Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 11-21-2008, 08:32 AM
stock328is stock328is is offline
Mein Auto: 328is
DIY: Oil Service light reset
I am not responsible if you cause damage to your vehicle.
Unscrew the service port cap. (Located on the right side of the engine bay or left side as you stand in front of the car, round cap next to the right strut tower: see photo location below)
Once you have it opened you will see a big Pac-Man shaped hole and twenty little round holes. What is a Pac-Man? Never mind. We are only concerned with pin 7 and pin 19 (note: the words "pin" and "hole" are used interchangeably in this text). Refer to the picture below to find pins 7 and 19.
What we will be doing in this exercise is connecting pins 7 and 19 with a paperclip for four seconds. This will reset the oil service light. Simple, no? But first, here is the list of pins and what they are supposed to do:
Pin Terminal Description
1 TD TD Signal
2 - Not occupied
3 - Not occupied
4 - Not occupied
5 - Not occupied
6 - Not occupied
7 SI Service Interval Reset
8 - Not occupied
9 - Not occupied
10 - Not occupied
11 - Not occupied
12 61 (D+) Generator Charge Indicator
13 - Not occupied
14 30 Voltage; Hot At All Times
15 RXD Diagnostic Data Link
16 15S Voltage; Ignition Switch in Run
17 - Not occupied
18 PGSP Programming Line
19 31 Ground
20 TXD Diagnostic Data Link
OK, now you're ready to reset the oil service light, so turn the ignition key to position II, but don't start the car. Get out of the car and go to the data port. Always connect pin 7 first. Once you've inserted one end into pin 7, insert the other end into pin 19 and hold it there for 4 seconds. Then remove the paperclip. Check the dash and the oil inspection lights should be reset. The reset occurs upon removal of the clip.
IMPORTANT: DO NOT HOLD IT THERE FOR LONGER THAN 10 SECONDS or you may inadvertently reset your inspection I/II interval.
I am not responsible for this write up, I found it on the web. It took me twice to get it to reset but the first time I did not touch the sides of the port holes with the paperclip. Make sure there is contact with the inside of the ports.
Again, Do Not leave it there for more than 10 seconds.
ID:	167344   Click image for larger version
98 328is
Old 12-31-2008, 12:57 PM
Mike Gardner Mike Gardner is offline
Send a message via AIM to Mike Gardner
Mein Auto: '01 X5 3.0 '00 323CI 540i
Question Applies to Newer 3 Series? - 2000 323CI?
Can you do the same thing with the 2000 323CI? I am in the process of tuning up (or thinking about it) my 323 CI and need to know how to reset the service light.
Thanks,
Mike
Old 12-31-2008, 01:44 PM
SkyDog SkyDog is offline
Mein Auto: 2001 325i
Information on how to reset the service indicator on your 323Ci or any other E46 can be found HERE in our E46 Wiki. Set aside some time to read the wiki and you'll probably find out all sorts of new information about your car.
The wiki is linked at the top of the E46 model-specific forum if you ever need to find it. And there are plenty of helpful folks who hang out in there who are more than willing to help if you've got questions.
Old 01-05-2009, 10:50 AM
fungus-318i fungus-318i is offline
Mein Auto: '90 318i e30
can you link me to an e30 version
Lee
Old 01-05-2009, 08:24 PM
Ron Stygar's Avatar
19,585 Miles
1 TD TD Signal
2 - Not occupied
3 - Not occupied
4 - Not occupied
5 - Not occupied
6 - Not occupied
8 - Not occupied
9 - Not occupied
10 - Not occupied
11 - Not occupied
13 - Not occupied
17 - Not occupied
19 31 Ground
http://www.unofficialbmw.com/e36/ele...ce_lights.html
Old 02-18-2009, 02:32 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I tried this and failed after a Motive oil change.
Reason? Nobody told me there isn't a diagnostic port in the 2002 E39, so be advised the procedure here relies on you knowing that the engine compartment data link connector only applies to 1997 to 2000 (E39s anyway).
For my E39, I reset the service interval from inside the cockpit.
0. Put the key in the ignition but do not turn it (OFF position)
1. Press the odometer reset button and hold it down
2. Turn the ignition to the first detente (ACC position)
3. DO NOT TURN the ignition to the second detente nor the third (which starts the engine)
4. Continue to hold the odometer reset button down
5. After about five seconds, you'll see a flashing "RESET" on the cluster
6. Release the odometer reset button and press again for five seconds
This reset my service interval (since I don't have a diagnostic port).
As for the 20-pin engine diagnostic port, here's the pinout ...
Old 09-22-2010, 01:39 PM
bobo1956 bobo1956 is offline
BoBo1956
Mein Auto: 2007 M Coupe
Can someone please post the same Oil Ligh Reset procedure for a 2007 M Coup?
Greatly appreciate it.
Old 10-07-2010, 09:25 AM
1fastg 1fastg is offline
Mein Auto: 330i
it looks hard!
330i Marlon
Old 10-12-2010, 04:18 PM
Uptowngurl Uptowngurl is offline
Banned
Mein Auto: hyundai
Such as a good resource of information information it here. Thanks bluebee for a helpful ideas.
Old 11-10-2010, 05:58 AM
pengola pengola is offline
Mein Auto: BMW X5 4.4i
will this work for an x5 4.4i ?
Old 02-03-2014, 06:50 PM
kmcl kmcl is offline
Mein Auto: 2001 Z3
Talking It works!
Did my first oil change on my 01 Z3 2.5L and shorting pin 7 and 19 with a paperclip worked. It took a few tries to get it but it worked exactly as described.
Old 09-06-2016, 12:14 PM
JohnnyRevs JohnnyRevs is offline
Mein Auto: BMW e39
Yep, still works
Did this today on my e39 and can confirm this still works!
Many thanks to OP.
Old 01-03-2017, 07:23 AM
rbelton rbelton is offline
Mein Auto: E39
Here's the reset for the E30 model:
Here's the reset for the E53 and E39:
Old 01-27-2017, 10:43 AM
BadBoyBeltran BadBoyBeltran is offline
Mein Auto: 2011 BMW 550i GT
How can I reset the Oil Service Light on the F07?
2011 550i GT
2013 1199R
2011 RSV4 SE
Old 01-28-2017, 08:19 AM
DIY: OIl Service light reset
I got it. Very simple.
1. Turn ignition on. Do not start the car. (Do not step on the brake pedal, and the car will not start)
2. Press on the odometer reset button and keep it pressed until the service/ maintenance data appears.
3. Select the service that you want reset.
4. If the service can be reset, press the odometer reset button for 5 seconds.
5. You should be done !!!
2011 550i GT
2013 1199R
2011 RSV4 SE
