E36 (1991 - 1999)
Old 10-11-2008, 12:16 PM
mbayba1234 mbayba1234 is offline
Mein Auto: 1995 318i
Question 1995 318i owner's manual? or at least radio wire diagram?
I was wondering if anyone knew of an online or happened to have a .pdf for a 95 318i owner's manual?
just got my first bimmer the other week and it came with a supplementary owner's manual?
but not all the information i need is in there
my buddy is trying to hook a sub up for me and i need the radio wire diagram, so i know what colors mean what
any help would be greatly appreciated!
Old 10-11-2008, 01:58 PM
jpeavler jpeavler is offline
jpeavler
Mein Auto: 93 318i
1994-95 BMW 318i
Six-Speaker System
FUNCTION PIN WIRE COLOR
Accessory 12 Volt 5 VT/WT
Constant 12 Volt 9 RD/WT
Chassis Ground 15 BN
Power Antenna 16 WT
Remote
Illumination 13 GY/RD
Dimmer
FUSE VALUE FUSE LABEL FUSEBOX LOCATION
15 AMP #44 DRIVER'S SIDE UNDER HOOD
20 AMP #9 DRIVER'S SIDE UNDER HOOD
The front tweeters are wired in parallel with the front woofers.
Left Front Spkr + 1 YW/RD
Left Front Spkr - 8 YW/BN
Right Front Spkr + 2 BU/RD
Right Front Spkr - 11 BU/BN
Left Rear Spkr + 3 YW/VT
Left Rear Spkr - 12 YW/GY
Right Rear Spkr + 6 BU/VT
Right Rear Spkr - 14 BU/GY
Cell Phone Mute 4 WT/BN
Vehicle Speed Sensor 10 BK/WT
Back to top
Ten-Speaker System
Power Antenna 16 WT*
Remote
Dimmer
*The WT wire triggers both the antenna booster and the ten-speaker amplifier.
Left Front + to Amp 1 YW/RD
Left Front - to Amp 8 BN/OG
Right Front + to Amp 2 BU/RD
Right Front - to Amp 11 BN/OG
Left Rear + to Amp 3 YW/BK
Left Rear - to Amp 12 BN/OG
Right Rear + to Amp 6 BU/BK
Right Rear - to Amp 14 BN/OG
Back to top
Amplifier Wiring INPUT SECTION
FUNCTION WIRE COLOR
Constant 12 Volt RD/WT
Amp Remote WT
Chassis Ground BN
Left Front + Input YW/RD
Left Front - Input BN/OG
Right Front + Input BU/RD
Right Front - Input BN/OG
Left Rear + Input YW/BK
Left Rear - Input BN/OG
Right Rear + Input BU/BK
Right Rear - Input BN/OG
OUTPUT SECTION
FUNCTION LOW-RANGE MID-RANGE HI-RANGE
Left Front Spkr + YW/RD YW/WT YW/GN
Left Front Spkr - YW/BN YW/BN YW/BN
Right Front Spkr + BU/RD BU/WT BU/GN
Right Front Spkr - BU/BN BU/BN BU/BN
Left Rear Spkr + YW/GY YW/VT
Left Rear Spkr - YW/BK YW/GY
Right Rear Spkr + BU/BK BU/VT
Right Rear Spkr - BU/GY BU/GY
Old 01-30-2009, 03:24 AM
jason_recliner's Avatar
jason_recliner jason_recliner is offline
Don't ask me, I'm a sofa.
Mein Auto: Bostongrün 1995 320i
Ah, seek and ye shall find. This is just what I am looking for.
I picked up a new blootueth phone kit today off a mate and obviously would like it to mute the stereo when in use.
Does anyone know whether the mute wire should be taken high or low to activate the function?
"The Reclinermobile" - 1995 320i Boston Green
A word on our sponsors: Iridium sparks thanks to NGK. Wheels will shortly be dressed once again by Yokohama C-Drive. Road is lit by Eagle-Eye 6000K HID, supplemented by 7000K CCFL Angel eyes. HB/Fog have selected to go with Philips 4000K BlueVision. Engine parts choose to slip with Castrol's 20-50 GTX2 dinosaur slime, renewed every 10,000km.
Old 01-31-2009, 11:07 PM
*bump*
Or for that matter, how to even get to the wiring? I can't see how the stock stereo comes out.
If the wiring loom came out somewhere else I could access the mute wire, that would be good too.
Old 02-01-2009, 08:29 AM
imrbobby imrbobby is offline
Mein Auto: 96' 3.28I bmw 3 series
hey welcome to the forums, first of all if no one told yo uabout this there is a search button and theres alot of DIY about taking somesort of the radio out.. ill jus tell you now, there are gunna be 2 bolts on the sides of your radio take those 2 out and all you need to do is pull it out.
Old 02-01-2009, 08:40 AM
http://cgi.ebay.com/ebaymotors/BMW-C...Q5fAccessories
if you scroll all the way down to the pictures, it should tell you where the bolts are at. and only use the first picture in the link.
318i, diagram, manual, subwoofer, wire
