E46 (1999 - 2006)
Old 11-28-2008, 07:17 PM
BeAmW325i BeAmW325i is offline
Mein Auto: 325i / 335i
Lots of white smoke coming out of exhaust
A LOT of white smoke is now coming out of the exhaust. After doing some research, it seems like a head gasket issue?? I opened the engine bay and checked the oil dipstick. The oil is not milky, and looks normal. However, I saw some splashes of white dried liquid (probably coolant) near the coolant reservoir. Would a blown gasket cause that? Errr!!! The car is a 2002 325i with 58K miles.
2007 335i Coupe
6-Speed | Black Sapphire Metallic | Coral Red | Gray Poplar Wood Trim | Sports Package | Premium Package
2002 325i Sedan
Step | Oxford Green Metallic | Gray Leather | Sports Package | Harman Kardon | Heated Seats
Old 11-28-2008, 08:17 PM
DaShoker's Avatar
DaShoker DaShoker is offline
Fitness Freak {}=={}
Mein Auto: Lexus SC turbo
Probably head gasket. So low mileage though....... Anything crazy happened before? May be overheat or something else?
Vadim
^ Highway Beast ^
SC300
2JZGE NA-T
Old 11-29-2008, 05:00 AM
I don't think it has overheated. I'm the second owner though! Few days ago, the startup idle was a little rough and that was it.
2007 335i Coupe
2002 325i Sedan
Old 11-29-2008, 05:10 AM
da geez's Avatar
da geez da geez is offline
Escape Artist®
Mein Auto: MY 07 M Coupe
If it is coolant, and I think it is, the exhaust should smell like coolant.
Telepath wanted: you know where to apply.
2007 Interlagos Blue M Coupe
2004 325i and I'm not sure what color it is except for dark silver.
Old 11-29-2008, 08:03 AM
Nov99328i's Avatar
Nov99328i Nov99328i is offline
(o0\(III)(III)/0o)
Mein Auto: 99 E46 328i
Do you have an oily tailpipe? Mine looked like white smoke but was actually light blue. I ended up with a blown oil separator "CCV". Take your spark plugs out and check for black oil on them.
ADR gunmetal 18's, Clears up front & sides, DVD system mounted in headrests + 1 up front, Dinan CAI + software
Mirror tint all around, M-TECH II front bumper, Front and rear Foglights
For my yoke is easy, and my burden is light. Matthew 11:30
Old 11-29-2008, 09:35 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
+1. Another fester had the SAME issue. he thought he blew his motor. I fixed the CCV for $185 in parts and about 4 hours. Oh, you'll need new plugs too. YOU DO NOT HAVE A BLOWN HEAD GASKET!
Old 11-29-2008, 10:19 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
I agree with smolck....the easiest & cheapest way to verify this is to pull the plugs after the car has sat for awhile....if they have an oily film on them (as opposed to a nice, dry, greyish-tan color), your oil seperator is shot.
The road goes ever onward....
(R.I.P. Jever)
Old 11-30-2008, 09:43 AM
Thank you for the feedback guys. I don't know much about these things, but had a few emails back and forth with a tech, and he was saying that it sounds like the Crankcase Vent Valve. Would that explain the little bit a white "splash" around the coolant reservoir area? I will take the car to a BMW service shop on Monday or Tuesday and have them take a look at it. If it is the CVV, can I drive the car for about 5 miles to the shop, or will take make things worst? I don't want to tow it, if not necessary. BTW, there are no CEL's or warnings on the dash.
2007 335i Coupe
2002 325i Sedan
Old 11-30-2008, 09:45 AM
This might be an obvious smell to some, but I have no idea what coolant smells like
2007 335i Coupe
2002 325i Sedan
Old 11-30-2008, 10:01 AM
smolck's Avatar
ROLL TIDE!
Yea, you can drive it 5 miles. It might sputter and die a bit. But the CVV is most certainly the problem. Don't let them take you for a ride on this repair. The parts are only $160 or so, and I did one in 4 hours first time ever doing it. I have seen quotes as high as $1100 which is pure BS. Don't be afraid to shop. You have power the regular public does not have......Bimmerfest. Report back their findings and cost BEFORE you authorize work if you want to save $$ and not get screwed!
Old 11-30-2008, 10:37 AM
Thanks. I will get estimates from 2 shops before dropping the car off. I will report back and let you guys know what they find. Smolck, wanna drive to North Florida and hook up a brother Is there some kind of a TSB for this issue...I read about it on e46fanatics? I will call the dealership on Monday too.
2007 335i Coupe
2002 325i Sedan
Old 11-30-2008, 11:22 AM
smolck's Avatar
ROLL TIDE!
You won't get the CVV replaced by BMW. You got SEC championship tickets? I'd drive to North Florida for that! What part?
Old 11-30-2008, 11:24 AM
Ryan M Ryan M is offline
Mein Auto: .
If it were me, I'd spend a few dollars and get a compression test done. Or if you know how, do it yourself.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 11-30-2008, 12:31 PM
smolck's Avatar
ROLL TIDE!
Why? It is clearly the CVV....
Old 11-30-2008, 12:32 PM
Mein Auto: .
Because I don't like to guess.
Old 11-30-2008, 12:55 PM
smolck's Avatar
ROLL TIDE!
But what has the OP said that even remotely sounds like a blown head gasket? White residue near the coolant resevoir (aka expansion tank)? My car has that too. If it was milky in the oil then I could understand that. But since I have just fixed this EXACT same problem for another Fester when most people here diagnosed as a blown head gasket, it isn't a "guess" it is an "educated guess" It was Nova's comments that helped me pin it down. This guy has all the same issues, and a simple glance at the plugs will show them covered in black oil and thereby confirm a bad CVV.
Old 12-01-2008, 01:54 PM
Just got an estimate of $500 to replace the CVV with parts and labor. This place only works on BMW's. I should have the car by tomorrow evening. They said the white smoke was caused by the oil being sucked out of the engine and getting burned, not the coolant. I'll update you guys again tomorrow.
2007 335i Coupe
2002 325i Sedan
Old 12-12-2008, 12:57 PM
digidybear digidybear is offline
Mein Auto: 2001 740il
i had the same problem and still do, i had the valley pan seal replaced, and the osv (oil seperator valve) and the thing still smokes when starting it up but stops after.....I'm going bonkers because its more annoying than a mechanical problem. any other suggestions from anyone ...thanks
Old 12-12-2008, 01:06 PM
smolck's Avatar
ROLL TIDE!
If your oil separator went bad, your plugs are probably fouled. Change them....
Old 12-12-2008, 03:51 PM
Nov99328i's Avatar
(o0\(III)(III)/0o)
O2 sensors are prolly shot too...............
Old 12-13-2008, 04:26 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
It smells "sweet". Buy a gallon of BMW coolant and sniff it. If your exhaust smells the same, it's a bad gasket.
You'll need the coolant soon anyway.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 12-13-2008, 04:29 AM
Scott ZHP's Avatar
We want the Lion!
Reread the first post ...
"A LOT of white smoke is now coming out of the exhaust."
Old 12-13-2008, 08:45 AM
smolck's Avatar
ROLL TIDE!
Doesn't automatically mean blown head gasket. A failed oil separator can cause more smoke than you can imagine. This was the problem with a recent fester I helped replace the CVV.....
Old 12-13-2008, 09:13 AM
Scott ZHP's Avatar
We want the Lion!
Yeah, no kidding. I've been around, in, under and through enough engines to know that as well.
Your quote was this: "But what has the OP said that even remotely sounds like a blown head gasket?" Re-read the first post, including the title.
Old 12-13-2008, 12:25 PM
smolck's Avatar
ROLL TIDE!
Yes Scott, we bow to your greatness...
He also said "oil level is fine and not milky" and his car only has 58k on it. These engines don't have a habit of popping head gaskets unless overheated with only 58k.....
