E46 (1999 - 2006)
Old 10-01-2008, 02:09 PM
EyeNDaSky1 EyeNDaSky1 is offline
Mein Auto: 2002 325i
Exclamation 2002 325i High Pitched Whistling Noise
I have a 2002 325i with 119K. The last couple of days I have noticed a high pitched whistling noise coming from the engine bay. It only whistles around 2000 - 3500 rpms and only lasts for about 5 mins after start. I thought it may be the wheels or brakes, but the noise is still there in Neutral. I don't usually hear it in the morning which I also found weird.
Any ideas?
Buy cheap OEM parts from Evan or Jason www.mileoneparts.com
Thanks,
Robbie
Old 10-01-2008, 09:29 PM
Keyser Soze's Avatar
Keyser Soze Keyser Soze is offline
just like that, he's gone
Mein Auto: 2013 535
search air intake boot
2013 F10 535i M-Sport, Sophisto Grau, 6-speed MT
2011 E90 335i Sport, Jet Black, Sport Auto, Performance Edition
2002 E46 330i Sport, Jet Black, 5-speed MT, lots of upgrades
2001 E46 330Ci Sport, Steel Grey, 5-speed MT....and more
Old 10-01-2008, 10:16 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Sounds like your intake is either wtf dirty or has a little hole some where. I had this problem on a Monte Carlo SS a while back never had the problem on my BMWs though. But it did turn out to be my intake was wtf dirty.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 10-02-2008, 02:32 PM
Ok, Great. I'll take a look at it. I replaced the belts thinking they were worn, but didn't fix the noise. Doesn't matter anyway because the belts were still original...
Old 10-02-2008, 02:59 PM
Gryphon's Avatar
Gryphon Gryphon is online now
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
Open the hood, and try to track down the general area it's coming from in the engine bay.
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 10-02-2008, 06:54 PM
henry_desmond's Avatar
henry_desmond henry_desmond is offline
Mein Auto: 08 BMW 335i cabrio
Mines started as a whistle and then it turned into a high pitch squeal.... I thought it was the belts then it turned out to be the alternator tensioner! It costed $976.88 to replace it at the BMW dealership!
Currently own: 08 BMW 335i vert, 07 Mazda CX-7 GT (DD)
Previously owned: 03 Infiniti G35 sedan, 00 Mercedes-Benz S-430, 97 Volvo 960, 01 BMW 330i, 97 Lexus ES300, 09 Honda Civic LX, 04 BMW 325CIc, 00 BMW 323i, 97 Honda Accord EX Coupe, 99 Ford Expedition EB, 05 Mazda 6i, 94 BMW 325i, 98 Pontiac Firebird Formula WS6 "Collectors Edition", & 87 Honda Prelude Si (First car)
Old 10-03-2008, 07:56 AM
Ok, maybe high pitched whistle wasn't the correct sound terminology. Its more like a high pitched whine, that fluctuates with how high the rpms are. Seems to only do it on the drive home from work after the car has sat in the parking garage. It was about 50 degrees this morning and didn't do it.
It will only last for about 5 mins on the drive home and then goes away till the next end of work day.
Old 10-06-2008, 09:36 AM
Update:
Took apart air intake, cleaned and looked for cracks. Everything seems fine. Also hooked up my OBD reader and no codes were present.
Still making the noise...
Old 10-06-2008, 10:23 AM
ChrisLLK ChrisLLK is offline
Mein Auto: 2000 stahlgrau e46 328Ci
Could be the belt idler pulley or the alternator? If the bearings are just starting to go in one of those, it's possible when the vehicle is cold they are making noise at a certain RPM, and when they warm up, the little bit of lubricant they have starts working and the whine goes away.
Old 10-06-2008, 10:35 AM
troubled's Avatar
troubled troubled is offline
Mein Auto: 00' 323i
Originally Posted by EyeNDaSky1 View Post
Update:
search my name and look for the post on the noise mine was making and see it is close
2000 323i
ZHP Suspension (shocks, springs, sways)
Front Strut Bar
135m Wheels
BMW CCA #407107
Old 10-07-2008, 02:33 PM
troubled: the brake booster issue? I think its a diff sound than the one you described. Plus applying brakes or not applying brakes has does not affect the sound being present or not.
After opening the hood and having a friend press the gas pedal (in neutral) I have traced the sound to be coming from the area of the alternator....
Old 10-07-2008, 04:30 PM
Mein Auto: 2013 535
you aren't going far enough up the air intake BOOT chain.................it's the last rubber elbow before it hits the manifold. That's the part that splits and causes the whiney noise.
Old 10-07-2008, 05:35 PM
jsonli jsonli is offline
Mein Auto: 330ci
You got raped.
Old 10-08-2008, 04:35 AM
sierrakilo99 sierrakilo99 is offline
Send a message via AIM to sierrakilo99
Mein Auto: 2008 328i/1989 Civic HB
Check the crankcase ventilation system. These components deteriorate due to heat and can crack, causing the 'whistling' noise you hear. The ventilation valve (item 1 in the diagram) isn't expensive to replace, but its a b&*ch to get out.
Name:	Crankcase Ventilation-Oil Separator.png
Old 10-08-2008, 08:33 AM
troubled's Avatar
Mein Auto: 00' 323i
mine was not a broke booster problem I have attached a link to my thread here see if this sounds anything like yours
http://www.bimmerfest.com/forums/sho...910&highlight=
2000 323i
Front Strut Bar
135m Wheels
BMW CCA #407107
Old 10-10-2008, 10:43 AM
Wow, yeah that's the exact sound. I haven't heard the noise in a couple days, but if it comes back I'll be sure to do what you did. Thanks.
Old 10-10-2008, 11:21 AM
troubled's Avatar
Mein Auto: 00' 323i
My problem was the deflection pulley, but I replaced both the adjusting pulleys at the same time. This is really an easy DIY, if you want to do this yourself PM me and I can help you out.
2000 323i
Front Strut Bar
135m Wheels
BMW CCA #407107
Old 10-10-2008, 02:39 PM
mogness mogness is offline
Mein Auto: '01 330Ci
Oddly enough, I seem to be having the same issue. Started yesterday night after I drove through a flooded road, although it doesn't seem to be as loud as the one in the video. Did yours start out softer, troubled?
It really freaked me out this morning but I found that it becomes less noticable after I drive for a while.
Old 10-10-2008, 02:45 PM
troubled's Avatar
Mein Auto: 00' 323i
No mine just started that loud. I only ran the car long enough to get the video for posting and then went I got the parts. There was no warning at all.
2000 323i
Front Strut Bar
135m Wheels
BMW CCA #407107
Old 10-10-2008, 02:52 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Does that include 200 miles in duplicate trips because you were given the wrong parts? Was that "easy"? :
Old 01-20-2011, 12:42 PM
ericgarr ericgarr is offline
Mein Auto: 27502
I've been having the same problem. Whistling stops when I put in the clutch or let off the gas. Air intake would make sense. It's been too cold to look at it lately.
Old 08-13-2011, 12:37 PM
tazthecat tazthecat is offline
Mein Auto: 2004 325i
Loud noise in the engine bay
The temp was around 92 degrees, I wasnt parked in the shade and my car was off for around 3 hours. Once I was done, around the same temp outside, I went to my car started it up and I was hearing this loud whistling/scretching noise. It sounded the same as the noise you pointed out on your video. This is the first time I heard the noise, do you think I should wait to hear it again before I start taking anything a part. Another note, you said that what you did was an easy DIY. Mind giving me some more detail on what you did? I would much appreciate the reply!
P.S
2004 325i/108k miles
325i, engine, noise, whistle
