E36 (1991 - 1999)
Old 11-24-2008, 06:21 PM
tooli21 tooli21 is offline
Mein Auto: 1995 M3 Coupe
E36 M3 Idling Issue
Hello All,
I recently purchased a 95 M3 and am new to this forum. I've had the car for about three weeks and it runs beautifully, but within the last two days, has started to intermittently "surge" and drop revs while idling. It doesn't seem to threaten to stall, and does seem to happen more when the engine is just below normal operating temperature.
Any thoughts? I am suspecting an O2 sensor or something like that. If so, does anyone know cost range for replacement?
Old 11-24-2008, 06:29 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Welcome to the 'Fest! What do you mean by surge? Like, the whole car physically lurches forward, or what?
O2 sensors aren't that bad, but I rather doubt it's them. One thing you can try is cleaning your ICV (Idle Control Valve). There are lots of DIY instructions on that, it's not hard. Check out bimmerdiy.com for instructions, or search around here.
Anyway, since you're 95 that's OBDI, you get the pleasure of having the pedal trick. Search pedal trick and you'll see what I'm talking about, and get instructions on how to do it and how to interpret the response you'll get. Then, if you post up the codes we can tell you exactly what's wrong.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 11-24-2008, 06:46 PM
DennisVet DennisVet is offline
Denmo
Mein Auto: 328 ci
It is the Idle control valve. You need to replace it. Partsgeek.com. Make sure your spark plugs are good.
Old 11-24-2008, 06:55 PM
I Am The Machine
It can be cleaned very easily, it's VERY rare to actually *need* to replace ICVs.
// Chad //
You're a derbanana
Old 11-25-2008, 03:14 PM
Thanks for all of the advice.
Phantom...The car doesn't move forward, but rather the RPM surges up or down, we'll say +- 200 RPM from the normal idle speed. I'll have to check out the pedal trick.
I think I'll try cleaning the ICV before replacing anything, and also check the spark plugs for corrosion.
Old 11-25-2008, 03:29 PM
I Am The Machine
Yeah, definitely sounds like an ICV issue to me if your RPM fluctuates like that.
// Chad //
You're a derbanana
Old 11-25-2008, 04:36 PM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Could also be a vacuum leak or a dying/leaking brake booster.
Old 11-25-2008, 06:18 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
+1, was just about to say that. =)
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 12-22-2008, 01:33 AM
lutfiali@izzi.c lutfiali@izzi.c is offline
Mein Auto: 318i 1994
How is a leaking brake booster affect the rpm? I am having similar problem. After a hard acceleration which followed by braking, the rpm drops around 500 and jumps up and down. I just changed two knock sensors because the fault code showed that way, true enough the knock sensors were broken. But still, after changing them i still have the same problem and the idling is rather rough. I am thinking to change the oxygen sensor but not sure.
Old 12-23-2008, 02:03 AM
Hi all,
Just to report that my erratic engine problem has beed solved today by the BMW specialist. The culprit is a combination of dirty/sticky air-flow meter + loose cables at inlet manifold + probably cracked air hose. They changed the hose and cleaned the aif flow meter, fixed the wiring, the car now drives like new and very responsive and light, no more erratic rpm after hard acceleration, i am so happy!
Merry Christmas and Happy New Year everybody.
Old 12-23-2008, 02:05 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Exactly the same as mine!!!
Stupid MAF
2001 Mini Cooper R50
Edirty6 for life
Old 01-07-2009, 10:22 AM
325i Fury 325i Fury is offline
Mein Auto: 1995 BMW 325i
Engine Temp sensor could be bad or cam sensor..
Old 01-07-2009, 12:32 PM
Still here
Mein Auto: M3
Excellent call
Mine were ok, but still possible
Edirty6 for life
e36, idle, m3, o2 sensor
