E30 1991 325i 5000 rpm engine cutout problem - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 11-26-2008, 11:46 AM
baaaaaaa baaaaaaa is offline
Mein Auto: 1991 BMW E30 325i
Exclamation E30 1991 325i 5000 rpm engine cutout problem
I've got a manual 325i that has a problem where the engine cuts out at around 5200 rpms. It does not stall or anything but won't go past this point. It does this in just about every gear and does not do it if you slowly accelerate up past this point. It mainly just doest if if you hammer it or floor it. I have done alot of work to this car lately and really am stumped about this problem. The things I've done to it this summer include dinan chip, scorpian exhaust, k&n intake, oxygen sensor, thermometor, manifold gaskets and more.
Anybody had this problem or got any ideas whats wrong
Old 11-26-2008, 11:51 AM
Edev's Avatar
Edev Edev is offline
BMW Genius @ BMW Portland
Mein Auto: M Coupe
youre hitting the redline. your gauge is probably off a little bit which is why it cuts off there rather than around 6k.
btw. dont hit the redline every gear.
BMW Genius @BMWPortland.
2000 Z3 M Coupe
Old 11-26-2008, 12:51 PM
kamotors's Avatar
kamotors kamotors is offline
Mein Auto: 325i
I've heard of this happening alot, Its not a rev limiter your hitting is it? someone on e30tech had the same problem only i think it was cutting out at like 4500rpms. don't remember what the problem was but i'm pretty sure it wasn't the guage being off.
89 325i~~04 s60r~~88 635csi~~91 325ix-SOLD~~02 WRX-SOLD~~04 WRX-SOLD~~01 2.5RS W/h6-SOLD
Old 11-26-2008, 01:07 PM
I don't think it could be the tac off becuase a few months ago it would go past 5000 no problem. Ill look into though. Thanks
Old 11-26-2008, 09:40 PM
downhiller's Avatar
livin large
i would say most likely the rev limiter is telling you to shift. theres hardly a need to hit redline or get within 500rpms of it, because the closer you get, the more power youre losing, both torque and hp. i only hit 4800 bout once a month, to get any loose carbon off the valves, plus its nice to let the engine unleash the fury every once in a while....
Old 11-26-2008, 10:03 PM
I don't think it could be the rev limiter becuase I have a dinan chip which makes the rpm go to 6900 redline.
Old 10-03-2013, 05:57 PM
wielandgeorg wielandgeorg is offline
Mein Auto: 1995 530i
Hello how did you ever correct this issue. 91 325i ran to redline nice the other day, today it hangs at 5000 feels like it just cuts out. Pulls strong to 5000 then no more won't go past that.
I don't want to throw a lot of money at it guessing
Would be nice
To know how you fixed the issue
Old 10-03-2013, 08:04 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Take your valve cover off and see if you have any broken valve springs.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 10-03-2013, 08:08 PM
It idles fine and runs great up until 5k why would it do that smoothly if a spring was bad? It almost seems like it happens after the car got wet like in a rain.
I doubt it's a problem w cam or rockers or so
Old 10-03-2013, 09:05 PM
downhiller's Avatar
livin large
could have bad/cracked coil/spark plug wires, fouled/dirty/old/too big of gap spark plugs, rotors worn, dizzy cap cracked/dirty contacts.
i would first start with a tune up (depending when the last time you did it) then find an o-ring or gasket to help seal the dizzy cap from moisture entering.
you could also have a loose/too much gap cps. tryin to give easy stuff first
Old 09-23-2014, 09:39 AM
kiwi1993 kiwi1993 is offline
Mein Auto: e30 325i
Find the issue? have the same......
