Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 06-12-2003, 05:13 AM
AF AF is offline
Here since day one
Mein Auto: 535ix, GL450, 991S
Gary - what is the weight of the 18 x 9.5 SSR GT3 ?
Hey Gary,
Can you tell me the weight you have for the 18 x 9.5 SSR GT3 wheel and if by any chance do you have the weight of the 255/35/18 . . .
thanks
Old 06-12-2003, 05:16 AM
Ack's Avatar
Ack Ack is offline
In Mod Heaven
Mein Auto: 2002 330Ci
Re: Gary - what is the weight of the 18 x 9.5 SSR GT3 ?
Originally posted by AF330i
Hey Gary,
thanks
I was always curious about this. Nice ? Alan.
Old 06-12-2003, 05:21 AM
SpaceMonkey's Avatar
SpaceMonkey SpaceMonkey is offline
both feet in
Location: Home of the Superbowl XXXVI & XXXVIII Champions
Send a message via AIM to SpaceMonkey
Mein Auto: '02 ZJC
I know the 18x8.5 GT3 is about 25 lbs.
And the 18x9.5 GT1 is roughly 19.7 lbs.
As for tires, weight varies by manufacturer.
5sp, Sport, CWP, Xenon, Moonroof, ///M Steering Wheel, ///M Strut Brace, OEM Aluminum Pedals, Euro Storage Tray
VDO Gauges, GruppeM CAI, Shark Injector, UUC SwayBarbarians, UUC evo3 SSK & RK2, UUC TrannyMounts/Enforcers
Passport SR7 / ZR3 Radar, XM Satellite Radio, a/d/s sound, BBS RG-R 17x8 w/Bridgestone Potenza S-03 235/40ZR17
Old 06-12-2003, 05:43 AM
Gary@Tirerack's Avatar
Gary@Tirerack Gary@Tirerack is offline
Moderator
Mein Auto: 1995 BMW M3
Right on guys! 18X9.5 GT3's weighing in at 24.5lbs.
Tire weights will very by manufacturer. Most are 23-28lbs.
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link.
Gary@Tirerack.com
Old 06-12-2003, 05:49 AM
AF AF is offline
Here since day one
Gary are you sure about this weight for the 18 x 9.5 because that sounds like the wieght of the 18 x 8.5 ?
I had weighed out on a very accurate scale 2 different 18 x 8.5 GT3 wheels and came in at 24.2 lbs. & 24.4 lbs (but this later wheel had about 2 oz. in wheel weights and the former had no wheel weights)
.3 lb difference for an extra inch sounds kind of low . . .
Old 06-12-2003, 05:54 AM
Moderator
SSR is showing 24lbs on the front one... I can assume they would round down a decimal, so this sounds about right to me. The forged rim section being one inch wider normally does not add much weight. I'm at the mercy of their numbers, but they do make sense in this case.
Gary@Tirerack.com
Old 06-12-2003, 06:00 AM
AF AF is offline
Here since day one
ok . .. . thanks for the info . . . I appreciate it
Old 06-12-2003, 06:11 AM
Mr. The Edge's Avatar
Mr. The Edge Mr. The Edge is offline
Mein Auto: .
for a little more confirmation, evosport lists 24 lbs for the 18x8.5 and 25 lbs for the 18x10.
So naturally, the 18x9.5 should fall right between those
Belief cannot argue with unbelief, it can only preach to it
To clasp the hands in prayer is the beginning of an uprising against the disorder of the world.
