E46 (1999 - 2006)
Old 11-02-2008, 06:06 AM
dj330Ci's Avatar
dj330Ci dj330Ci is offline
The Ultimate Übermensch
Mein Auto: 2006 330Ci ZHP
Power Steering Pump - DIY
I wanted to document my power steering pump installation so that anyone who needs to replace one might consider doing it themselves rather than shelling out a lot of money to have a band of orangutans do it. This job can be done in under 2 hours. On a scale of 1 – 10, I rate it a 3, my skill level being a novice. I drove the car up onto my Rhino Ramps so I could get underneath the car more easily. Some prefer using jack stands.
Parts Needed:
Power Steering Pump LUK LF-20 - 32 41 6 760 036
Tischer $404.80
1 Quart Mobil 1 Synthetic ATF or ATF of your preference. Don’t use “power steering fluid”. BMW advises using ATF.
1 pint Bass Ale draft, gently chilled.
Empty Fluid Reservoir:
Use a turkey baster or some other syringe type tool. Don’t worry if you don’t get every drop . . . it will come out in the end!
Remove these:
The fan shroud above looks intimidating, but it isn’t. Remove the electrical connectors first, then unscrew (#5) using a T20 torx bit. Next, pull the pin out (#4). Now you’re ready to lift shroud straight up and out of the way. This step is probably optional but I like having the extra room.
Loosen the 3 pulley bolts that attach the pulley to the pump:
See first illustration, bolt number 5. 13mm It’s a good idea to loosen these up before removing the serpentine belt. Follow Paul180’s directions here to remove belt. http://www.bmw330ci.net/maintenance/belts.php Follow this diagram when replacing the belt:
Remove splash guard under the engine bay:
This picture is for a 7 series but I wanted to post an image for reference.
Now you’re ready to get to the pump. First remove the rubber hose from the pump. This is where the fluid will gush so be ready to catch it using a plastic container of some type. Next remove the high-pressure line using a 17mm combination wrench. I think it’s 17mm. If the line cannot be separated from the pump at this time, don’t panic. Now you’re ready to remove the pump. Remove bolt #’s 2, 3 and 6 (referenced above) using a 13mm socket. If the high-pressure line is still attached, gently wiggle it free from the pump.
Now you’re ready to install the new pump. Complete all steps above going backwards this time. Fill reservoir with fluid to the max line. Start car, gently reverse off of the ramps. Now turn steering wheel from lock to lock several times. If steering wheel doesn't want to move, don't panic like I did . . ., Rev and hold up to 2500 rpm and gently turn wheel left and right. This builds up the pressure needed to open up the valve inside the pump. Now drive around the neighborhood and come back, check that level is okay.
Here are some helpful footnotes:
When reattaching the high-pressure line the bolt doesn’t screw in all the way. It wasn’t designed for that so when tightening it to the pump, and you feel it getting snug, that’s the ticket! Do not over tighten.
I don’t use torque specs. Common sense will give you a feeling when it’s tight enough.
It isn't necessary to remove front sway bar as Bentley recommends.
Finally, . . .
There's no such thing as an ugly man with a fat wallet!
Old 11-02-2008, 06:26 AM
RichReg's Avatar
RichReg RichReg is offline
Mein Auto: '15 435Xi.GC & '00 323Ci
Great DIY.
Where were you about 5 weeks ago when I had mine replaced?
As an addendum , I'd like to say that this pump LUK LF-20 - (32416760036)
is available BRAND NEW from AboveAllMotorwerkes for $300 w/free shipping.
http://www.aboveallmotorwerks.com/BV...UK_32416760036
Old 11-02-2008, 06:33 AM
dj330Ci's Avatar
Originally Posted by RichReg View Post
Great DIY.
Holy cow! $300? I haven't heard of these guys. Did you pay a fortune?
Old 11-02-2008, 06:45 AM
RichReg's Avatar
Did I pay a fortune for the install, do you mean?
No....with all due respect, I watched my mechanic (and his quite competent first-hand man) do the entire job in less than an hour.....
they charged me $95. I even let them keep the core. Of course, I wouldn't recommend using just anyone for this kind of install.
I gave them the pump of course, and the Mobil 1 ATF. I took a chance with AboveAll after a lot of research...they have a VERY small selection of parts and even less sales staff. I ended up dealing with the owner of the company since he was the only one who would return my calls: http://www.prlog.org/10054433-bmw-en...car-chief.html
It was a bit of a gamble, but so far it has paid off. Also, my understanding is that the remanufacturing of these pumps doesn't work very well long-term, so I wasn't willing to settle for one of those, either.
Old 11-02-2008, 07:04 AM
dj330Ci's Avatar
You got a steal! Install didn't cost as much as I thought. I still have the pump. I wonder if I can get cash for it. In some cases I could return it in exchange for the core charge but in this case there wasn't one. Anybody have ideas?
Old 11-02-2008, 07:12 AM
RichReg's Avatar
If you're referring to the old steering pump that you removed, without having someone remanufacture it,
I think the most you'd be able to get for it would be:
Old 11-02-2008, 07:16 AM
dj330Ci's Avatar
Man! I didn't even think about that. Now that's a steal!
Old 11-02-2008, 07:24 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Excellent DIY, thank you. You should place it in the Wiki, or make a DIY section there if its not there
Old 11-02-2008, 07:39 AM
dj330Ci's Avatar
Thanks for the comments. I'm really glad to be helpful.
Old 11-04-2008, 08:26 AM
SeanC's Avatar
SeanC SeanC is offline
Mein Auto: E70 Xdrive48, F30 328i
Great DIY Dave! Though I'll probably let you do it if something happens to mine
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Old 11-04-2008, 09:30 AM
desertrat desertrat is offline
Mein Auto: non-BMW
Thanks Dave, hope I never need it but it's nice knowing it's here if I do. Yes, it needs to be plugged into the wiki.
Old 11-04-2008, 09:53 AM
dj330Ci's Avatar
Thanks Sean, appreciate the comment. Anytime. We can fix that!
You're welcome. I hope you'll never need it either! I'm not familiar with posting into the wiki. Can somebody help?
Old 11-04-2008, 10:47 AM
troubled's Avatar
troubled troubled is offline
Mein Auto: 00' 323i
Glad to see you got it changed, when can you come back down so SMOLCK can take it on the "death corners"
2000 323i
ZHP Suspension (shocks, springs, sways)
Front Strut Bar
135m Wheels
BMW CCA #407107
Old 11-04-2008, 11:13 AM
dj330Ci's Avatar
I'd probably have somebody's mail box dangling from my door handle not to mention some lady's clothes line.
Old 11-04-2008, 11:55 AM
troubled's Avatar
Mein Auto: 00' 323i
well the ditch will slow you down alot and then you have the trees that will most likely stop you before you hit the clothesline
2000 323i
Front Strut Bar
135m Wheels
BMW CCA #407107
Old 11-16-2008, 09:11 AM
dj330Ci's Avatar
I don't know what's gotten into me . . . Never been this way before, never mechanical but maybe my age has something to do with it. I think the fun part of tinkering for me is that it makes me focus on something for longer than a few seconds. As you all know I replaced my pump a couple weekends ago and it functions very well. I decided to take my old one apart to learn how things work. Well, I think I found the problem. Let's have some confirmation from some of you. My conclusion is that the piece on the far right of the photo is the culprit. This plate is partially responsible for keeping the shaft centered properly while spinning. When I opened this I observed that the shaft was definitely not centered. Look closely at the 2nd photo . . . the hole in the middle is not a circle anymore, my assumption being it's supposed to be a circle. Sooooooooooooo, do any of you know where I can get this part? I know it's a shot in the dark. Maybe someone has a pump for parts? Even if I can't pull this off I have the pleasure of taking it apart and learning something new. This has been a pleasure so far.
ID:	166927   Click image for larger version
Old 11-16-2008, 09:45 AM
jayton jayton is offline
Mein Auto: 2001 325i Saloon
If you guys would like a steal without the gamble, try autohausaz.com. I paid $320 with free shipping, and it was here in 2 days.
Old 11-16-2008, 10:22 AM
dj330Ci's Avatar
I wish I knew where I could get that piece. At this point this is simply a hobby.
Old 01-25-2009, 09:59 PM
TxTorqueMade TxTorqueMade is offline
TxTorqueMade
Send a message via Yahoo to TxTorqueMade
Mein Auto: 2002 330i
I admire your curiosity. If you can find a new part to fix the off center thing Ill try it out on my 330i. Let you know how it/if it works. I borderline need a new pump.
Old 03-13-2010, 03:39 PM
biggdave1 biggdave1 is offline
Mein Auto: 2002 325I BMW
Great post
Thanks for the great post. last weekend i printed your post and changed my PS Pump on my 2002 325I. less than 2hrs to do the job and i even had to run to the parts store for a clamp....worked perfect!!! Thanks again
Old 03-13-2010, 04:15 PM
BMW_325isedan BMW_325isedan is offline
Mein Auto: 2003 BMW 325i
i had this very problem in my 2003 325i the power steering pump went out at just under 60,000 miles now i ordered the pump form www.koperformance.com which was a pretty good deal compared to the BMW dealership in Idaho falls anyway i ordered it form the ko site for 375.00 with free shiping and i recieved the pump in about 3 days and did the install myself only thing i wish i had done was replace the dam belts why i had everthing apart other then that i thought i was a fairly easy job the new pump has been in for over a yeah and doing fine!!!!
Old 05-10-2010, 01:37 PM
phanrick phanrick is offline
Mein Auto: 2001 325CI
Replace Power Steering
Awesome work and graphic. thanks a million
Old 05-10-2010, 02:11 PM
how difficut is it to replace the Oil Housing Gasket. Please help
thanks
