Old 12-06-2011, 09:10 AM
VileVince VileVince is offline
Mein Auto: 2005 645Ci
Originally Posted by VileVince View Post
Just got this warning this morning in my '05 645ci while making my first left turn at a stop sign. I pulled over, parked, turned the car off, turned it back on & warning was gone the whole commute to work (about 30min). I didn't notice much with steering response or anything, maybe a little "tighter", if that makes sense. I'm going to check my fluid levels later when the car cools again, hopefully it's just low & I'll go grab some Pentosin CHF 11.S for $20. Glad I found this thread, I figured it was probably low fluid, plus it has been rather cold here lately.
Checked my fluid yesterday before heading to lunch, stick was bone dry. Saw there was fluid in there, but very low. Seemed like the same combo of low fluid & cold weather. Went & bought some CHF 11s at O' Reily's & topped off this morning. Had no issues commuting to work & steering seems to feel back to normal. Total cost $24.02 with tax.
Old 12-08-2011, 10:35 AM
WilliCO's Avatar
WilliCO WilliCO is offline
1oz perception-1# obscure
Mein Auto: 2016 Chevrolet Tahoe
I was smart enough to leave my garage door open on Monday night, when the temperatures in Denver dipped below zero. By the time I got out to my car in the morning, it was still really cold in there - about 5 degrees. Sure enough, I got the steering message.
I'm on the road, but I'll check the fluid when I get back. I bet it's low.
-Will
2016 Chevrolet Tahoe LT | 2013 535i xDrive M-Sport (Retired) | 2005 545i Sport (Retired - best of the litter) | 2001 X5 3.0 Sport (Retired)
Old 12-19-2011, 04:18 PM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
I got my annual active steering malfunction warning today. Fluid must have been a bit low because it cleared itself right away and my turn signal would deactivate by turning the wheel.
If you get the malfunction and turning the wheel does not clear the turn signal indicator (either direction), it is likely a problem with the steering angle sensor as opposed to the power steering fluid level.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 06-04-2012, 12:53 PM
zlatan545i zlatan545i is offline
Mein Auto: 2005 545i
Nice forum people, just got this stupid message today, After pulling into chinese restaurant parking lot it was steep sidewalk I wonder if that triggered the fluid to drop below the sensor line for a second? I will try adding CHF-11 fluid to see if it will fix it, will be back.
Old 07-13-2012, 03:08 PM
samtekle samtekle is offline
Mein Auto: 2000 323i
see thread below
Old 07-13-2012, 03:09 PM
see thread below
Old 07-13-2012, 03:10 PM
a
Old 07-13-2012, 03:30 PM
here is how i fixed mine after trying resetting it many times it always comes back right away turning the steering wheel to left and right to reset did not work either . Finally out of frastration i disconnected the battery both poles and waited for 15 min got in the car and just turned the key to on only not starting the car to my surprise i can see the tilted steering wheel slowly center it self to normal position waited a little longer to give it time to adjust then just started the car. car started good but the light was still on .while car still running turned the wheel all the way to the left first then all the way to the right (while turning the wheel to the right i felt this hard jolt at the wheel and i returned wheel to center and wow light goes out) drove the car all day no problems at all she is back baby. My car 2004 bmw 530i sport. hope this helps.
Old 10-04-2012, 10:56 AM
PSmith1269 PSmith1269 is offline
Mein Auto: 550i
I had this same problem for the past month "Steering Malfunction...Possible hazard from fluid loss in steering or suspension hydraulic system. Do not continue driving." The warning would only come on in the mornings as I was driving to work. Later in the day (going to lunch, coming home, etc) the light would NEVER come on. I had it looked at by my mechanic several times but the fluids were always fine, etc. But, the third time I brought it in they found that the "low fluid sensor" for the power steering was bad. I am waiting for the part to come in and for him to replace it and then hopefully...no more problem! Lol...
Old 10-23-2012, 07:27 AM
JDPSP JDPSP is offline
Mein Auto: 2005 BMW 645ci
Steering Hazard Warning
This actually a DIY on most BMWs.
Replace the sensor which requires the purchase of the reservoir, cap and sensor (check online BMW parts Atlanta) and fill back up with SF-11 fluid. The cost for my 645ci was $59, two new clamps and the fluid ... $26. The process took about fifty five minutes.
Note: Use a turkey baster to remove the fluid in the reservoir first so you don't have fluid all over your garage floor.
Old 10-23-2012, 08:57 AM
Mein Auto: 550i
My mechanic ended up changing the sensor for me about three weeks ago and now the problem is gone. He only charged me $110.00 total for parts and labor. I'm sure if I had gone to the dealer it would have been at least three times that!
Old 10-23-2012, 09:06 AM
He likely put the reservoir on and reused the fluid. The side benefit is that the resevoir has a filter in it and if you are over 60K, that's a good thing.
Old 10-23-2012, 09:00 PM
Tiki123 Tiki123 is offline
Mein Auto: Bmw 540i
Steering malfunction
I had the same message and took my car to dealer. They say they need to replace a steering rack, and they are charging me $5000.00!!! I'm shocked!
I drive 2004 550i. It has 70K. Never an accident, easy Florida driving. Help!
Old 10-24-2012, 04:17 AM
Might be the case. Do you notice any steering issues or just the hazard warning? If the latter, I'd leave and have an independent garage install the reservoir. The most important thing you can do if you are not into DIY, is to have a very good indy shop
Old 12-06-2013, 07:47 AM
zen1111 zen1111 is offline
Mein Auto: nevada
steering malfunction warning. plz help
I received steering malfunction warning as well. And it appears, it only happens when temp is cold. Some people suggested just by topping it off (fluid) . solved their problem. I hate it to take to dealership if i can fix it by just adding fluid. Can anyone tell me where fluid cap is located and what type fluid I need to add? I appreciate your help in advance.
Old 12-06-2013, 07:52 AM
Mein Auto: nevada
Oh i forgot to mention. I live in Nevada, USA. Thanks
Old 12-06-2013, 09:52 AM
WilliCO's Avatar
Tis the season! It would be fun to plot the coming and going of activity on this thread against nationwide temperature drops.
You guys need Pentosin CHF 11S hydraulic fluid - the reservoir is marked under the hood; I don't have my E60 anymore or I'd post a picture. I bet 90% of the people who got the warning today just need a little topoff.
Should be able to get the fluid at the local auto parts store.
-Will
Old 12-07-2013, 01:52 PM
Mein Auto: nevada
Greer. Thank you for your response. Hope it works. I'm going top it off as u suggested. Hope it take cares of it
Old 12-07-2013, 02:16 PM
WilliCO's Avatar
Steering Malfunction Warning...
Let us know.
-Will
Old 12-09-2013, 05:30 PM
Mein Auto: nevada
Re: Steering Malfunction Warning...
I open the hood and I see leakage from steering fuel. You guys think I can have it fixed by private shop instead of taking to dealership . we all know they stick it.
Old 12-09-2013, 06:56 PM
WilliCO's Avatar
That was a watch item on my E60; I traded it before it became a problem. My indie seemed to understand it, I would have trusted them with the repair.
-Will
Old 12-09-2013, 07:01 PM
Mein Auto: nevada
Mine is 06, 85k. Love my car but thinking about selling it. Do you know how much is the repair?
Old 12-09-2013, 07:23 PM
WilliCO's Avatar
Nope, never got that far.
-Will
Old 02-13-2014, 11:17 AM
Xlaox Xlaox is offline
Mein Auto: 04 545i
Im having this problem now. Actually been having it for a couple of months now and im getting fed up with the steering wheel being cocked to one side.
I've tried the following.
check fluid (a bit low, filled up but still on even after weeks of topping off)
Resetting with steering with. Left, right, middle (tried with car on and off.)
Disconnecting my byatter for about 2 mins. (Only took off the negative post.)
After disconnecting the battery the I drive told me to turn the car off and back on so active steering could initialize or something like that. I did it and still no good. Everything was the same as before. How am I able to check myself if the module or power steering fluid sensor is bad. I hate to take it to the dealership.
Old 02-13-2014, 01:11 PM
H F H F is online now
I'm not sure that it's a temperature issue. I live in SO CAL, and have been getting this phantom steering malfunction for the last six months in warm weather.
the only time it appears is an hour more during really hard cornering when I do my canyon carving . Then it resets after I park it and drive normal.
It never happens on street driving or freeways though so I'm not sure what to do about it if I should start replacing sensors and stuff.. I know that I need to replace my thrust bushings and wonder if it has something to do with that. I'm going to replace those soon so Ill see if it does have something to do with it,, but I doubt it.
