E90/E91/E92/E93 (2006 - 2013)
#76
scraper - have several - not the issue.
question is the amount of idle time, which was between 5 to 10 minutes
2008 335xi Coupe Black Sapphire Metallic | 6MT | Sport Package | Cold Weather Package | Premium Package (Saddle Brown Dakota) | Navigation w/iDrive | Sattelite Radio | Dinan Exhaust 2009 KGT1300 Apple Red Metallic 2008 R1200RT Blue Biarritz (sold) 2003 Goldwing Black (sold) |
#77
When an owner complained to Ettore Bugatti that his car was hard to start in the cold Le Patron replied "If you can afford one of my cars you can afford a heated garage".
#78
+1
#79
So I am going to stress my engine without too much of an option other than building another garage or selling my other toys.
I live in Montreal...where the months December to March will have morning temperatures ranging from -7 F to 20 F. My single garage is filled with my '71 stingray and HD Fatboy. My new 335 is arriving around end of Dec and it will be sitting outside on the driveway from day 1. Now my commute to work is only 6 miles, hardly enough time to get it nice and hot! And don’t forget I am in the break in period where I want to treat the engine right! ![]() What to do? ![]() Is there an OEM oil/block heater available? Would that be my solution ?
2009 335xi Coupe, Space Grey Metalic, MT with Sports package (18") and Tinted Windows (+ Nav, Exec, Coldweather). |
#80
![]() dj
'08 535i Deep Sea Blue Cream Beige Dark Poplar 6 Sp Manual Sport Premium Rear Shades BMW CCA #392316 |
#81
Block heater is better than oil heater which can burn the oil at a molecular level. Im not sure if there are OEM units. I would guess not.
There are battery heaters too that are flat and go under the battery. You would want to use a zero wt oil like 0W30 or 0W40 An excellent thing for your motor would be to pump the oil thru the engine before you crank it. There are sytems on the market to do that. It has to be tied into a main oil gallery. Just 10 to 15 seconds should be enough to flow the oil to all locations before cranking the motor. Cold starting is the single largest contributor to engine wear. I lived in Alaska for a couple years so I'm familiar with these methods. The other thing in cold climates is to avoid moisture from collecting in your gas tank. Keep it full so there is less air in the tank and use quality fuel filters and additives to absorb the moisture. Straight alcolhol dumped in your tank also works very well and you don't need much, less than 15% of a full tank, when you tank is relative full. Some pump gas already has alcohol in it, up to 10%. Do not add to these gasolines.
Frank 540/6 Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy Last edited by franka; 12-10-2008 at 06:40 AM. |
#82
Get up earlier, and go for a drive every morning. Take some nice sideroads or go the lightly traveled direction on freeways. Enjoy the freedom you have been blessed with by that 6-mile commute.
-- 2009 335i Cabriolet Tasman Green/Cream Leather 6MT 2005 330Cic ZHP Monaco Blue/Grey Leather: sold to the unworthy "You know you're having fun when your tires melt." -Shocktopus, after a day of autocrossing in August |
#83
Be thankful you don't have my 4 mile commute!
09 - 335i E92 / Monaco Blue / Saddle Brown / Dark Burl / Step / Comfort Access / Rear Sunshade / Heated Seats / PDC / iDrive / Sat. Radio / iPod & USB / Prem Pkg / Sport Pkg / OEM Alarm / Ventus V12 (Non-RFT) / V1 and other goodies... |
#84
Stuations vary. It will work better in a garage than in the wind outside. Even a light bulb will raise the temp in your garage assuming it not drafty. In Fairbanks Alaska they have electrical boxes on the metter stands on the street with provsion to plug in your heaters (more than one is the norm up there).
Frank 540/6 Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy |
#85
Please explain why you shouldn't idle
I have read enough on this forum to know your not supposed to keep your car idling for more than 10-15 seconds because it puts a load on the catalytic converter. My question is what do you do if your stopped at a light? does that put a load on the catalytic converter as well?
they can't stop me they can only hope to contain me |
#86
Personlly I will let it idle for a min or 2. Personally the 10 to 15 seconds to me is pure BS. Letting it idle for a min or two does no damage. Can anyone tell us why over 15 seconds does damage and what is that damage?
#88
Our Bimmers have heated O2 sensors which enable the ECU to precisely control air/fuel mixture within seconds after starting. In addition the ECU has "learned" over the last X number of starting sequences at Y temperature what the best air/fuel mix is to start your car most effiently this time. I don't think that idling our engines for even an hour is going to cause the slightest amount of damage. Not even to the cats which the ECU is programmed to protect. Your MIL/CEL would come on long before the cats were damaged.
When we talk about the "best" idling/low speed/high speed sequence we need to define "best". Best use of the owner's time? Best for overall MPG? Best for engine longevity, etc? Life is a compromise, and so is "best". Here's my personal cold start method, used year round, which doesn't vary unless I'm defrosting the windows: Start the engine, idle for 15-30 seconds, drive moderately at under 3k rpm until the oil temperature is showing at least 180, then drive it like it was intended. Keep in mind that here in NH that we are "forced" to idle for extended periods to get the ice off the windows. Even if we do have heated garages at home, most of us do not at our jobs. I do think that as a GENERAL rule, all other things being equal, an engine in San Diego will show less wear than an engine in Manchester NH due to the fifty degree cooler average Winter temperature in NH. Speaking of san Diego, I just got back from a week there. Wow, nice cars, even the taxis have 21" BBS's and quad exhausts. |
#89
Idling to warm up a car is not "a bad thing." It just isn't necessary under normal conditions. It's a waste of gas and a source of unnecessary pollution. If you need to get the car warm to clear the windows it is far better to do that than to drive with impaired vision. More: If you have a very short commute (let's say less than 10-15 minutes) it's better to idle for a few minutes before you leave than for you to have to shut your engine down cold day after day. As a general rule , when you shut it down it should be warm enough to vaporize any moisture in the exhaust system.
#90
Just a simple question...why are the 3 series guys posting here? It's ok to post here but I would not be posting in the 3 series.
Sales as a vendor, anyway you can get it?
#92
I'm seeing this in the E9x forum, so that's why I'm posting in it. Maybe the moderators crossposted it since it is of general interest.
#93
In the summer i never warm up the car, i only warm it up to a defrost windows so I can see. Living in New England this can happen as early as October and last into March. I have anywhere between a half hour to 45 minute commute based on traffic conditions so cold shut off is not a problem.
#94
Huh? What? Why are YOU posting THIS here?
#95
My error. Thought it was an E39 thread. Don't know how I got into this thread in the 1st place.
Frank 540/6 Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy Last edited by franka; 12-10-2008 at 06:42 AM. |
#96
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
