Old 10-30-2008, 08:16 AM
Al's540i's Avatar
Al's540i Al's540i is offline
Mein Auto: 2000 BMW 540i
Calling QSilver! Which connection in the sterring column....
provides power to the steering column up/down movement? I want to disconnect this because mine makes an awful creeking sound (Uzi sound) whenever it moves up or down.
I've lubed it several times but to no avail. Dealer said I'd need to have the entire column replaced. Mucho dineros!
Right now to aleviate the problem, I've pulled fuse 13. I set the steering wheel to the height I like and pulled the fuse. The only problem with doing this is that I also lose power to all the seat functions .
If I know which plug is for up/down power, I could set my steering column to the height I like and then unplug....then the steering column would stay "frozen" in place but I'd still have power to my seats....
Thanks in advance to anyone's help on this...not just QSilver
2000 BMW 540i
2010 Mercedes ML350
1998 Audi A6 Quattro (Sold)
Old 10-30-2008, 08:22 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Hmm, if you are referring to the convenience exit feature that moves the steering wheel upward when the ignition is turned off, then back to its previous position when the ignition is turned on...then that feature is controlled by the control module behind the large rectangular seat switch.
I'm pretty sure anyone with an e39 or e38 built prior to 9/97 would be willing to swap seat switches with you. That would be the easiest way to rid yourself of that feature. Other than that, you'd probably have to go into the wiring harness and remove the wires that control it.
Again, that feature is controlled by something in the seat switch pictured below...which also communicates with the GM (general module) and the memory seat switch (in the door). The "convenience exit" steering wheel movement only occurs if you have the "specific" switch that you have...an older switch doesn't have it:
item #7 in diagram below prior to 9/97 build date don't have the convenience exit feature:
Q {BMW CCA Member #191509}
(SOLD)
Old 10-30-2008, 08:34 AM
Al's540i's Avatar
Thanks. If I get seats that don't have that switch how would I be able to move the steering column to my liking?
2000 BMW 540i
2010 Mercedes ML350
Old 10-30-2008, 08:42 AM
QSilver7's Avatar
The old fashioned way...with the stalk on the left side of the steering column.
(SOLD)
Old 10-30-2008, 08:44 AM
Al's540i's Avatar
Right but that moves electronically. If there is no current going to it, it doesn't move.
2000 BMW 540i
2010 Mercedes ML350
Old 10-30-2008, 08:59 AM
QSilver7's Avatar
I think you misunderstood what I meant about the seat switch.
Up until 9/97 build date...the e38 & e39 steering wheel didn't move up/down automatically when the ignition was turned off/on. The only way to move the steering wheel was with it's lever on the side of the column. It always stayed where you put it.
Then BMW updated the seat switch and added the convenient exit feature. The only thing that is different between the pre 9/97 seats is the automatic movement. BMW doesn't even sell the old switch any longer...so you can only get it used from older e38s & e39s built before 9/97.
If you totally disconnect the harness from the switch...then you will lose ALL seat movement ..if you have a wiring diagram...you probably could figure out what each wire going to the harness is for...and possibly pull the ones that are connected to the steering wheel. The wiring harness to the steering wheel switch on the column would still be connected to the GM...so I would think that you'd still be able to "manually" control the steering wheel.
(this is all just supposition...I've never looked at the wiring diagrams for these connections.)
(SOLD)
Old 01-26-2011, 08:43 AM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 1999 M3, 2002 M5
OK, found this thread and waking up. So, my steering wheel sometimes moves up and down, sometimes starts and stops. Occasionally, it loses all the memory settings.
Is the fuse going bad?
Note -- I'm only asking about the steering wheel, not the seat. Thanks!
I LIKE OLDER BMWS, PLEASE HELP ME:
Fern Green 99 M3, Conforti Shark Software, Conforti CAI, Dinan Exhaust. Stamped LTWs, 235x40 square, OE Hella heads, ///M Pedal Kit, Clear Corners, OEM Rear Spoiler, CD43 stereo. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 01-26-2011, 09:58 AM
QSilver7's Avatar
All though there is a fuse for the steering wheel...if it was blown, you'd never get any movement from the steering wheel (like pulling the plug on a lamp). Erratic movement would indicate a breakdown in communications from its control modules, or electro/mechanical failure of the drives that operate the column's movement. The "commands" for the steering wheel comes over the P-Bus from the GM to the seat module:
(SOLD)
Old 01-26-2011, 10:03 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
I'd still vote for the seat switch in your case. It may have erratic contact, looseness, etc that's causing this behavior, since it also controls the steering wheel. Pretty sure the fuses either work or they don't. Anyway simple to check a fuse and replace with a spare, there are spares in the glovebox.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 12 years
