Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 06-19-2003, 08:26 AM
ELOVE525 ELOVE525 is offline
Mein Auto: 1999 528I
Struts And Springs
I HAVE A QUESTION. I HAVE A 99' 528 WITH 18X8.5 AND 18X9.5 RIMS. I WOULD LIKE TO LOWER THE CAR BUT I'M NOT SURE WHATS THE BEST WAY TO GO ABOUT IT. SHOULD I CHANGE THE STRUTS AND THE SHOCKS AS WELL? IF SO, WHICH BRAND IS BETTER?
Old 06-19-2003, 08:57 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
To lower a vehicle, you'll need to use lowering springs of some type. Stock shocks will work, but they'll wear out much more quickly, might want to save labor charges by having both done at the same time.
Check out http://www.tirerack.com/a.jsp?a=AB2&...sion/index.jsp
for more info on suspension!
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
Old 06-20-2003, 08:57 AM
Thank you Gary. Would I need to get struts for the front, or would the shocks be fine? (I know they are pretty much the same thing, but I just want to make sure.)
Old 06-20-2003, 09:14 AM
Moderator
We use the term "shock" to mean struts or shocks. You'll only be able to get one or the other for a given vehicle. You can the term "shock absorber" or "damper" to avoid confusion
Rudy@Tirerack.com
