Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E90/E92/E93 M3 (2008+)
The latest and greatest V8 powered M3!
Old 11-06-2008, 06:07 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Let's Install Alcantara Tricolor ///M-stitch Boots
Start with the shift boot. To remove it, pull up by pinching the leather along the 2 longest sides. The boot is snapped into the console and it will come up when you pull.
Once the boot is unsnapped, reach in and disconnect the wire harness that powers the lighted shift knob.
Pull the shift knob straight up. Use 2 hands. Be careful not to hit yourself in the face when you do this, or hit your knuckles on the rear view mirror. Remember: do not twist the knob as you pull. It will unsnap from the selector rod.
If you are re-using your stock shift knob, you will need to cut it off of the stock boot and glue the exposed leather onto the rim of the shift knob. Use a good contact cement for this like 3M Wedgewood that you can buy at Lowes stores. Turn your aftermarket or replacement boot inside out. Feed the wire harness for your lighted knob (if you are using one) through the neck opening of your new boot. Slide your new boot onto the selector rod. Line up your knob and snap it onto the selector rod.
Connect the wire harness. Turn your boot right side out and snap the new boot onto the center console.
Then move on to the e-brake boot. To remove the stock boot, pull up at the back of the boot by pinching the leather with your fingers. No tools.
Turn the boot inside out over the e-brake handle.
Cut the factory tie wrap off at the neck of the boot and slide the boot off of the e-brake assembly. Turn your aftermarket boot inside out and slide it back onto the e-brake assembly. Re-install a new tie wrap and make sure you line it up to the groove in the brake handle. Take care to make sure you secure the entire neck of the new boot, all the way around the handle.
Turn the boot right side out. Snap it back into the console.
Good job. Remember to use genuine Alcantara and not Ultrasuede or a lower grade product. BMW always uses real Alcantara which is actually a very dark gray.
Jon Maddux
10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe
Old 11-06-2008, 06:11 PM
The Other Tom The Other Tom is offline
Mein Auto: 2008 335i
Good job, Jon
2008 335i
2001 325i retired
2000 M Roadster Imola Red retired
1998 Z3 2.8L retired
Old 11-07-2008, 06:32 AM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Is there any plans of LeatherZ in offering Novillo leather shift/parking brake boots in M3 interior colors (Fox Red, Bamboo, Silverstone, Black)?
Old 11-07-2008, 07:39 AM
JonM's Avatar
Moderator
Yes, we will get to that. These were the first ones a customer ordered and he wanted Alcantara. Sadly, BMW no longer sells OEM hides through dealer parts counters. So getting exact matches will be a challenge. What color are you after specifically?
Jon Maddux
Old 11-07-2008, 07:59 AM
Technic's Avatar
Test... 1, 2 ,3
Bamboo beige... both the shift and the parking brake boots. That and your ZHP 6-speed short shiftknob to complete the combo.
Old 11-07-2008, 03:52 PM
youyou youyou is offline
Mein Auto: 335i
Hi actually i would love to have the shift boot and the e-brake boot in black leather with the ///M stitching.
Basically same as your pictures just in leather instead of Alcantara.
Let me know if this is possible.
Thank you.
Old 11-10-2008, 10:54 AM
JonM's Avatar
Moderator
Thank you.
Anything is possible. I build boots all the time. See http://www.LeatherZ.com
Jon Maddux
Old 11-10-2008, 03:25 PM
Mein Auto: 335i
Ok so can you pm me a price?
I'm a buyer.
Old 11-11-2008, 05:14 PM
HotLap HotLap is offline
Mein Auto: 2008 535i / 2007 GT500
JOn, nice job - but I too would like to see differnent matching interior colors. I'd either like the same black leather (stock) with just the M stitching added OR I'd like to see the Bamboo Novillo to match my M3 interior. Any chance you are going to be doing the Bamboo beige color?
Please PM me a price - I too am a buyer!!
2008 M3 Convertible 6MT, Jerez Black/Bamboo/Sycamore, Tech/Preimum/Packages, Enhanced Preimum sound, 19" M Wheels, I Pod and other goodies
2008 535i 6spd MTX, Monaco Blue w/Cream Beige Interior, Arrived 11/21/08...Sport / Preimum / Cold Weather / IPod / Logic7 / Split Seats / Sunshades
Old 11-11-2008, 05:21 PM
JOn, nice job - but I too would like to see differnent matching interior colors. I'd either like the same black leather (stock) with just the M stitching added OR I'd like to see the Bamboo Novillo to match my M3 interior. Any chance you are going to be doing the Bamboo color?
Old 07-20-2012, 10:23 AM
Brandon594 Brandon594 is offline
Mein Auto: 1993 325i bmw
Is there a way where you can make the shift knob a screw on?
Old 07-23-2012, 02:23 AM
Mike Benvo Mike Benvo is offline
BMW Programmer/Tuner
Mein Auto: E90 M3 6SP / 7 Turbo
Looks good!
A helpful tip is that it's often easier to get the knob off while it's in 2nd gear.
A friend of mine a few years ago knocked himself out cold trying to get it off, the previous owner had glued it on and when it finally gave it hit him square in the jaw
Old 07-23-2012, 08:30 AM
Chuck W.'s Avatar
Chuck W. Chuck W. is offline
Mein Auto: 12 BMW 535I MS Alpine Wht
The quality of your products is well documented, nice job.
One trick I learned on removing shift knobs was to put two screw drives on each side of the knob. One handle on the right side and one handle on the left side. Holding the handles and blades, use the shafts of the screw drivers under the lip of the knob and slowly pull up. Be careful because once it gives, it gives. If folks had videoed some of their removals they would be damn funny.
2012 BMW 535I 14K Miles
ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012
Alpine White, M Sport, Blk Nappa, Cold Weather, Luxury Seating, Premium, Premium Sound, Tech, Sports Trans, Active Cruise, Heads-Up
Mods - Quad Exhaust Tips, HID Fog Lights, Clear Front Reflectors, M5 Spoiler, Calipers Painted Black, 12.5 mm Rear Wheel Spacers, 5% Tint Rear - 35% Tint Front - 50% Tint Windshield
Coding by itschase (Chase)
Next; ED of 2014 M4
