The X5 SAV Forum
Old 04-09-2017, 09:12 AM
vlc8165 vlc8165 is offline
Mein Auto: 2005 x5
x5 start problem
my 2005 X5 sometimes wont start in the morning.it will start 2 or 3 days in a row then the next day nothing but clicking.sometimes even after 1 day.i took it in and the battery was fine,when I jump it to start it it fires up right away.i check the battery and its at 14 volts.anybody have similar problems ,need some insight.
Old 04-09-2017, 05:26 PM
Fifty150hs Fifty150hs is online now
Mein Auto: SF Bay Area
Are you checking your battery voltage before you jump start it when it won't start? You could have an intermittent parasitic drain that gets masked by jump starting.
Old 04-09-2017, 07:49 PM
Mein Auto: 2005 x5
thanks,i will check the battery before the next start.what is a intermittent parasitic drain.never heard of it.
Old 04-09-2017, 08:14 PM
It is where something doesn't go to sleep like it is supposed to after it is shut off. The X5 is designed to "go to sleep" 16 minutes after the car is shut off and there is nothing done to wake it up (like opening a door). There are multiple electrical systems that go to sleep. When one of them doesn't, it drains the battery. Usually over night.
I had this same problem. I'd go to start the car in the morning and dead battery. Jump start and every thing fine for about a week. Then it happened again. Jump start again and everything ok for a week again. Then it happened again and again and again. Finally tracked it down to the telematic not going to sleep. Started out intermittent until it was virtually constant.
Old 04-10-2017, 07:50 AM
Mein Auto: 2005 x5
question is how or what is the fix.thank you.
Old 04-10-2017, 09:45 AM
If it is the telematic and you don't use bluetooth, disconnect it. IF that is the cause. If you do have parasitic drain it could be any number of things. The easiest way to figure it out is to do testing with an ammeter to determine draw after the car is supposed to go to sleep. Anything over about .4 amps means something isn't sleeping that should. To chase that down you basically have to start pulling fuses until you find the circuit with the draw, then you'll know.
If you have lots of time, you can pull a bunch of fuses and then check the car the next morning. If it starts, insert one fuse and wait until the next morning. If it is drained you know that circuit is the problem. If it starts, insert another fuse and so on.
Old 04-10-2017, 03:29 PM
Mein Auto: 2005 x5
thank you for your help.i will try your suggestions.
