Old 10-14-2008, 08:53 AM
jblanco's Avatar
jblanco jblanco is offline
Mein Auto: 745i
Left front parking lamp malfunction
Team,
Yesterday I got this message on my console "Left front Parking Lamp Malfunction" then i Noticed that my left side angels lights are not longer working....My question is the following:
1 - Is the problem just light bulb...
2 - Is the problem the entire light set...
3 - What will be the cost before I bring the car to the D this saturday....
4 - Can I do this myself without problems....
Regards,
T.
Old 10-14-2008, 10:58 AM
harjothundal's Avatar
harjothundal harjothundal is offline
E65/E66 Helper Man.......
Send a message via AIM to harjothundal Send a message via MSN to harjothundal
Mein Auto: BMW 745 Li
i had the same thing... it was the bulb alone... weird thing though... my front right halo and rear licence plate light went out atthe same time... magically the halo turned back on though... the dealer still replaced both bulbs under warranty and i am yet to have any furthur issues...
Old 10-14-2008, 05:44 PM
unirok's Avatar
unirok unirok is offline
The White Knight
Send a message via AIM to unirok Send a message via Yahoo to unirok
Mein Auto: Cadillac STS-V Series
Originally Posted by jblanco View Post
Team,
Regards,
T.
Min does this like once a month with the same message. I would have the dealer fix it but it always works itself back out again?
Cadillac STS-V series
BMW 745i Sport
Mclaren Turbo Grand Prix
Lincoln Town Car Signature Series
Old 04-21-2010, 03:32 PM
larsizzle larsizzle is offline
Mein Auto: 2005 BMW 745LI
I have the same problem, I think im going to replace Angel Eyes on both headlights,
Anyone know where I can get some nice ones at a decent price?
Old 04-21-2010, 03:53 PM
dmacd dmacd is offline
Mein Auto: 2004 745i, 2007 MINI
It's the bulb. The dealer will recommend replacing both, since they are expensive and the labor is also high. It requires loosening the bumper to get at the bulbs. It can be done by an owner, but if you make a mistake and break a headlight, it gets VERY expensive.
Old 04-21-2010, 04:10 PM
Blue Bimmer Blue Bimmer is offline
Mein Auto: 03 745Li
bulbs are $26 for a pair at bavauto.com. Check the DIY section for a good writeup. It takes a couple hours with simple tools. I am doing it this weekend. BTW I just got OEM bulbs... I like the stock look, plus i'm not a pimp.
Old 04-21-2010, 04:23 PM
so.. there are two bulbs per side...im not looking for anything fancy, im just a symetrical type person, and i know one side they work and the other they dont.........it might be easy to break other side, JK.. thanks for the help..
Old 04-21-2010, 06:28 PM
Mein Auto: 03 745Li
no, one bulb per side= a pair for the car.
Old 04-23-2010, 09:18 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
And, larsizzle, since you have the pre-facelift 745, you don't have to loosen the bumper or anything, just unbolt the headlight assembly and move it forward a little.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 04-23-2010, 09:50 AM
Joe-BMW's Avatar
Joe-BMW Joe-BMW is offline
Mein Auto: F10, E39, Audi Q7
I had the same malfunction and the dealer fixed it this past Tuesday. It was the left side and both angel eyes were out however they told me only one needed to be replaced. They possible could be stringed together like christmas tree lights when one goes out they all go out. They did not charge me but let me know CPO does not cover it, to my surprise.
2012 535xi|Dark Graphite|Black Interior|M-Sport|
Prior BMW's: 1987 325e|1993 740i|1998 740il|2002 745li|2007 750li|2006 750li
Old 04-25-2010, 09:53 AM
jssmi765 jssmi765 is offline
Jssmi765
Mein Auto: 2002 745i
I had the same problem, OFF/ON, OFF/ON, thought it might be electrical and not the bulb. Eventually I just decided to replace the bulb, found the info on how to replace it in the DIY section here. The bulb cost around $35 at the dealership but I put off replacing because I was avoiding the task of taking off my bumper. When I finally did it, it was easier than I thought. The DIY pics are accurate and very helpful. It only took me about an hour; bet I could do it in 30 min if I had to again. Everything has worked perfectly since. Forgot how much I missed those beautiful Angel Eyes!
Old 04-25-2010, 04:02 PM
revrun revrun is offline
Same experience here as jssmi. Searched and read and took it on. If you are patient and mechanical, it really is a simple task.
Old 12-11-2012, 04:05 PM
hwarris hwarris is offline
Mein Auto: '06 750LI
Hi Guys,
I own 06 750li and had same issue. I know everyone here is talking about taking the bumper of to replace the bulb but infact I didn't have to do all that. I found it was faster to take out the air filter intake (I think that's what's it called) thing and once the whole thing was out I just open the light over from the back and counter clockwise the socket and i had the bulb in my hand. Thought I would share this it took me 15min to do all this. I didn't take the picture as I was in a rush and sort of first timer so was more worried about everything else then making a video. Maybe next time. I paid $100 for OEM Sylvania HID at autozone for the bulb. Stealership was charging $250 for the labor.
Thank you to everyone posting on this blog it has save me alot of money. Hope this helps.
Old 12-11-2012, 06:56 PM
julio745licandy julio745licandy is offline
o4cAnDyReD745Li
Send a message via Yahoo to julio745licandy
Mein Auto: 04 745 LI CANDY RED
so an 04 745li model dont need to have the bumper tooken off if replacing both bulbs meaning right and left light? I have the same problem both parking light malfunction.
Old 12-13-2012, 03:56 PM
BuiltnBoostedZ BuiltnBoostedZ is offline
Mein Auto: X3 xDrive35i & 350Z TT
I didn't take the bumper off to replace mine. PITA without it off, but you can do it.
350Z TT - SOLD!
2004 745Li - SOLD
2011 X3 xDrive35i
Old 12-13-2012, 04:48 PM
rsbolin@me.com rsbolin@me.com is offline
Mein Auto: 2004 760i
I had an error about the right front parking lamp but I was looking at it and it is the Angel Eye that is not lighting. One dealer said it is the entire assembly for active headlight and wanted $2k+ to replace. What joke. I will pull the filter intake case as was stated by hwarris and replace the bulb.
Old 12-17-2012, 05:14 PM
E92-Lighting's Avatar
Mein Auto: 335i
its just a simple bulb replacement which we carry that is guaranteed to solve your error code
BMW ACCESSORIES and PARTS
Old 12-17-2012, 08:17 PM
ArtL's Avatar
ArtL ArtL is offline
Mein Auto: 2006 750Li
Yes, it's just the bulb replacement.
