E46 (1999 - 2006)
Old 11-22-2008, 07:16 PM
simmonsinc's Avatar
simmonsinc simmonsinc is offline
Sophistication...
Mein Auto: 2000 BMW 328i
Question BMW OEM Battery vs. Auto Zone, Batteries Plus, Advance Auto Parts...
Guys,
I am so mad I can't see straight. Is there a difference between a BMW Battery vs. another brand name battery? Is it the name that you are buying? Or is there actually a performance difference?
I can understand mechanical parts, but this is a battery.
Sean
Old 11-22-2008, 07:37 PM
Mark_325i's Avatar
Mark_325i Mark_325i is offline
Mein Auto: '03 325i, '88 325iC
Autozone duralast 49L (if I remember correctly). $80. Fits and works fine.
Mark
88 325iC
03 325i
Old 11-22-2008, 07:50 PM
dj330Ci's Avatar
dj330Ci dj330Ci is offline
The Ultimate Übermensch
Mein Auto: 2006 330Ci ZHP
You can return the battery dude after buying one at Autozone.
There's no such thing as an ugly man with a fat wallet!
Old 11-22-2008, 07:56 PM
ckleung100 ckleung100 is offline
Mein Auto: '99 323i
Originally Posted by simmonsinc View Post
Guys,
First of all, calm down Sean, it's not worth it.
Originally Posted by Krisl
Originally Posted by stilover
chinese battery, autozone battery whats the difference. anything that is not german made might as well be chinese haha and yeah idk i guess i got a deal on the bmw battery
The battery that autozone says our car needs is $140 (94-DLG). The autozone that will fit, has more CCA, and works great (as tested by hundreds of E46ers including myself) is only $70 or $80... the 49-DL. Go ahead and spend $140 if you want though . You do realize that the OEM BMW battery is made by Douglas Battery co of North Carolina, right? It's not German. Autozone batteries are made by Johnson Controls of Milwaukee.
There ARE differences in battery construction but the key to comparing batteries is usually CCA ( cold cranking amps). Typically, the higher the CCA, the better the battery has to be constructed to achieve a higher CCA rating.
You are paying mostly for the name. The OEM battery IS a quality battery but it is no better than batteries from other reputable companies like Autozone or Exide.
Old 11-22-2008, 08:03 PM
simmonsinc's Avatar
Sophistication...
Thanks Guys!! I just hate it when ppl get over on ppl. Well, can you tell me this, is it true that the alternator would have to work harder to recharge a larger CCA?
Sean
Old 11-22-2008, 08:09 PM
Mein Auto: '99 323i
You get a definite NO from me on that one. I thought I explained it to you in the other thread. I don't claim to know EVERYTHING so I'm not offended if you want someone to confirm what I'm saying.
CCA(cold cranking amps) are how much power the battery has in RESERVE. The alternator replaces what is used up during startup and then stops. If not, it will overcharge the battery. The only thing that will wear out an alternator is if you add aftermarket stereo amps and the such that will constantly draw off the alternator.
I don't understand why you tech would tell you something like that unless he is getting a commission from the battery. (or did you pay him cash on the side??)
Old 11-22-2008, 08:12 PM
simmonsinc's Avatar
Sophistication...
You did, you did, just wanted to make sure - I seriously can't see straight cause I am so mad. I can't believe that he would bs me like that. I mean hell, if there really is no difference between a BMW Bat, and any other bat, why change it. I will be calling up there Monday. That's some shady sh***.
Sean
Old 11-22-2008, 08:24 PM
slyfocks slyfocks is offline
Mein Auto: 2005 330ci
Some of the OEM batteries are AGM (absorbed glass mat) type which is arguably a better technology. They are, however, much pricier and have lower CCA than conventional choices that are readily available. For normal environmental conditions and on-road use/vibration, the advantage is probably questionable. If AGM choices were available with CCA equal to something like the 49DL and at a reasonably close price, I would go that way, but I am not aware of any that are domestically available that meet those conditions.
Old 11-22-2008, 08:36 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Originally Posted by slyfocks View Post
The OEM battery is AGM (absorbed glass mat) technology which is arguably a better technology. They are, however, much pricier and have lower CCA than conventional choices that are readily available. For normal environmental conditions and on-road use/vibration, the advantage is probably questionable. If AGM choices were available with CCA equal to something like the 49DL and at a reasonably close price, I would go that way, but I am not aware of any that are domestically available that meet those conditions.
Yep, I was just going to mention that. AGM is a superior battery technology, but it's roughly the equivalent of using a quad core machine to do email when it'll fail just like any other battery in 4-6 years. No need to pay more $$.
Old 11-22-2008, 09:07 PM
robj213 robj213 is offline
Mein Auto: 2003 325i SP, Xenon
Another happy customer of the AutoZone 49DL here. Will be 2 years next Feb with the battery, so far so good!
Old 11-22-2008, 09:25 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
Well, you guys have the AGM choice if you want it. From all the other owners I've talked to and my dealings with the dealer, back in Mexico we only get the white batteries and the black AGM's are not available. At least we won't be spending unnecessary money...
BTW, what's a thin black rubber hose that plugs into the side of the OEM battery? I'll probably have to change it sometime next year when it gets over the 4 year threshold and was intrigued when I found that little tube sticking out the side. Haven't gone to the local AutoZone to see if they carry the model so highly recommended in the forum.
Don't you all think that battery capacity is a tad small? I mean, for a car that has so many electrical doodads and is so dependent on electrical power, the battery seems almost puny. Or maybe it's because I was used to carrying a monster of a battery on the ole Linc.
Old 11-22-2008, 09:30 PM
Mein Auto: '99 323i
The black hose is the battery vent to vent the gases (h2) outside the vehicle since the battery sits in an enclosed trunk. You don't want hydrogen trapped in your trunk. Think Hindenburg.
The battery only needs to supply enough juice to start the car. All the electrical doodads and doo-hickeys are run off the alternator.
Old 11-22-2008, 09:31 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
That would be the vent tube. When batteries dischage, they release hydrogen gas. Not a problem when the battery is under the hood.. but it can be an explosion hazard when in a sealed trunk... so you have to make sure you re-connect the vent tube to the new battery.
OEM capacity is fine.
Old 01-06-2011, 12:44 PM
otl100 otl100 is offline
Mein Auto: BMW X5
Angry BMW Batteries VS Other Batteries
My friend has a BMW X5 and has had problems for the last 2 years with Les Schwab batteries. She bought the "Xtreme power, 84 month battery"; since then the battery routinely dies on her, requiring her to get a jump or get the car towed to a garage where they will charge her battery. I just found out today from BMW that BMW batteries ARE different from the batteries that you might buy at Les Schwab, Chucks or other car parts suppliers. I don't know if this applies to ALL BMW models but what I was told was that since BMW vehicles have so many bells and whistles, there is a constant draw off of the battery. Les Schwab or other batteries are not powerful enough to withstand this constant power drain. Most importantly, BMW batteries are sealed and vented while Les Schwab batteries are sealed and not vented. The venting is important since the battery is buried in the back of the car under the tire. While my friend saved about $79.00 buying a non BMW battery, she has gone through the expense and aggravation of having a non functioning battery for 2 years, paid for jumps, tows and charges. Les Schwab completely denies ANY problem with their batteries or installation, and said that BMW is wrong!
Old 01-06-2011, 02:18 PM
e30_for_life e30_for_life is offline
Mein Auto: ZHP / E30 M3
^ Sorry dude, BMW power requirements aren't more extensive that an average modern car loaded with bells and whistles. A respected brand will do just fine. Be it Duralast or Interstate. I've heard mixed things about Optimas.
'04 330i ZHP * OEM Clears * ///M Strut * CoolantSnitch
Old 01-06-2011, 02:24 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Your information is partially correct... Your friend's X5 is of the newer generation variety than our E46 and those vehicles require a programming change so the car knows how to charge the battery. If it had an AGM battery from the factory and she installed a standard battery, there's her problem. The computer needs to know what type of battery is in the car.
From my reading around here, both are fine, but without the programming to match, the problems described will result. The E46, the last owner friendly BMW, doesn't care what kind of battery is in the trunk.
Jeff R.
Coconutpete's Avatar
Coconutpete Coconutpete is offline
Coconut Pete's paella!
Mein Auto: VW Wabbit
What does your friends X5 have to do with a thread from 2008 in the 3-series forum?
The word "there" can appear as a pronoun, as in “over there".
"Their" is a possessive pronoun. In a phrase like “Susan and Bill's car,” it could be used to to make a new phrase: “their car.”
”They're” is a contraction of “they are.”
“They are” should always be able to replace “they're.”
Extra credit: It's "I'm looking for an M3" not "I'm looking for a M3".
Old 01-06-2011, 02:30 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
First things first....
Check the dates BEFORE posting !!! You`re responding to a thread that`s been dead for over 2 years.
And, replacement batteries from WalMart or Autozone are perfectly fine, for one-half the price of a dealer`s cost.
Read the E46 Wiki.
Use the SEARCH function....there are probably *at least* a thousand "which battery ?" threads....
The road goes ever onward....
(R.I.P. Jever)
Old 01-06-2011, 06:58 PM
AlboBMW's Avatar
AlboBMW AlboBMW is offline
#422323
Mein Auto: '01 325i
Buy OEM. It's cheaper in the long run. BMW batteries are superior to DL, in my opinion. I purchased a DL49 and it leaked acid all around the battery console.
Old 01-07-2011, 07:38 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Sorry dude, I disagree with this one.
Old 01-07-2011, 09:20 AM
Bilstein Bilstein is offline
The Dude abides.
Mein Auto: 2002 325xi
Yeah, Albo, you're so far out on a limb that I fear for your safety.
See the attached comparison.
Old 01-09-2011, 12:26 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Total fluke.
Old 01-09-2011, 12:34 PM
Fast Bob's Avatar
Keeping it surreal
Total fluke.
I think so....how many `festers (and E46fanatics) have we seen who replaced their ailing battery with a Duralast ? Probably in the *hundreds* at this point, and I have never heard another complaint such as this one. Law Of Averages points to "fluke"....
(R.I.P. Jever)
Old 01-10-2011, 08:01 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
We use the Duralast DL49 over in the E39s also:
- What battery (1) & what battery maintenance (1) & battery replacement DIY (1) (2) (3) & how NOT to change it (1) (2) (3)
Old 06-01-2011, 01:05 PM
OSIX OSIX is offline
Mein Auto: 325i '93
Found this thread today research battery options for my 325i. Douglas Battery is not far from me, so when I read they were the OEM I gave them a call. I was told they sold that part of the business to East Penn Manufacturing. I contacted the local office and they referred me to a shop in my area that sold their batteries. Expensive compared to the after market units out there. But thought I would share this info in case anyone ran across this post and was interested.
