1998 740iL - Low coolant level warning - Bimmerfest - BMW Forums
Old 12-07-2008, 01:15 PM
incinci incinci is offline
Mein Auto: 1998 BMW 740IL
I have a 1998 bmw 740iL. It gives me a warning saying "check coolant level" when the car is cold. But when it has been run for a while, and i start the car again, the warning goes away. What could be the problem?
Old 12-07-2008, 01:31 PM
morrisP morrisP is offline
Mein Auto: 1985 528e
mabie air pockets in the coolant system, when the engine gets warmer it trys to push the air out the resivore tank, somtimes the fluid fills the tank before any air can escape, thats why it says its fine after it warms up. try taking the refill cap off and run the car until you see the coolant back in the tank, then if any bubbles start to come up, be ready to top it off because it will suck the remaining fluid back into the system in place of the air pocket, so you dont want any air going in after it. try to keep an eye on overflow, somtimes the the air will push out the fluid before it comes out so try not to let anything important get wet. put a plastic bag over any close electrical components, or shield the side of the engine with somthing. this has happened with mine too so i hope i could help...
Old 12-07-2008, 10:26 PM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
The sensor is seeing a borderline low. Coolant expands when it is heated up so there is "more" coolant in the system when it is hot than when it is cold.
Filling it up with coolant and water should eliminate the warning.
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 12-08-2008, 08:15 AM
mandrews1119 mandrews1119 is offline
E38 - Flight on 4 wheels!
Mein Auto: 2001 750ilA
Don't forget to bleed the system of air with the small screw at the top of the tank. Do this when COLD the screw is plastic and can crack under heat .
[SIGPIC]
2001 BMW E38/750il V12
Anthracite Metallic: If this car were any faster, I would have arrived yesterday!!
BMW, the ONLY driving machine.! By the way, yes, it's fast...and NO! You can't drive it!! Power, elegance, styling, technology that is still cutting edge, the ultimate driving machine for sure.!
Old 12-10-2008, 10:51 AM
project37 project37 is offline
Mein Auto: 1998 740iL
I had the same problem. I would check my expansion tank to confirm that the coolant level was fine and even bleed any air from the system but the "Check Coolant Level" nag would still come on occasionally. It turned out to be a faulty sensor. Not expensive or difficult to DIY.
P.S. I am new to your forum but not to the E38.
Old 11-17-2010, 08:35 PM
taco_combo taco_combo is offline
Mein Auto: 2001 BMW 740I sport
dont mean to bump an old thread,
but my check coolant light also comes on in the morning when the car is cold. my car has 140k on it. I will do a coolant flush with a mechanic actually. it probably needs one.
I had a mechanic check it about a month ago and he said the level is fine actually. (maybe a bad sensor???????????)
I guess this is a common theme on bmw's esp the e38.
how much is it for a sensor if the sensor is faulty or dead?
Old 11-17-2010, 10:44 PM
wilk187's Avatar
wilk187 wilk187 is offline
2001 740il Sport, RIP
Mein Auto: 2006 750i Sport, '14 GTR
It's like 25/30 bucks. 30% more from the dealer. Easy swap
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes,
LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
HTML code is Off
