet, break off the bolt.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 06-12-2003, 07:34 AM
RichP RichP is offline
BFE 2003
Mein Auto: 2002 330Ci
they come with lock-tite on them, so even at the 18 setting, they should be fine; someone on fanatics already overtorqued one and broke the bolt though, so be careful!
Old 06-12-2003, 07:38 AM
Mr. The Edge's Avatar
Mr. The Edge Mr. The Edge is offline
Mein Auto: .
yes, the torque spec is LOW (18-20 ft-lbs)
When I installed mine that seemed awfully loose, but I've had no problems in the year or so that I've had it on.
Old 06-12-2003, 08:42 AM
The HACK's Avatar
They're ONE USE nuts, meaning they've either got some sort of plastic inner lining that gets crushed as the nut is being tightened, or the threads are made in a way that it'll deform a certain degree when the desired torque is reached and prevent the nut from backing out.
Another reason why they're so damn expensive.
EDIT: Meaning once you tighten it, do not loosen it back up or you'll need to get a new set of nuts. Hence having a torque wrench is VITAL for the install.
Old 06-12-2003, 08:57 AM
Mein Auto: .
not sure about that. I bought a used one and the nuts were fine
Old 06-12-2003, 09:02 AM
AB's Avatar
AB AB is offline
Don't worry, be happy
Mein Auto: '11 Porsche Carrera S
that's what she said
Old 06-12-2003, 09:30 AM
The HACK's Avatar
All strut nuts are one use only. Using used nuts will compromise a) the torque rating and b) compromise the nuts ability to stay on the thread. I would NEVER reuse the one use only strut nuts and shock mount nuts. Don't be surprised if they back out of the thread sometime in the future.
It's your call.
Old 06-12-2003, 09:36 AM
Mein Auto: .
It's your call.
we're talking about these right?
Old 06-12-2003, 09:41 AM
RKT BMR's Avatar
RKT BMR RKT BMR is offline
Banned
Mein Auto: 5/01 production 330Cic
OMG... $7.60 EACH?!?!?!?!?
Old 06-12-2003, 09:52 AM
alee's Avatar
Super Moderator
So what's a cheap but good one that I can pick up?
Old 06-12-2003, 09:56 AM
The HACK's Avatar
Yeah. They're all one use only. Again, you may not think you're having any problems with them right now, but I'll bet it's probably no longer at 18-20ft-lbs right now. It probably doesn't take more than 10 ft-lbs to hold the strut brace down, and that's why you haven't experience any problem with it. I'd suggest you check them with your torque wrench and see if they're still within spec.
If you've seen these nuts NEW, you'll see the very last thread tapers to make these nuts "self-locking". Once used the last thread deforms to conform to the shape of the thread and locks itself down. The second you remove and re-use them, that last thread will no longer lock down and you're basically taking a chance that 18ft-lbs spread through the thread will hold the nut together.
Like I said, it's your call. I'd suggest you replace them with new one use, self locking nuts.
Old 06-12-2003, 10:04 AM
Mein Auto: .
just checked, they're all still at 20
Old 06-12-2003, 10:05 AM
Mein Auto: .
Home Depot sells a Husky TW that is good from 10-100ft lbs for about $50
Old 06-12-2003, 10:06 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
You are not assembling the Space Shuttle. Hell, you're not even assembling the lower control arm of the car.
Ausgang will probably disagree, but I've seen how these particular nuts work, and backing them out and retightening them a couple of times for this use will NOT do any harm. Especially at the torques these are used at and the material out of which it's made, the threads aren't going to deform to the point where they are going to lose their effectiveness at those loads.
Old 06-12-2003, 10:09 AM
Mein Auto: .
I will also add the ChuckD at roadfly notes that those with adjustable camber plates retighten and tighten those nuts every time they make an adjustment
Old 06-12-2003, 10:14 AM
The HACK's Avatar
I'll say that there's probably divergent opinion regarding this issue.
I've had my rear self locking nut come loose once because I re-used them when I installed my RSMs. I even torqued them to spec too. Took about 6 month for it to work itself loose.
Those with adjustible camber plates also adjust them often enough to not ever have to worry about the negative effects.
If it works for you...Great. I'd suggest you check them periodically to see if they're still true to torque.
Old 06-12-2003, 10:15 AM
alee's Avatar
Super Moderator
I was thinking something smaller? I already have a Craftsman 1/2" drive one that probably goes that low, but I was thinking of picking up something smaller for jobs like this.
Old 06-12-2003, 10:16 AM
Mein Auto: .
This, of course, is excellent advice, whether they are self-locking or not
Old 06-12-2003, 10:17 AM
Mein Auto: .
then why wouldn't you use that one?
EDIT: not sure if many 1/2" drives go to 10. It may go as low as 25.
There should be some micro torque wrenches that would fit the bill
Old 06-12-2003, 10:18 AM
The HACK's Avatar
The Tool Warehouse (www.thetoolwarehouse.net) sells an KD micro torque wrench (0-30nm) that I use, 3/8" drive and about 6 inches long that works great for torque sensitive jobs like brake caliper guide bolts that require a very low torque setting. About $35 last I checked.
Old 06-14-2003, 01:01 AM
wookiehoth wookiehoth is offline
Mein Auto: 2002 E46
I had mine installed by the dealer. I hope it is torqued correctly.
Old 06-14-2003, 07:45 AM
Bimmer ese's Avatar
Bimmer ese Bimmer ese is offline
Mein Auto: 04 X5, 01 330i
Torque wrench
A torque wrench has a usable accurate range from 20-100% of full scale (ie, a 5-75ft lb wrench is accurate from 19-75 ft lb). I really do not know of any US spec wrenches that can cover anything from 17-19ft lb without going to a NM scale wrench. Hell, I've already purchased two Snap-On torque wrenches for my car. Now, it looks like I may need another one Oh well
