E46 (1999 - 2006)
Old 01-28-2012, 04:32 PM
robj213 robj213 is offline
Mein Auto: 2003 325i SP, Xenon
I broke mine in half trying to get it out, but I didn't notice any clogging in it, just a small amount of yellow milky residue. None of the hoses appeared to have any clogging either.
Old 01-28-2012, 11:48 PM
Totte Totte is offline
Mein Auto: E83 X3 2.5si (2009)
Originally Posted by ganseg View Post
Would you mind cutting your oil separator in half to see if it is clogged? I cut mine vertically and there was NO gunk in it. I wonder if it is the hoses that get clogged.
I remember seeing at least one picture here where the dipstick tube itself was completely clogged... There is an updated version of the dipstick tube where the oil guides are made bigger to prevent clogging
Old 01-29-2012, 05:21 AM
ganseg ganseg is offline
Mein Auto: 2001 330i 3.23
This is just a thought in process, but what if a person put a catch can down near the bottom of the engine bay, then ran the hose that goes into the dipstick tube into the catch can. THen the hose out of the catch can would go to the dipstick tube. This would prevent oil from ever being sucked up into the intake (one of the two results of failure). THis would have to be done before things were completely clogged, and you would need to drain the catch can each time you changed oil, but the car would never hydrolock. My car has 145k on it and mine wasn't blocked up, so I would have tried this if I had any thought of it before removing the oil separator.
Old 02-08-2012, 08:20 AM
bluecrab bluecrab is offline
Mein Auto: 2011 328i xDrive
I'm about to this job on my '04 325xi... seeing puffs of bluish smoke out the tailpipe on cold starts. Also seeing smoke every once in a while stopped at a light. Starting to get worse so now's the time. Wish me luck!!
Old 02-18-2012, 03:46 PM
Replaced my CVV and associated hoses/pipes. No more smoke! Pretty tough job but well worth it! I'm a happy camper. I dissected my old valve and, sure enough, the diaphragm was torn. Took me about 4 hours to do the job.
Old 06-10-2012, 03:18 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Lots of pictures of clogged M54 engine dipstick guide tubes over here in the E39 section:
- How to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1)
Our philosophy is not to reward BMW by paying yet another hundred dollars for their redesign - but to redesign the dipstick guide tube ourselves!
The good news is you can test for a clogged dipstick guide tube in just a few minutes and a 1/2 inch ID rubber hose.
Old 06-24-2013, 04:57 AM
VTpeura VTpeura is offline
Mein Auto: 325XI, 330XI, X3
about the cold weather CCV valve installation
Originally Posted by ckleung100 View Post
Very nice write up.
Replacing the hoses is not really an option. GET NEW ONES. They will break. If not now, they will break two weeks after you get everything back together. Save yourself the grief of having to get new ones later and replace them while you already spent so much time taking everything apart. I would even go so far as to say BMW designs them to need replacement, much like the window regulators. Why couldn't they have been metal pipes instead of thin hard plastic?
Some additional information on the cold climate valve: I live in Toronto but upon removing everything, I discovered the car used the regular CCV valve. I wonder how cold it has to get for BMW to install it with the car?
The cold climate version is simply a foam jacket for the CCV valve and foam sleeves for the pipes. If you don't remove the intake, it is next to impossible to get the insulated CCV and connecting hose (item 20, photo 7,8) in. I gave up after 2 hours. There simply is not enough clearance.
I just performed this service this weekend. This forum was great for the step by steps. I did one trick to get the cold weather CCV to install easier. Lightly coat the insulation on the surfaces where it will be contacting other surfaces. This made the ccv slide in to place much easier.
Old 12-15-2013, 03:51 PM
eldonoplay eldonoplay is offline
11611432559 Oil Separator Hose to Valve Cover won't seat right... too long? please help!
Old 12-15-2013, 06:12 PM
iskoos's Avatar
iskoos iskoos is offline
Coupe OR Never
Mein Auto: '02 - 325ci
Never heard of that before.
If it is too long, the only possible explanation is that you did not properly attached the other end to the CVV.
I also assume you got some aftermarket stuff. If so, do yourself a favor and return them to get OEM.
I bought the whole set aftermarket to save about $50 and then none of the pipes/hoses connected properly. It was a nightmare and I returned all of them immediately.
Old 12-15-2013, 06:58 PM
Thanks Iskoos. this thing is kicking my butt... think you are right on aftermarket stuff. fighting them bottom hose now. post wiring harness back in...grrrr
Old 12-15-2013, 07:25 PM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
Re: DIY Oil Separtor, DISA, ICV
From personal experience I can again advise -- this is NOT the project to try to save a buck by using aftermarket parts. OEM only for this one.
Old 12-16-2013, 05:45 PM
Thank you Lbert!! and all of the rest of you folks that contribute. This DYI and others have been beyond helpful. I have relied heavily on you all for the care and well being of my car (2003 BMW 325i 156,000 miles). I have saved roughly 4500-5000 to date and learned some very cool stuff. I am not mechanically inclined.... not at all. But you all have made taking care of my car possible. And I thank you... car is running well now!
Old 12-16-2013, 10:14 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Thanks for the thanks. It's why we're here. We're friends with each other and we have no idea what others look like.
Old 12-17-2013, 06:16 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
In some cases that can be a good thing.....
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 03-15-2014, 08:27 PM
inferno nexus inferno nexus is offline
Thanks for the DIY! Did the job in ~6 hours today. I did however, drop two things into the engine bay and need help with part numbers:
10 mm nut for wire harness box to throttle body. (photo 5 on DIY) I believe it is 07129904865? That's #8 on http://www.realoem.com/bmw/showparts...80&hg=11&fg=40
1/4 turn clip for securing the brake housing shield (Photo 1 on DIY). I can't find this anywhere on realoem or the ECS Tuning catalog.
Old 03-15-2014, 08:56 PM
iskoos's Avatar
Coupe OR Never
Well, can you not drop the splash guard and recover them?
I am sure your splash guard would also enjoy some cleaning while you are there
Old 03-15-2014, 08:58 PM
My condo doesnt allow maintenance in the parking lots, so I avoid raising my car to attract attention....
Old 03-16-2014, 06:51 AM
ahull's Avatar
You can always try a home depot for suitable replacements for both. 10mm nuts are pretty common, just get the right thread count. See if you can find another nut somewhere under the hood that's identical you can take with you to match. They have plastic rivets there too.
Edit: Realoem, #16: http://www.realoem.com/bmw/showparts...76&hg=51&fg=80
Plug the part # into furiousmethod.com and then google it
Old 03-16-2014, 08:13 AM
Thanks! Yup I use furious method all the time; I just couldnt find that diagram on realoem.
Old 07-31-2014, 05:12 AM
justbabs justbabs is offline
Mein Auto: 2011 BMW 535i xDrive
A very helpful DIY. I would add when assembling the lower intake boot to the throttle body, I lined up the rubber tab to the tabs on the throttle body, then used a paint marker to draw a line on the tops of both for easier alignment during assembly on the car.
Old 12-22-2014, 07:53 PM
Ryan4402000 Ryan4402000 is offline
Mein Auto: 2002 330i
I did this DIY the other week. thanks Elbert for the write up. I wanted to add in some tech tips. You can leave the ICV hose connected to the lower intake hose during disassembly since the worm screw is a pain to get to. I did a bunch of other work while in there including cleaning ICV and DISA. Beisan systems VANOS seals, replaced factory spark plugs with 160K miles on them and cooling system overhaul. My car is happy now.[IMG][/IMG]
ccv, diy
