E34 (1989 - 1995)
Old 12-13-2008, 02:50 PM
wildwex wildwex is offline
Mein Auto: 525i
Thumbs down 1995 525I Won't start then clutch pedal fails
I was driving my 1995 525i and acted as if it was running out of gas then died. I towed it home and used starter fluid and it tried to start. I checked fuel pump fues, etc., but still can't get it to start. I was planning to pull the fuel pump and check it out and when I went in (after leaving the car in the garage for 4 days), I press the clutch in and it had no resistance and went right to the floor. Before this, I put a battery charger on the battery to charge it up. Any ideas.
Old 12-13-2008, 06:29 PM
attack eagle attack eagle is offline
No more e34!
Mein Auto: Nikes + Mongoose
two unrelated issues
`03 Summit White Tahoe LT
LM7, G80, GT4, PDZ, ZW7, G65, PDP, etc.
Mutual Admiration Society
Member #5
Old 12-13-2008, 07:12 PM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
Have you checked for spark? Get it to start before you deal with the clutch issue.
Old 12-13-2008, 08:20 PM
mednetlive mednetlive is offline
Mein Auto: 530it
Diagnostics
The clutch issue, and the engine failure are probably 2 seperate issues.
First, do a very basic diagnostic check. Crank the engine for a few seconds and then
remove a spark plug. Is it "wet"? If it is then you have an electrical problem, most likely
a crank shaft sensor failure. If the plug is dry, then you have a fuel supply problem.
When the crank sensor fails, it will send a message to the the ECU, telling it to shut down
the engine electronics, this includes spark.
As far as the clutch is concerned. Is it mechanical or hydraulic? Best bet is that it's hydraulic. Check fluid resevoir, and clutch cylinder for leaks. Clutch cylinder is easy to replace.
Good luck
Wool
fuel pump and clutch
