E46 (1999 - 2006)
Old 10-21-2008, 09:18 AM
jhowe1's Avatar
jhowe1 jhowe1 is offline
Mein Auto: E46 & E21
driver side door only no alarm activation???
if i am the only person in my car and only use the driver side door, the alarm does not arm when commanded. if i reach over and open the pass door and shut it then set alarm... it arms as advertised.
i am wondering if this is an issue that reprogramming the alarm at a dealership is required...
if anyone has had a similar problem i would like to know... thanks!
Old 10-21-2008, 01:48 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Who needs an alarm these days ? Does the clown nose blink when you lock the car with the remote? Are you sure you actually *have* an alarm ? (They`re optional on 3-series....most people don`t bother).
Regards,
Bob
Old 10-21-2008, 04:51 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Sound to me like *maybe* the switch on the passenger side door is malfunctioning and the alarm thinks the door is still open. It won't arm if a door is open, but upon close it will arm.
Unless the door wasn't closed all the way, but unlikely this is a repeat offense each time you drive the car.
Jeff R.
Old 10-21-2008, 05:34 PM
jhowe1's Avatar
i def have an alarm... i have set it off before.
the clown nose only blinks when alarm is activated, not just locked.
if the switch on the door is possibly malfunctioning, will the alarm still arm? and wouldn't the indicator light on dash show door opened all the time?
also, when the alarm DOES activate i get the normal blink of parking lights and *beep*
BUT, when it is JUST the driver side door that was opened, i get no lights or *beep*, just locking of the doors and no "clown nose" blinking...
Old 01-18-2011, 09:20 AM
redrivertavern redrivertavern is offline
Mein Auto: 2002 bmw x5
got to go to work will reply later thanks
Old 01-18-2011, 01:13 PM
GCoop's Avatar
GCoop GCoop is offline
Mein Auto: 2004 325xi
Old 01-18-2011, 02:15 PM
NO ALARM AT ALL . Power locks do not work also n. I did notice that the dome light is not coming on when driverdoor is opened ? Is there someting I mist when I put the new hadle unit on the door ?
Old 01-18-2011, 10:06 PM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 01 E46 330 xi
Like maybe you forgot to plug in the wiring for the door lock actuator. Or you routed the wiring in the door incorrectly and when you rolled the window down wiped all the wiring out.
01 E46 330Xi
06 E92 328i ZSP
07 E92 335i ZSP
E9 One Day It Will Be Mine
Old 01-18-2011, 10:14 PM
ya ok thanks
Old 01-18-2011, 10:22 PM
marinekilz's Avatar
Noone Special
OK I just reread my post and realized how cold it sounds. I really just ment to recheck your work if you just had the door apart for anoth repair.
01 E46 330Xi
06 E92 328i ZSP
07 E92 335i ZSP
Old 01-19-2011, 08:06 AM
K thanks for the input . I'm going to recheck my work as soon as i have time . <
Old 01-23-2011, 03:20 PM
scottjoh scottjoh is offline
Mein Auto: 1999 323i
Sounds like you need to replace the door lock actuator. The door ajar sensor is in the actuator assembly. I have all the part numbers listed on my web page for all the years/body styles/LHD/RHD. There are also pictures of the internals in case you were wondering what it looks like inside.
http://www.bmwgm5.com/E46_actuator.htm
alarm, door, driver, passenger
