Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW. Sponsored by The Tirerack. Moderated by Gary@Tirerack.com |
Gary - what is the weight of the 18 x 9.5 SSR GT3 ?
Hey Gary,
Can you tell me the weight you have for the 18 x 9.5 SSR GT3 wheel and if by any chance do you have the weight of the 255/35/18 . . . thanks |
Re: Gary - what is the weight of the 18 x 9.5 SSR GT3 ?
And the 18x9.5 GT1 is roughly 19.7 lbs. As for tires, weight varies by manufacturer.
![]() 5sp, Sport, CWP, Xenon, Moonroof, ///M Steering Wheel, ///M Strut Brace, OEM Aluminum Pedals, Euro Storage Tray VDO Gauges, GruppeM CAI, Shark Injector, UUC SwayBarbarians, UUC evo3 SSK & RK2, UUC TrannyMounts/Enforcers Passport SR7 / ZR3 Radar, XM Satellite Radio, a/d/s sound, BBS RG-R 17x8 w/Bridgestone Potenza S-03 235/40ZR17 |
Right on guys! 18X9.5 GT3's weighing in at 24.5lbs.
Tire weights will very by manufacturer. Most are 23-28lbs.
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link. Gary@Tirerack.com
I had weighed out on a very accurate scale 2 different 18 x 8.5 GT3 wheels and came in at 24.2 lbs. & 24.4 lbs (but this later wheel had about 2 oz. in wheel weights and the former had no wheel weights) .3 lb difference for an extra inch sounds kind of low . . . |
SSR is showing 24lbs on the front one... I can assume they would round down a decimal, so this sounds about right to me. The forged rim section being one inch wider normally does not add much weight. I'm at the mercy of their numbers, but they do make sense in this case.
ok . .. . thanks for the info . . . I appreciate it
for a little more confirmation, evosport lists 24 lbs for the 18x8.5 and 25 lbs for the 18x10.
So naturally, the 18x9.5 should fall right between those
Belief cannot argue with unbelief, it can only preach to it ![]() ![]() ![]() ![]() To clasp the hands in prayer is the beginning of an uprising against the disorder of the world. |
