E46 (1999 - 2006)
Old 11-14-2008, 06:22 PM
Bobk528 Bobk528 is offline
Mein Auto: 2001 325Ci, 2002 330Xi
P0491 code - secondary air system
I recently had a mechanic replace the secondary air pump, air valve, electric control valve, and rubber hose (total cost of $1050) because a P0491 and P0492 Check Engine code appeared. After the mechanic cleared the codes, the car ran for 1 day before the Engine light and same codes (P0491 and P0492) returned
There is nothing else to replace. Anyone have any suggestions on how to resolve this code problem?
Old 11-14-2008, 06:30 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
wow, thats nuts. changing that air pump would have fixed the problem. double check to see if you have any leaks
Old 11-14-2008, 06:39 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Sorry to hear that :/. I see you're in San Jose - may I ask what mechanic you went to?
Old 11-14-2008, 07:56 PM
toddkageals toddkageals is offline
Mein Auto: 2012 335i Sport
I got this same code when I changed my CCV valve. In changing the valve, I removed the intake manifold. On the back of the intake manifold (near the firewall) there was an electrical connector that I left disconnected. It's easy to do since you can't see it once the manifold is back on. You can feel it with your hand if you remove the microfilter housing. Should be easy to feel around back there and see if something is disconnected. Could also be a short in that wire I suppose. You might try a mechanic's mirror on a stick to be able to see back there.
Good luck.
Todd
Todd
2008 335i
Old 12-01-2008, 07:45 PM
jayton jayton is offline
Mein Auto: 2001 325i Saloon
So how did it all turn out? Is the light still on? Have you rechecked the wires?
Old 12-10-2008, 06:14 PM
mikevaquez's Avatar
mikevaquez mikevaquez is offline
Send a message via Yahoo to mikevaquez
Mein Auto: BMW 325ci
Have the same problem. I changed my secondary air pump and the check engine light came back on after 2 days. Anyone have an answer for this?
Dynavin
Angel Eyes
5000k Fog Lights
Hard Wired Escort 9500ix
2 twelve inch Orions
Diamond Audio Componets(Front)
JL Audio Components(Rear)
Old 12-21-2008, 04:18 PM
P0344 - camshaft sensor, P0491, P0492
Several weeks ago, the OBD reader displayed three codes: P0344 - camshaft Position Sensor, P0491 and P0492, which are related to the secondary air system. Shortly after reading the codes, the car would not start.
My son replaced the OEM pulse generator/Camshaft position sensor and was able to get the car running. The codes were erased and have not returned.
Is there a direct relationship between the earlier diagnostic codes (P0491 and P0492) and replacing the camshaft position sensor (P0344)?
Old 04-27-2009, 08:06 PM
Several months ago the check engine light returned with the same code numbers, P0491 and 0492. After searching the bulletin board, an independent BMW mechanic determined that the problem was isolated to the non-return valve, which is part number 11611312737 and according to Bav Auto, it cost $16.95 but the small plastic piece looks like it costs only 5 cents.
Old 06-12-2009, 09:02 PM
The problem seem to be a 50amp fuse for the secondary air pump (fuse slot number 36). I went to AutoZone and paid $3 for the fuse, erased the code and the Check Engine light has not turned on for a week.
Old 12-04-2009, 01:05 PM
raeboo raeboo is offline
Mein Auto: 330xi
saw this on e46 Fanatics:
Last November the Check Engine light appeared on a 2001 325Ci and the diagnostic code reader displayed P0491 and P0492. An independent mechanic replaced the secondary air pump, air valve, electric control valve, and rubber hose at a total cost of $1,050.
After the mechanic cleared the codes, the car ran for 1 day before the Engine light and same codes (P0491 and P0492) returned.
The Check Engine remained on until the mechanic recently searched a BMW bulletin board and determined that the problem was isolated to the non-return valve, which is part number 11611312737. According to Bav Auto, the part cost $16.95 but this small plastic piece looks like it only costs 5 cents. So far the Check Engine light has not returned. If you receive a P0491 and/or P0492 code, you may want to first look into replacing a $17 part.
Old 12-04-2009, 01:10 PM
jh jh is offline
Mein Auto: 13 335is, 74 2002, 04 330
Did the tech clear the "adaptive" values... when clearing the codes? I had a recurrence of check engine light couple days after secondary air work on an E36... and when the tech cleared the "adaptive" values... it has not recurred.
Old 01-09-2010, 06:51 PM
AlboBMW's Avatar
AlboBMW AlboBMW is offline
#422323
Mein Auto: '01 325i
I also had this morning, and it was really really cold when I started the car.
I checked the codes, then I went to the internet.
I found this
Once you get fault codes, it does not automatically mean that you have to replace parts. The FC's simply mean that you have problems in the circuits mentioned(in your case the secondary air systems in banks 1 & 2). You still have to diagnose the cause of the problem before you replace parts if needed.
Sometimes you do not even need to replace anything(like when you just cut a vacuum hose with a loose end provided it still reaches its destination, or you just plug a connector that got loose).
Your problem is with the secondary air pump system(the system in general since it involves both banks). At cold engine startup, the pump runs for about a minute to provide extra air into the exhaust system so that unburned gases gets burned off in the catalytic converter as part of the emissions system.
The general overview of the system is this:
1) the pump is turned on by the engine computer (DME) at cold startup
2) the DME switches on the pump relay (usually found behind the glove box) which turns on the pump. The DME does its work properly when the 5 fuses in the main electronic box are not blown(the fuses are housed in a small box of 5 fuses). The small fuse box in turn is housed inside the big black box either on the left or right side of the engine compartment.
3) if the pump does not turn on at cold startup then there may not be power at the connector to the pump or the pump itself is bad (or the pump may turn slower due to low voltage supply or due to a bad pump motor); you can feel and hear the pump running it is at the right somewhat front area of the engine compartment
4) when running, the pump provides the air output thru a hose to a valve which is switched on by a vacuum switch solenoid (thru a small vacuum hose), usually the hose gets wornout and can no longer switch on the valve, sometimes the solenoid switch goes bad (this is at the left side rear end of the engine), sometimes the valve itself goes bad (you can test this by removing the valve, looking for free movement and functional testing by supplying vacuum to it)
5) when the valve is working properly, then the air supplied by the pump goes into the exhaust manifold and then the catalytic converter
6) the oxygen sensors before and after the catalytic converter monitors the situation during the brief span that the pump works (at cold startup) and then gives an OK or stores a fault as needed.
So you see, it is not a simple matter. But with the above data you can diagnose the problem and find out for yourself what the car needs. It can be a fuse, relay, valve, solenoid switch, vacuum hose, or pump. But definitely not 02 sensors.
http://en.allexperts.com/q/BMW-Repai...325i-P0491.htm
So I checked the hoses. The thin long one, runs all around the intake manifold into a insert into the manifold, behind the engine, under the cabin filter assembly. The hoses were fine. I erased the codes and hoped this was a one time glitch. I allowed the car to completely cool down --easy to do in 19 degree weather-- and I started the car. The code did not return and the secondary pump came on, then after 50 second I heard it wind down like usually.
I also checked the fuses, and they were fine.
Old 05-26-2010, 11:18 AM
gramirez gramirez is offline
Mein Auto: BMW 325ci 2001
Question: My name is grace, i drive a 325ci 2001, having problems with code0491,0492, to replace the check valve, where does it go?
Old 05-26-2010, 11:49 AM
Starless Starless is offline
Mein Auto: 2002 325i Auto
I have a write up in my signature with some good resourses for you. See if that helps
Old 08-22-2015, 09:15 AM
tony745li tony745li is offline
Account Under Review
Mein Auto: 2003 bmw 745li
https://www.facebook.com/groups/700477680083131/
*I got the aga secondary air cleaner kit for rent* and the aga valve stems kit for rent as well
Call or text* 414 5172179 tony
Or u can add me on Facebook* at
