Old 10-20-2008, 08:01 AM
BMW5MT's Avatar
BMW5MT BMW5MT is offline
Mein Auto: Silver 00' 540i 6 Speed
Pictures
OK here are some pictures. Just looking at these pictures what seal do you think it is? The trans is at the top towards the rear of the car and you can see oil on what I think is the back side of the flywheel.
Mike
ID:	163904   Click image for larger version
2000 Titanium Silver, Six speed, Sports
Mods:
CDV Delete, M5 Rear Sway Bar, M5 Grill, M5 trunk spoiler, M5 Mirrors, Hella Angle Eyes, Clear Side Markers, MZ3 SSK, Hella Celis Brake Lights, MKIV upgrade, Wide Screen Nav Display, 19" Moven S5R Wheels, ACS Pedals, iPod Icelink, Eisenmann Race Exhaust, M-Tech Rear Bumper, Umnitza Predator ICE, M Steering Wheel, Z4 shift knob.
Old 10-20-2008, 08:22 AM
cn90 cn90 is offline
The engine oil dye thingy is here:
http://www.popularmechanics.com/how_...71.html?page=2
My suggestion:
- If the oil leak not too sever, then watch it and top up the oil as necessary. At 86K miles, you may need a clutch job soon, so wait until clutch job and do the whole show (RMW, all man trans seals, clutch itself, flywheel, thrwout bearing etc etc)
- Or do this, always park the car in the same spot in the garage. Pull the dipstick and note where the engine oil is (keep note).
Also, check the oil level inside the manual trans by removing the FILLER plug and stick your finger inside. Best is to fill it with a bit of man trans oil until it flows out. Here is my write-up for 98 528i using tubing to fill man trans oil. Your 540i has the FILLER plug on the drivers side (instead of the passenger side as for 528i):
http://bimmerboard.com/forums/posts/189240
Now drive the car normally and check oil levels (engine oil + man trans oil) at 300-500 miles interval. If one goes down then you know the source of the leak.
Old 10-20-2008, 10:13 AM
Al's540i's Avatar
Al's540i Al's540i is offline
Mein Auto: '00 BMW 540i; '11 BMW X5
On my 540i the filler plug is on the passenger side of the tranny pan.
Current
2012 Audi A4 S-Line
2011 BMW X5
2000 BMW 540i
Past
2010 Mercedes ML350
1998 Audi A6 Quattro
2002 Lexus IS250
1988 Honda Prelude
Old 10-24-2008, 05:27 PM
BMW5MT's Avatar
OK, it was my rear main seal that went bad again! My mechanic removed the transmission and confirmed it. Here are some pictures I took today but I will post back tomorrow to talk a little about the shop that is doing the work.
BTW I am having the clutch replaced while they are in there!
Also the fluid you see in the fourth picture is not from the transmission, that is was came from the RMS.
Name:	Clutch and Rear main seal replacement (1)RS.JPG
ID:	164487   Click image for larger version
Name:	Clutch and Rear main seal replacement (3)RS.JPG
ID:	164488   Click image for larger version
Name:	Clutch and Rear main seal replacement (4)RS.JPG
ID:	164489   Click image for larger version
Name:	Clutch and Rear main seal replacementRS.JPG
Mods:
Old 10-31-2008, 05:11 PM
BMW5MT's Avatar
Guys
I just wanted to let everyone know that I got my rear main seal fixed along with replacing the clutch and pilot bearing. The best part about the whole thing is that they were quick and have really good prices. I paid only $995.00 including tax for the repair. If you're looking for a small shop in the Woodbridge, VA (Northern VA) area that will treat you right then go to:
Laslo's Foreign Car Service
14747 Build America Drive
Woodbridge, VA
(703) 491-7545
Please mention my name!
Mike Taylor
P.S. I found out that the reason why my RMS went bad after only a little over 2 years and only 10K Miles is by not driving the car. I really only get to drive my car on the weekends. I was told that I need to start the car and let it run about 15-20 three time a week to keep the seals soft.
Mods:
Old 10-31-2008, 05:54 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Glad you got that fixed.
I've never heard that about keeping the seals soft. I guess it's worth a try, but I'm not sure I believe it.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 10-31-2008, 06:57 PM
BMW5MT's Avatar
Funny, both the dealer and the Indy shop said the same thing about the seals without me saying anything about it. What do you think it could be?
Mods:
Old 10-31-2008, 08:52 PM
razzy530's Avatar
razzy530 razzy530 is offline
Send a message via Yahoo to razzy530
Mein Auto: 2007 530i 6 Speed
yes, when the seals get dry, they begin to leak. the oil lubricates them and keeps them soft, therefore the statement. also, if you run low on oil and not enough oil gets to the RMS, then it will leak once you do have enough amt of oil.
2013 F30 335i M-Sport (RWD)
2007 E60 530i 6 Speed (RWD)
2002 E39 530i Retired
BMWCCA MEMBER #397411
Old 10-31-2008, 09:09 PM
Couple thoughts:
1. Did your mechanic replace the Man Trans seals x4?
They should have done it.
Nothing is more annoying than 1 year and 20K miles later your Man Trans starts leaking.
2. Rubber, by its nature deteriorates with:
* Time
* Heat
* UV light (which is true for Car Tire but not for RMS).
* Pressure exerted on itself.
So a leaking RMS after 2 years could be a sign of INCREASED Crank Case Pressure. Check your CCV system!
I don't agree with people saying it leaks because of no use!
How about car stored for winter, does it leak in the Spring?
How about car parked at dealers lot waiting to sell?
How about Seals sitting a few years on the shelf waiting to be sold?
Old 11-01-2008, 08:46 AM
razzy530's Avatar
Couple thoughts:
* Time
* Heat
CN,
nothing likes to "sit still" because once it put into use, it breaks down or otherwise shows signs of no usage, ie leaks. If you remember, in storage a vehicle still needs an oil change, and its engine started every so often for simple lubrication. If the RMS is dry with out oil on it, it will leak. To your example, cars at the dealers get moved around all the time for space or specific vehicle needs. Both used and new of course. But if a used car sat at a dealers lot for 5 months, YOU BETCHA it would show its signs of breakage after sitting that long, in whatever shape or form.
Old 11-01-2008, 08:51 AM
Originally Posted by razzy530 View Post
CN,
nothing likes to "sit still" because once it put into use, it breaks down or otherwise shows signs of no usage, ie leaks. If you remember, in storage a vehicle still needs an oil change, and its engine started every so often for simple lubrication. If the RMS is dry with out oil on it, it will leak. To your example, cars at the dealers get moved around all the time for space or specific vehicle needs. Both used and new of course. But if a used car sat a dealers lot for 5 months, YOU BETCHA it would show its signs after sitting that long, in whatever shape or form.
razzy,
If you look at the comment the O.P. made:
"P.S. I found out that the reason why my RMS went bad after only a little over 2 years and only 10K Miles is by not driving the car. I really only get to drive my car on the weekends. I was told that I need to start the car and let it run about 15-20 three time a week to keep the seals soft."
Personally, I have owned many cars and some of which are driven ONLY on weekends, and yet the RMS only leaks after 12 years old and after 100k MILES, not AFTER 2Y/10k miles!
Old 11-01-2008, 09:23 AM
Ryan M Ryan M is offline
Mein Auto: .
If all this were true about not letting your car sit, then why don't the valve covers leak, the headgasket, the front main seal, all the seals in your tranny, in your differential, etc all leak? Because its BS. Only driving your car on weekends is fine. It's not like it's sitting for years on end. It's only 5 days. Come on guys.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 11-01-2008, 01:42 PM
BMW5MT's Avatar
Couple thoughts:
No he told me that the Trans seal looked good. BTW where are the 4 seals located?
I had him check the CCV while he had the car and he said it was good.
I have to say that I do agree with what you are saying about the car sitting.
I will say that the day it started leaking, I took it out for some spirited driving and that's when it starting leaking. Do you guys think that's what caused it?
Mods:
Old 11-01-2008, 09:36 PM
razzy530's Avatar
very possible, to answer your question. But of course coincindence plays a part too
Old 11-02-2008, 07:41 AM
Brevity= the soul of wit
Originally Posted by Al's540i View Post
Where is the rear main seal? I have a leak after changing my valve cover gaskets and I'm pretty sure it's not the gaskets?
Old 11-02-2008, 10:48 AM
BMW5MT's Avatar
OK where is the 4 transmission seals that cn90 was talking about?
Mods:
Old 11-02-2008, 11:18 AM
Mein Auto: .
I only know of three. Input, output, and selector shaft. Not sure what 4th one he is talking about.
Old 11-02-2008, 11:36 AM
BMW5MT's Avatar
Thanks Ryan!
Mods:
Old 11-02-2008, 02:20 PM
Ryan is correct, 3 seals total. Sorry, typo error!
However, FWD MT has 4 seals (input, selector, 2 outputs)
Old 11-17-2012, 09:39 AM
VA525FREAK's Avatar
VA525FREAK VA525FREAK is offline
Mein Auto: 2001 525i
I need help now, My car is sitting at shop waiting to have my auto transmission pulled to either:
1. replace front seal $1,200
2. replace transmission $2,500 minimum
Care has 207k miles on it. Engine leaks oil as well. Is it even worth it to throw this much money at a car with over 200k?
I could potentialy call mechanic and tell him to just not do anything and have it towed to my girlfriends dad's (he has a huge garage with lift) and attempt this on my own. I have pretty good mechanical skills but im no mechanic. What do you think I should do?
Also, does it make sense that the front seal blew out because my filter was clogged? Think my transmission will last?
Old 11-17-2012, 12:06 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Cool. Nice photos
Old 11-17-2012, 12:08 PM
ztom's Avatar
Originally Posted by PropellerHead View Post
Wow. Thanks for the photo.
