Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 06-18-2003, 08:15 AM
ELOVE525 ELOVE525 is offline
Mein auto: 1999 528I
Suspension Dilemma
HELLO FELLOW BIMMER ENTHUSIASTS. I AM HAVING A PROBLEM. I RECENTLY BOUGHT 18X8.5 AND 18X9.5 BREYTON MAGIC RACING FOR MY 99 528. AFTER INSTALLATION, I FOUND THAT THE RIDE WAS SITTING PRETTY HIGH AND WANT TO LOWER IT A LITTLE. THIS IDEA MOSTLY CAME BECAUSE ONE OF THE REAR SHOCKS IS MESSED UP, SO MY PLAN WAS JUST TO CHANGE THE REAR SHOCKS, AND BUY SPRINGS. DOES ANYONE HAVE ANY ADVICE AS TO IF THIS IS A GOOD IDEA AND IF SO, WHO SELLS THE BETTER SPRINGS?
Old 06-19-2003, 02:50 PM
vietsb's Avatar
vietsb vietsb is offline
Trying to top 1K posts...
Mein auto: 89 E30 325i, 97 E39 540iA
It's highly recommended to:
-Replace the shocks at the same time as the springs. Why pay for labor twice? Also, if you have a 3-4yr old car or >50K miles, your stock shocks are probably going or gone anyways. Sounds like you plan to do this, but only for the rear.
-Replace all 4 shocks or springs at the same time with matching pieces. This maintains the intended ride design and balance the aftermarket company had in mind. In general, it's probably safe since it makes for more predictable handling.
If you currently have the stock sport suspension, you can try Eibach springs which will lower your car slightly front and rear, or H&R if you want the front to be even lower. Unfortunately, this is my experience w/ the 540i aftermarket springs, but I believe the 6-cylinder applications are about the same.
E39 DIY Site: BMWdiy.INFO
E30 DIY Site: E30.BMWdiy.INFO
BMWTips: BMWTips.com
Old 06-19-2003, 07:52 PM
BillP BillP is offline
Mein auto: Cars
Viet, you forgot one very important recommendation ...
STOP SHOUTING! DON'T YOU KNOW THAT TYPING IN ALL CAPS IS CONSIDERED EXTREMELY RUDE?
Phew! I feel better now.
Bill
Old 06-20-2003, 01:10 AM
vietsb's Avatar
Old 06-20-2003, 06:08 AM
THANKS
First of all, I want to say thank you to vietsb for the advice. That was my original plan but I wasn't completely sure because i kept getting different opinions on it. One more question, would it be wiser to get the sport shocks or the heavy duty ones?
Oh, and to BillP, sorry if i offended you. I didn't mean to yell at you. Hope I didn't hurt your feelings. I had no idea that you could actually yell over the computer.
Old 06-20-2003, 04:33 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator
Mein auto: Trek 6500 MTB
Re: THANKS
Don't worry about BillP...his eyes are extra sensitive.
It is commonly understood that posting in caps is more or less considered "yelling"...most prefer normal capitalization unless, of coure, YOU WANT TO FRICKIN' YELL AT SOMEONE!!!!
See how it works?
Old 07-17-2005, 08:09 AM
Offshore-Wealth Offshore-Wealth is offline
Offshore-Wealth.com
Mein auto: BMW 540
Greetings,
You didn't mention what size your tires are? Tires are going to have more impact on ride height than suspension changes will. If you go with spring and shock and strut change, I agree, you have to do all four to insure handling is correct. But the most you can expect is an inch lower with suspension change to sport as example. If you go Dinan, you will be spending a ton, so it is all about tires in my opinion.
Good luck, Mike
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
