E21 (1975 - 1983)
Rear Disc Conversion
Hey everybody. I have some rotors and 4 big beefy calipers sitting around at storage. i am planning on putting the larger calipers on the front. so my question is what do i have to do to first, change the front calipers, and second, switch over to discs in the rear? thanks.
In the event of brake failure or loss of control, consult with you nearest wall. |
I too have considered installing disc brakes in the back. But it would require, according to my BMW mechanic adding brake lines, new distributor quite alot. He said that if I have to ask... well you know.
If you can find 323i rear trailing arms they have rear disc and the arms are a direct bolt on. I switched mine with the trailing arms and then modified e30 caliper to fit rear. I also have the famous volvo girling calipers on front.
Could you use the equipment off a 5-series for that era?
